stump Samba Member
Posted: Sat Dec 31, 2005 12:28 pm Post subject: 1641 vs 1776 ? |
im currently tearing down my stock 1600 to rebuild im trying to decied if i should use a 1641 kit or have my case and heads worked for a 1776 im planing on a mild cam high ratio rockers and dual 35-40mm carb i already has a 009 dist and 1 5/8 header system i know the 1776 cylinders are thicker and will cool better but what is the aprox hp gain? thanks for your input |
RIS Samba Member
Joined: December 18, 2003 Posts: 3044 Location: Youngstown, Ohio
Posted: Sat Dec 31, 2005 12:35 pm Post subject: |
I'd go 1776cc, a 135cc difference in displacement is enough to feel by the seat of the pants. The extra cost for having the case & heads bored will be worthwhile.
HP gain depends on how the engine is built, heads, cam, compression, etc. Could be 5-25hp difference. _________________ Richard Sedoris - VW Performance & Machine - Youngstown, OH
http://rismachine.tumblr.com/
YouTube: https://m.youtube.com/channel/UCfTBCG4I61iVm_ROc8OAuOQ
Instagram: @rismachine |
stump Samba Member
Posted: Sat Dec 31, 2005 12:53 pm Post subject: |
thanks ris im leaning more to the 1776 my next q is larger valve worth while i figure if im gonna have the heads machined i should have them worked for larger valve too any sugestion is there such thing as to big when it comes to valves ? and if i install high lift rockers is a cam nessary or if i install both what cam lift and rocker height compliment each other best? thanks |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79633 Location: Sneaking up behind you
Posted: Sat Dec 31, 2005 1:12 pm Post subject: |
1776 is a much better choice than a 1641. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
(183)Beast Samba Member
Joined: September 05, 2005 Posts: 117 Location: Kansas
Posted: Sat Dec 31, 2005 2:06 pm Post subject: |
If your splitting the case get the 1776. _________________ An unfinished SandRail and a Baja occupy my time.
1835 with Dual Kadrons, 1 5/8 Tri-Mill and a C-35 Cam//Hopefully a Turbo is soon to come with a Stroker Crank. |
gabe321 Samba Member
Posted: Sat Dec 31, 2005 4:09 pm Post subject: |
stump wrote: |
If you want bigger valves I suggest you buy new heads with bigger valves. The cost to work on your stock head to make them bigger would cost you as much as buyig new ones. I suggest 40x35 you'll notice the difference.  |
Glenn  Mr. 010
Posted: Sat Dec 31, 2005 4:15 pm Post subject: |
The road to high performance is an ever twisting road that only gets more expensive the further you go. _________________ Glenn
Member #1009
#BlueSquare
nsracing Samba Member
Posted: Sun Jan 01, 2006 7:51 am Post subject: big bore? |
When you get to the machining part, let me know.
Easy bore on the case and heads.
Ciao. |
stump Samba Member
Posted: Mon Jan 02, 2006 9:01 am Post subject: |
ok 1776 it is new larger heads sounds good . any opinons on what cam to use? and how about a lightened flywheel? high flow oil pump? high ratio rockers a cam or both? thanks |
RIS Samba Member
Posted: Wed Jan 04, 2006 5:27 am Post subject: |
stump wrote: |
I'd go 40x35 on the heads, whatever you do get them ported! Big valves alone won't do much. If you can only afford to do one for a 1776cc I'd rather see the money put towards porting the stock valve heads to the max (correctly!) than unported big valved heads. If money isn't an object take a look at CB Performance's CNC round ports.
Hard to go wrong with an Engle W-110 cam, can always add 1.25:1 ratio rockers later for more power.
Get a Schadek 26mm pump and machine the case for full-flow - it's all you'll ever need. _________________ Richard Sedoris - VW Performance & Machine - Youngstown, OH
