removing the thermostat
thelazerviking
thelazerviking is offline
PostPosted: Tue Oct 25, 2005 2:20 pm    Post subject: removing the thermostat Reply with quote
hi, i was wondering if it would be much of a deal to remove the thermostat on my 71 type 1. if i do i'm keeping the vanes and i'd weld them open. i don't plan on really ever driving in the cold weather so i don't think warm up shoudl be too much of a problem but i want to know if it is. it's going to be pretty much for racing purposes. would it be a pretty bad idea to take out the thermostat even if i welded the vanes open? thanks, james
"If I buy the policy, can I be the beneficiary?"
Randy In Maine
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Oct 25, 2005 2:28 pm    Post subject: Reply with quote
You should leave it connected.
But if you must... just remove the 13mm nut that holds the thermostat bracket to the engine. Then just unscrew the thermostat.
If the spring is on the linkage it will keep the flaps open. If it's missing just wire the linkage open.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
thelazerviking
PostPosted: Tue Oct 25, 2005 2:51 pm    Post subject: Reply with quote
oh good idea, thanks
....but am i going to have any engine troubles at all if i do this other than it will take longer to warm up? or would there be any troubles in taking longer to warm up just in itself?
Randy In Maine
Mr. 010
Glenn is offline
PostPosted: Tue Oct 25, 2005 2:57 pm    Post subject: Reply with quote
On short trips it won't warmup and you will get condensation inside the engine case.
You might also increase bearing wear.
If it works... then leave it.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Droolman
Droolman is offline
PostPosted: Tue Oct 25, 2005 8:41 pm    Post subject: Reply with quote
living in texas....i have only used the theromstat on one of my bugs, that being one of my 67's and that is because it is all original...i have driven thousands of miles and never had a bearing failure....and warming up in below freezing conditions has never been a problem....i have 2 67's and i have never noticed any differance in condensation in the oil....now in the northern states....it might be a whole differant ballgame....i have seen what happens when they stick closed though.....its not pretty, but also im all about original and those little things are getting hard to find.
1967 blue bug
1965 drag bug
Towel Rail
Horizontally Opposed
Towel Rail is offline
PostPosted: Tue Oct 25, 2005 10:04 pm    Post subject: Re: removing the thermostat Reply with quote
What benefits are you hoping for? Thermostats weigh next to nothing, and don't hurt performance at all. Confused
bugnut68
bugnut68 is offline
PostPosted: Tue Oct 25, 2005 10:10 pm    Post subject: Re: removing the thermostat Reply with quote
If you really want to go racing, build a full tilt drag car with no cooling system whatsoever, especially if you're that concerned about weight. If it's just a mild performance street car, leave the thermostat for the sake of longevity (VW designed it that way for a reason) and make sure you have gauges set up so you can keep an eye on cylinder head and oil temps. That way you know when things are going awry.
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
Bruce
Bruce is offline
PostPosted: Tue Oct 25, 2005 11:40 pm    Post subject: Reply with quote
Droolman wrote:
l....i have seen what happens when they stick closed though.....its not pretty,
Did you personally see the flaps stuck closed, or did you "hear" about it?
fredybear
fredybear is offline
PostPosted: Wed Oct 26, 2005 8:45 am    Post subject: Reply with quote
This is one of my favorite subjects......make sure u put a head temp guage in if u leave the whole setup in.....cause bad things can happen......and dont weld em open take em out if your not gonna use the whole setup...
bugnut68
bugnut68 is offline
PostPosted: Wed Oct 26, 2005 9:44 pm    Post subject: Reply with quote
Actually, what he should do is leave the flaps in, wired open, if it opts to remove the thermostat unit...the flaps direct the air properly to the heads and cylinders, which is FAR better than running nothing in there at all. This has been proven.
fredybear
PostPosted: Wed Oct 26, 2005 10:25 pm    Post subject: Reply with quote
thats a crock......what i recall is the flaps increase head temps b 5 degrees or so.....
o wait
You got it... wait till you see this data!
tested 4 stock shrouds so far today, with and without flaps! all 4 of them show the same trend and the FLAPS make the engine run consistently 5 degrees hotter on all cylinders! I tested with and without the functionaly thermostat as well! it did not matter!
This is unbelieveable!
I thought for sure the flaps would make a big difference!
wonder where that came from
partonkevin
partonkevin is offline
PostPosted: Wed Oct 26, 2005 10:48 pm    Post subject: Reply with quote
I've always heard to leave the cooling flaps in, even if you remove the thermostat. Apparently, the flaps directs more cooling air to the head where you need it most and less cooling air to the cylinders where you need it least. That being said, I run a single port shroud with no thermostat or flaps (anybody have that stuff laying around?), and it seems to take a while for my car to warm up as it's getting colder out. And I run MUCH better when I am warmed up!
bugnut68
bugnut68 is offline
PostPosted: Thu Oct 27, 2005 6:28 pm    Post subject: Reply with quote
o wait
Jake Raby also said that that five degrees difference won't make or break the engine. The fact is, for ultimate longevity, the whole set up should be left in, thermostat and all.
VW knew what they were doing, far more than a lot of us amateurs. Wink
Andrew
Andrew is offline
PostPosted: Thu Oct 27, 2005 9:40 pm    Post subject: Reply with quote
VW spent something like a million dollars developing and testing the whole cooling system with flaps/thermostat thing. I gotta think they got something right for their money...
-Andrew
bugnut68
bugnut68 is offline
PostPosted: Thu Oct 27, 2005 11:15 pm    Post subject: Reply with quote
o wait
Okay homie, I'm calling you out in a matter of speaking...in this other thread regarding cooling system info:
http://www.thesamba.com/vw/forum/viewtopic.php?p=1052314&highlight=#1052314
You state and I quote: "Sometimes im so amazed by the answers on this forum.....im lost for words........some of u folk need to do some research and testing...."
What was stated in that thread is fact...and what people are stating in here is true as well. The purpose of those flaps and the thermostat is ensuring proper cooling and warm up of the VW engine, as without it engine wear is increased. Five degrees higher? BFD. As I mentioned in my previous post, even Jake mentioned that those five degrees are insignificant, as I recall.
Sometimes i'm so amazed by posters lack of sentence structure and cohesive arguments. Very Happy
Droolman
Droolman is offline
PostPosted: Fri Oct 28, 2005 12:43 am    Post subject: Reply with quote
bruce, i have seen what can happen personally....my father went to work as a vw mechanic in 1959 and retired in 2003 and i was born in 63. i think me and my brother had to tear down every motor and trans that came through his shop....i myself dont work on VW's for a living, but built my first engine when i was 10....and never looked back and i have seen it all...the last time i seen flaps stick was about a year ago on a friends car. it melted the pistons.....im just glad the aircooled VW was built...i will never give up my VW's, but my feelings on VOLKSWAGEN putting it there because they designed it that way and so it must be needed, maybe. i do believe VW put them there to restrict airflow not increase it...i dont ever remember there engineers building a aircooled motor that produced over 300 hp..or a trans that could handle it....so i dont put alot of trust in their research and development team.....what you see running down the road today is because of all the shops and suppliers right here in the good old USA....right or wrong i dont run it.....and other than a 1500 the smallest engine i have on the street is a 2110.....anybody that has taken the time to research this. hats off to you...the only difference i have noticed in the 67 with the 1500 with a thermostat and say my 67 with the 2110 is that the 1500 heater stays consistant....with the 2110, i find that i have to adjust the heater often....by this i mean that on the same 175 mile trip, once i get the heater set where it is comfortable with the 1500 i rarely have to touch it..the 2110 i have to adjust up and down....it will cool down on the open road part of the trip....this is on say a 30 to 40 deg. day
1967 blue bug
1965 drag bug
bugs/buggy
bugs/buggy is offline
PostPosted: Fri Oct 28, 2005 5:32 am    Post subject: Reply with quote
I just had the misfortune of my tail lamp wire getting suck into the fan after reinstalling my motor. In the process it got tied up with the spring that hold the flap in the open position. No thermo just flaps. Now my question is will the flaps be open or closed without the spring? The linkage still move freely by hand. I have driven the car limited miles with no noticable increase in cht (guaged). I'm thinking that the volumn of air from the fan axually blow the flaps in the open position. In respect to wireing them open should the linkage be pushed to the right side or to the left? I really don't want to remove the motor just to replace the spring.
Jake Raby
Jake Raby is offline
PostPosted: Fri Oct 28, 2005 7:02 am    Post subject: Reply with quote
Unless you are in a super Cold climate the thermostat is not that necessary... I did quite a bit of experimentation with T stats when developing and proving both my DTM systems and I'll honestly say that unless you drive like a Grandma that the differences are pretty Nil in direct comparison... I'm talking like just a few minutes difference, even on a 20 degree January day here..
VW did spend a lot of money on the T stat and cooling system and I do feel that the flaps and all other tin MUST be in place and my testing has proven this.
One interesting tidbit is that my Austrian Built Swiss Army Surplus Pinzgauer with it's 2.5L Inline AIRCOOLED engine has no flaps and no thermostat at all and the factory never gave it one-
It warms up just fine here in the US as well...
I have to go now- But I'll make a post later explaining exactly how the flaps and T stat work on the TIV and the kind of air flow percentages they dictate to the oil cooler and each bank of cylinders...
Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell"
fredybear
PostPosted: Fri Oct 28, 2005 7:48 am    Post subject: Reply with quote
[quote="Jake Raby"]
quote]
Your type 1 and 4 DTM r made without pervisions for the flaps or am i missing something???
So if you say the Flaps must be in place what your selling to the public is junk.......am i wrong????
Jake Raby
PostPosted: Fri Oct 28, 2005 9:18 am    Post subject: Reply with quote
The VW system was designed WITH the flaps IN. The TI and TIV DTM were both designed with no flaps in place. I did test them with flaps in place and removed and also directly against the stock system with flaps installed and removed as well and that was done in January for good comparisons.
The TI and TIV DTM were designed and further tested with a performance mindset- I don't give a damn how they do on a 1600 TI or even a 1776- My smallest TI test engine netted 181 BHP and those are the guys that need the cooling capability of the TI DTM- those engines have no problem warming up!
Jake Raby
