Heat/Air levers
KChallener
KChallener is offline
PostPosted: Tue Jan 24, 2023 12:35 pm    Post subject: Heat/Air levers Reply with quote
My 1976 Bay was missing the heat control levers, which I found at many sources. It seems there is a clip and a button that attach the levers to the control rods behind the dash??? I have found pictures but not one with the lever attached, nor can I find those clips anywhere? Any help/photos would be appreciated.
Thanks,
Ken C
1976 Bay, 1974 Thing, 1979 Vert Bug, 1973 Super, 1968 Beetle, 1967 split Brazilian Kombi
busdaddy
busdaddy is offline
PostPosted: Tue Jan 24, 2023 1:03 pm    Post subject: Re: Heat/Air levers Reply with quote
A 76 should use the plastic levers, no clips or springs required for those:
Слава Україні!
Shonandb Premium Member
Shonandb is offline
PostPosted: Tue Jan 24, 2023 1:07 pm    Post subject: Re: Heat/Air levers Reply with quote
I have a 76 and the levers just push on / pull off and are a snug fit.
Previous 1973 Panel Bus:
Click to view image
KChallener
So what connects the to the levers? Not slotted? I am missing something obvious here!!
KChallener
PostPosted: Tue Jan 24, 2023 1:13 pm    Post subject: Re: Heat/Air levers Reply with quote
Heater lever with dimple, assuming the plastic lever attaches there?
Shonandb is offline
PostPosted: Tue Jan 24, 2023 1:37 pm    Post subject: Re: Heat/Air levers Reply with quote
Yes, like this, they just press on.
Click to view image
KChallener
PostPosted: Tue Jan 24, 2023 7:10 pm    Post subject: Re: Heat/Air levers Reply with quote
Thank you! I will look at the ones that came with the bus closer, but I think they may be for an earlier model.
Ken
KChallener
PostPosted: Wed Jan 25, 2023 5:28 pm    Post subject: Re: Heat/Air levers Reply with quote
So I am embarrassed to report that the levers I have that came with the bus are for 1973 and earlier, slotted, not push on. I ordered the correct one Embarassed
