clockworkbox Samba Member
Joined: July 12, 2020 Posts: 473 Location: Williamsport, PA
Posted: Mon Jan 16, 2023 11:56 am Post subject: Front End Repair or Replace? |
I am doing a restomod on a 69 Beetle. There is damage from a front end collision that has been somewhat repaired but there is quite a few wrinkles left. I also have a front clip that is in good shape from a donor car. I'm hoping to get some feed back about weather I should try to further repair the original or weld in the donor clip. What do you think? Pictures below of the current damage.
_________________ '69 Beetle (pieces)
Learning the hard way is still learning... |
toxicavenger70 Samba Member
Posted: Mon Jan 16, 2023 2:53 pm Post subject: Re: Front End Repair or Replace? |
If it was me I would make a bumper mount that has a hook on the end of it so you could take a come-a-long and pull it out. It would take some time to get it where you need it but I do not believe it is crunched that bad. |
esde Samba Member
Joined: October 20, 2007 Posts: 6352 Location: central rust belt
Posted: Mon Jan 16, 2023 5:14 pm Post subject: Re: Front End Repair or Replace? |
I'd try repairing it. As mentioned I'd try pulling it. Get some tension into the panel, and then work the hammer and dolly on the wrinkles. _________________ modok wrote:
Posted: Tue Jan 17, 2023 10:36 am Post subject: Re: Front End Repair or Replace? |
Thanks for the advice! I think an old nerf bar would probably work to hook the come-along to but I will have to wait until the body is back on the pan try that. I am not trying to build a show car and I think pulling it back out will be easier. I did a lot of welding in the early to mid 90's but I'm sure I'm going to have to relearn those skills once I get into the bodywork. There are some bends in those areas from the factory and I think the biggest issue will be figuring out how to reform them properly. Thanks again! _________________ '69 Beetle (pieces)
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18046 Location: Eugene, OR
Posted: Tue Jan 17, 2023 1:38 pm Post subject: Re: Front End Repair or Replace? |
Bolt the fenders & bumper on it.
Only heat/hammer & dolly anything underneath that messes up the fit/gaps.
Wrinkles underneath don't need straightening usually. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
67ctbug Samba Member
Posted: Wed Jan 18, 2023 3:39 pm Post subject: Re: Front End Repair or Replace? |
Depends on what you plan on doing with the car. It could be repaired, but I'd bet it tears a bit when pulling. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
...or the PO envied the terrorists' bus in "Back to the Future".  |
mukluk wrote: |
