type 4 tin removal????
mmcleod
mmcleod is offline
PostPosted: Sat Jan 14, 2006 12:24 am    Post subject: type 4 tin removal???? Reply with quote
I took out all the tin screws that I could see. Am I missing something? I got the 3 small pieces out(by the shroud) but the 2 over the block and the one in the back I can't figure out. Also I took out the 6 screws to the panel that hides the fuel tank and it still won't budge either. Hmmmmmmmm???Please help if you can.
Thanks,
Michael
DurocShark
Location: Crappy town in a crappy state. But the beach is nearby, so I have that going for me.
DurocShark is offline
PostPosted: Sat Jan 14, 2006 5:43 am    Post subject: Reply with quote
Intake manifolds off? Foam seal off? Also, sometimes crap builds up in the corners covering screws. What intake? FI? Stock carbs? Other?
The tank door pulls out from the bottom and is often wedged in place pretty tightly. And there are hidden screws that we all miss the first time...
No boom today. Boom tomorrow. There's always a boom tomorrow.
VWGirl
VWGirl is offline
PostPosted: Sat Jan 14, 2006 5:59 am    Post subject: Reply with quote
sounds like you are indeed missing a few screws Laughing clean off the engine tin to look for hidden ones... on the tank, look underneath the body for two more scres, there should be one on either side... they would be to the outside of the fuel tank strap bolts... it's very frustrating trying to remove that panel and not knowing those screws are there!
Without love in the dream it will never come true
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Sun Jan 15, 2006 6:01 pm    Post subject: Reply with quote
There is at least one screw that threads up from the bottom. You might want to check that.
Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page.
Duncwarw
Duncwarw is offline
PostPosted: Sun Jan 15, 2006 6:20 pm    Post subject: Reply with quote
Yep, one each side up in the holes through the thing that passes for a frame rail.
The left big engine tin piece that covers that bank of cylinders is anchored at the back by being a sandwich of three pieces of tin held together by two screws. The right one should be easy.
This is all assuming, of course, that you don't have an upright fan engine in which case, I don't remember... Very Happy
“To find yourself, think for yourself”
Socrates, 470 BC - 399 BC
USMCbug
Samba Yoda
USMCbug is offline
PostPosted: Sun Jan 15, 2006 6:28 pm    Post subject: Reply with quote
If its an upright, then there are some screws on the backside that connect to the tins that cover the pr tubes.
72 Super Beetle
73 Standard Beetle
79 Baywindow Bus
65 Split Window Bus
79 Baywindow Bus
71 Super Beetle (current)
"When war does come, my advice is to draw the sword and throw away the
scabbard."
- General Thomas "Stonewall" Jackson
