Karma - Part it forward
xoo00oox
xoo00oox is offline
PostPosted: Thu Jan 25, 2024 2:38 pm    Post subject: Re: Karma - Part it forward Reply with quote
xoo00oox wrote:
Cleaning up shop and trying to make room for other things! I am tossing lots and lots and lots of 1.8t parts. If you need something 1.8t and I have it, I'll probably give it away some MK4 stuff and B5 Passat too! a few complete engines! I will not ship! Things are going in the dumpster very soon!
FREE! early style 1.8t, it's going to the scrapper soon!
Run8Stud
Run8Stud is offline
PostPosted: Thu Feb 29, 2024 9:56 pm    Post subject: Re: Karma - Part it forward Reply with quote
I have a serviceable pair of plastic coolant pipes off an '87 2.1 here in San Diego; I just replaced them with a stainless-steel set. If anyone's interested, they're yours if you come and get them.
John G. - 1987 Westy GW 2.2 5-Speed
uberaudi
uberaudi is offline
PostPosted: Wed Mar 13, 2024 10:30 am    Post subject: Re: Karma - Part it forward Reply with quote
GONE!
Anyone want some AdventureWagen windows cranks? Pay for shipping and they're yours.
'84 Adventurewagen 1Z Tdi, '86 Syncro tintop WBX...for now
surfinwesty
surfinwesty is offline
PostPosted: Fri Mar 22, 2024 11:22 am    Post subject: Re: Karma - Part it forward Reply with quote
I Recently converted the spare tire clamshell to the Go Westy storage container (spare mounted in the back).
I have a 15 spare tire with a lot of tread and rubber in good condition. Never been in the sun. I'm willing to pass it along!
Pick up in the North Bay Area.
Current Love:
"Adobe" 1984 VW Westy w/Subi
Retired:
"Swell Chaser #1" 1980 Westy (in VW Heaven)
"Swell Chaser #2" 1981 Westy (sold to loving family on TheSamba forum)
surfinwesty
PostPosted: Fri Mar 22, 2024 11:24 am    Post subject: Re: Karma - Part it forward Reply with quote
Along with the spare, I also have the clamshell that is in excellent condition. No rust.
Current Love:
Retired:
Corwyn Premium Member
Corwyn is offline
PostPosted: Wed Mar 27, 2024 5:34 pm    Post subject: Re: Karma - Part it forward Reply with quote
~ GONE ~I just replaced my Upper Control Arms on my van and before I run them over to the scrap yard, I'll offer them up here for free. Just pay the shipping or come grab them.
'90 White Westy ("White Lightning 😎")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~
flapjack
flapjack is offline
PostPosted: Tue Apr 23, 2024 6:26 pm    Post subject: Re: Karma - Part it forward Reply with quote
I'm in UT and have the following, happy to give out as a gesture of gratitude for all the great advice I've gotten here on the samba:
- 2 perfectly good (basically brand new) BLAU caps for the pressurized tank which I don't need since I installed a metal tank
- 4 tires and 14 inch original rims (the tires are crap but the rims are good)
- a faded square headlight grille with working headlights (the headlights are a bit cracked)
If anyone is interested in these items PM me.
1990 Multivan "Sacagawea" [Burgundy]
It's not a slow car, its a fast house.
professorplumb
professorplumb is offline
PostPosted: Mon Apr 29, 2024 3:54 pm    Post subject: Re: Karma - Part it forward Reply with quote
Used Bosch SR0408X starter - you can use it with [url="https://www.thesamba.com/vw/forum/viewtopic.php?t=638100"]this WestyVentures adapter plate[/url].
Bench tests good, but the solenoid is intermittently sticking and needs a tap. You'll probably want to rebuild the solenoid before installing, but other than that it was working fine.
Can deliver along the 101 corridor between Mendocino County and SF if you're willing to wait, or ship at your expense. Happy starting!
NorCalbuggy
NorCalbuggy is offline
PostPosted: Thu May 02, 2024 4:42 pm    Post subject: Re: Karma - Part it forward Reply with quote
GONE!
I have 10 new cone style lug nuts for alloy wheels (won't fit steel wheels)
Also a blue coolant pressure tank cap.
In Nor Cal but i'll send it if you pay shipping.
Cheers,
Andrew
"Steam seems to have killed all gratitude in the hearts of sailors"
1987 Westfalia Vanagon - "Clifford"
jefhaz
jefhaz is offline
PostPosted: Fri May 03, 2024 7:39 am    Post subject: Re: Karma - Part it forward Reply with quote
Cheers,
Andrew
pm sent
1985 Westy 1.9L
4Gears4Tires
4Gears4Tires is offline
PostPosted: Fri May 17, 2024 5:51 am    Post subject: Re: Karma - Part it forward Reply with quote
KYB rear shocks. A few years old, they work fine. I put Hijackers in my van to level it out so these were removed. Pick up please.
Heavy duty tail gate shocks. ONLY if you have stuff mounted to your tailgate. I accidentally ordered these a few years ago was really annoyed for years at how hard the tailgate was to shut.
vanis13
vanis13 is offline
PostPosted: Fri May 17, 2024 6:58 am    Post subject: Re: Karma - Part it forward Reply with quote
PM sent
4Gears4Tires
PostPosted: Fri May 17, 2024 7:26 am    Post subject: Re: Karma - Part it forward Reply with quote
Hatch struts gone.
4Gears4Tires
PostPosted: Thu May 23, 2024 12:42 pm    Post subject: Re: Karma - Part it forward Reply with quote
Pick up only
Two OEM coolant reservoirs that I'd advise against using only because all OEM coolant reservoirs suck. They don't leak. One comes with a blue cap that I epoxied a new barb to it because the old barb broke. I ran it like that for a few thousand miles.
A full set of rear brakes with 3-5k miles, maybe a lot less. Dunno.
do.dah
do.dah is offline
PostPosted: Wed May 29, 2024 10:04 pm    Post subject: Re: Karma - Part it forward Reply with quote
And, like 4g4t, I'm of the same opinion..
But, if you must,,,
I have 2 coolant pressure tanks. Plastic. One is factory, other is after mrkt.
Total of 4 caps.
The stuff that is used, was fine. No problems.
The stuff that wasn't used,, no idea if functional.
Also have 2 original fuel over-flow tanks and replacement "roll over" grommets.
Tanks and grommets were fine when removed.
[b GONE
4Gears4Tires
PostPosted: Mon Jun 10, 2024 10:46 am    Post subject: Re: Karma - Part it forward Reply with quote
Carb set up for wbx. Worked well when I pulled it from my van back in 2018. Pick up only.
elizer Premium Member
elizer is offline
PostPosted: Tue Jun 11, 2024 9:17 am    Post subject: Re: Karma - Part it forward Reply with quote
elizer wrote:
Pulled off 91 westy.
Decent shape. One panel clip pulled out but looks like you can fit a new one behind the fabric and lay some epoxy on the crack. Requires some adhesive where the fabric is pulling off on the backside.
Would prefer to not ship. Pick up Springfield, Virginia.
Sorry. Put into the trash bin.
91 syncro westy fas tdi
dabaron
dabaron is offline
PostPosted: Wed Jun 12, 2024 12:58 pm    Post subject: Re: Karma - Part it forward Reply with quote
are you saying you threw this in the trash? shameful that no one grabbed it.
1991 Vanagon GL Camper
tim_ha
tim_ha is offline
PostPosted: Thu Jun 13, 2024 7:29 pm    Post subject: Re: Karma - Part it forward Reply with quote
GONE
Free items: Custom pop-top for a sunroof van with partially functional flexible solar panels, steel roof baskets that fit nicely in front and rear of the pop-top. Take one item or all, your choice. See photos of these items installed on my van.
Location: Front range of Colorado. Pick up only, no shipping
It would be great if someone could get some use out of these. We converted to a hightop and so we no longer have any use for these items. I need to get rid of them by mid July.
All items are currently spoken for
1986 Syncro Sunroof EJ22
www.subagonsouth.com
space
space is offline
PostPosted: Fri Jun 14, 2024 11:42 am    Post subject: Re: Karma - Part it forward Reply with quote
PM sent for roof baskets
82 westy
w:
2.5 JDM Subie
Rear discs
Page 4 of 6
