begood56vw Samba Member
Posted: Tue Apr 11, 2017 8:30 pm Post subject: Re: 48 ida's with porsche shroud |
Just wanted to post an update to my carburetor linkage issues. I ended up getting a sync linkage and it's working great. Thanks to all who replied.
![](/vw/forum/templates/subSilver/images/spacer.gif) |
itHaKa Samba Member
![](/vw/forum/images/avatars/10522259774e5ee029383cc.jpg)
Joined: February 20, 2008 Posts: 254 Location: Argentina
Posted: Mon Feb 08, 2016 11:38 am Post subject: Re: 48 ida's with porsche shroud |
begood56vw wrote: |
Well dang I got the second linkage from CB performance and it still won't work. Seems like I have backward manifolds. The CSP center section sits inside the shroud.
Any ideas? ] |
looks like you have the bergmann shroud , i think csp linkage is designed for the csp shroud .
anyway in my case i had sharpbuilt and gwd shrouds and for both i had to trim the the csp central linkage to only use the first bolt in the case (closer to flywheel )
here is a video where you can see the csp linkage with idas
_________________ 76x88 , 1849cc engine build :
http://mundoescarabajo.com.ar/me/viewtopic.php?t=635 |
SBD Samba Member
![](/vw/forum/images/avatars/4615668950ef1f6233c37.jpg)
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Sun Feb 07, 2016 9:59 am Post subject: Re: 48 ida's with porsche shroud |
Howard 111 wrote: |
Bashr, nice looking engine compartment, but then, I'm a little partial to Ghias. ![Very Happy](images/smiles/icon_biggrin.gif) |
Isn't that a Thing engine compartment? ![Very Happy](images/smiles/icon_biggrin.gif) _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
Posted: Sat Feb 06, 2016 12:28 pm Post subject: Re: 48 ida's with porsche shroud |
Well dang I got the second linkage from CB performance and it still won't work. Seems like I have backward manifolds. The CSP center section sits inside the shroud. Any ideas? I think I might have to go with the sync linkage next. Well, I hope my mistakes helps others.
Posted: Fri Feb 05, 2016 2:37 pm Post subject: Re: 48 ida's with porsche shroud |
HotStreetVw wrote: |
Can you show a picture of the CSP linkage? It bolts to the front of the engine case (flywheel end), you will need to notch the shroud for the mounting bracket. |
I tried to post some pictures on the gallery but I lost internet service. I will try again a little later. thanks |
Posted: Fri Feb 05, 2016 2:36 pm Post subject: Re: 48 ida's with porsche shroud |
vince1 wrote: |
begood56vw wrote: |
Nextgen,
Well I got the CSP linkage and it won't Work. . The center section, when bolted to the engine, sits inside the shroud. Back to the drawing board. I'm sure this setup has been done before. I can't imagine being the first one. I just ordered the CB performance 3130. I hope that one works. |
Are you sure you got the type1 with Porsche fan version?
this one : http://www.csp-shop.com/technik/pdf/deeng/21134.pdf |
I ordered CSP # C31-129-941-100IDA from CIP1. It says that it'll fit with porsche fan shroud. |
HotStreetVw Samba Member
Joined: October 03, 2004 Posts: 871 Location: Wild West
Posted: Thu Feb 04, 2016 3:19 pm Post subject: Re: 48 ida's with porsche shroud |
Can you show a picture of the CSP linkage? It bolts to the front of the engine case (flywheel end), you will need to notch the shroud for the mounting bracket. _________________ 4inBhore
50 Split - 2724cc NA. Haltech injected
62 Notchback - 2542cc Turbo WIP |
Howard 111 Samba Member
Posted: Thu Feb 04, 2016 12:48 pm Post subject: Re: 48 ida's with porsche shroud |
Bashr, nice looking engine compartment, but then, I'm a little partial to Ghias. ![Very Happy](images/smiles/icon_biggrin.gif) _________________ 1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270 |
vince1 Samba Member
![](/vw/forum/images/avatars/17172221475bad2faa0d69e.jpg)
Joined: December 14, 2003 Posts: 823 Location: Burgundy, France
Posted: Thu Feb 04, 2016 11:27 am Post subject: Re: 48 ida's with porsche shroud |
Bashr52, that looks very cool. |
Bashr52 Samba Member
![](/vw/forum/images/avatars/16173477845bab81280be34.jpg)
Joined: July 16, 2006 Posts: 5667 Location: On an island in VA
Posted: Thu Feb 04, 2016 8:13 am Post subject: Re: 48 ida's with porsche shroud |
begood56vw wrote: |
Tbirdusa, do u have info on the synclink set up or the person who make it? Thank u in advance. |
http://www.thesamba.com/vw/classifieds/detail.php?id=1381017
I've got two sets of this linkage, its awesome.
Posted: Tue Feb 02, 2016 7:41 pm Post subject: Re: 48 ida's with porsche shroud |
Tbirdusa Samba Member
Joined: November 29, 2006 Posts: 1460 Location: Kansas City, MO
Posted: Tue Feb 02, 2016 7:30 pm Post subject: Re: 48 ida's with porsche shroud |
The Synclink would look bas ass on that setup. It also appears quite flexible in mounting position and if out of the box its a no go, i am sure Slowtwitch Pete would work through it with ya. _________________ Royals 2015 World Champions
Chiefs 2017 Superbowl winner
1986 Falco records Rock Me Amadeus! |
Posted: Tue Feb 02, 2016 7:03 pm Post subject: Re: 48 ida's with porsche shroud |
Nextgen,
Posted: Tue Jan 26, 2016 10:18 am Post subject: Re: 48 ida's with porsche shroud |
Well, too late. I already ordered the CSP Linkage. So if for some reason this one don't fit, any other ideas? I don't think I'm the first one to run this set up. |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6047 Location: CONGERS, N.Y.
Posted: Mon Jan 25, 2016 9:36 pm Post subject: Re: 48 ida's with porsche shroud |
Hotstreetvw
Thank you for posting the pictures. I will order the CSP linkage tonight and post my findings. Thanks again for the information. )) |
Posted: Mon Jan 25, 2016 9:31 pm Post subject: Re: 48 ida's with porsche shroud |
Looks like t1 manifolds. If you look at the picture I posted, zoom into the top right corner. There looks to be room, but your just going to have to try it and let us know. _________________ 4inBhore
Posted: Mon Jan 25, 2016 9:29 pm Post subject: Re: 48 ida's with porsche shroud |
Nextgen,
It's a type 1. |
