volksbugusa Samba Member
Joined: May 19, 2003 Posts: 382 Location: BUNNELL , FLORIDA. 32110.
Posted: Mon Jan 16, 2023 1:08 pm Post subject: my fly wheel |
today I pulled my motor..I was surprised to see my flywheel with worn teeth facing the pressure plate. not sure how this happened..must have been before my ownership..I never had an issue...should I replace it......What might have caused this...I do not see any damage on the starter gear.......
_________________ Matthew E D'Azzo
volksbugusa
https://www.facebook.com/groups/506947294919060 |
toxicavenger70 Samba Member
Posted: Mon Jan 16, 2023 2:11 pm Post subject: Re: my fly wheel |
A worn out starter bushing can cause this to happen. I had the exact same issue when I bought my car. I replaced it with a new flywheel because it started to get noisy on crank ups. |
Posted: Mon Jan 16, 2023 2:14 pm Post subject: Re: my fly wheel |
toxicavenger70 thanks for getting back to me.....will replace the flywheel yes...looking at my starter there is only the gear and no nose shaft....so i don't need to replace the bushing..am i correct? Thanks Matt _________________ Matthew E D'Azzo
volksbugusa
Posted: Mon Jan 16, 2023 2:38 pm Post subject: Re: my fly wheel |
volksbugusa wrote: |
toxicavenger70 thanks for getting back to me.....will replace the flywheel yes...looking at my starter there is only the gear and no nose shaft....so i don't need to replace the bushing..am i correct? Thanks Matt |
Looks like you have a self supporting starter. So you should be good to go. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33197 Location: Hot Arizona
Posted: Mon Jan 16, 2023 3:11 pm Post subject: Re: my fly wheel |
I think I'd just use grease on the flywheel teeth and starter teeth when I re-installed.
If you get a new flywheel, then you'll have to deal with adjusting the end play most likely.
Your starter is the autostick type self-supported type, fine. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
FarmerBill  Samba Member
Joined: July 25, 2017 Posts: 877 Location: New England
Posted: Mon Jan 16, 2023 4:43 pm Post subject: Re: my fly wheel |
If it's not grinding I would leave it be.
I had an engine with bad teeth on the flywheel, so bad that when the engine stopped on the worst spot I would have to turn it a few degrees by hand so I could start it. Since an 4 cylinder almost always stops in the same two positions, and since I was broke, I was able to fix the problem by removing the flywheel and turning it 90 degrees. |
Wulfthang Samba Member
Posted: Mon Jan 16, 2023 10:12 pm Post subject: Re: my fly wheel |
I mentioned lubricating the flywheel teeth with some kind of dry lube on the HBB forum. https://www.thesamba.com/vw/forum/viewtopic.php?t=776544
It was not widely accepted! The most common reason for not doing it that I found in my research is "because we ain't never done it thatway afore so why start now"? I'm not going to use grease but will use some type of dry lube, probably motorcycle chain lube. Non sticky, won't fling off and lubes pretty well. |
modok Samba Member
Joined: October 30, 2009 Posts: 27713 Location: Colorado Springs
Posted: Mon Jan 16, 2023 11:47 pm Post subject: Re: my fly wheel |
if it's just a four dowel, turn it 90 degrees to even out the wear.
Might have been chewed up by a bad starter gear. |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42788 Location: at the beach
Posted: Tue Jan 17, 2023 3:29 pm Post subject: Re: my fly wheel |
it looks like the starter teeth are too shallow. Is that the original style starter, or did someone swap it for one that doesn't require the bushing. _________________ George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
