rack and pinion kit pics for ghias and beetles
Page: 1, 2, 3, 4, 5, 6  Next
vwairheads
vwairheads is offline
PostPosted: Sat Mar 01, 2008 5:40 am    Post subject: rack and pinion kit pics for ghias and beetles Reply with quote
58Dub
58Dub is offline
PostPosted: Sat Mar 01, 2008 6:31 am    Post subject: Reply with quote
so...is this a kit that is available? from where and how much?
hpw
hpw is offline
PostPosted: Sat Mar 01, 2008 7:18 am    Post subject: Reply with quote
Stupid question, but what is the advantage of a rack and pinion over
a stock gear box?
http://www.youtube.com/watch?v=3SLIzSCt_cg&list=FLIX26sGa8__1F1loczLPTtg&index=2
Joval
Joval is offline
PostPosted: Sat Mar 01, 2008 7:20 am    Post subject: Reply with quote
I'm guessing ebay from the pics, but can't find it listed...
Max Welton
Max Welton is offline
PostPosted: Sat Mar 01, 2008 9:19 am    Post subject: Reply with quote
a stock gear box?
The equal-length tie rods should make the steering geometry symmetrical. And from the picture, it comes with it's own gear-box. Not a worm-and-sector like the stock one.
Looks interesting.
Come on vwairheads, spill it! Very Happy
Max
1967 Type-3 Fastback
Joval
Joval is offline
PostPosted: Sat Mar 01, 2008 10:12 am    Post subject: Reply with quote
In the meantime take a look at this -
http://www.red9design.co.uk/wishbones.htm
Wink
the caveman
the caveman is offline
PostPosted: Sat Mar 01, 2008 10:14 am    Post subject: Reply with quote
Almost looks like a rack from a fox
Eric_S
Eric_S is offline
PostPosted: Sat Mar 01, 2008 11:02 am    Post subject: Reply with quote
Wink
RHD.
Eric_S
What are all these extra parts?
Fibersport
Fibersport is offline
PostPosted: Sat Mar 01, 2008 1:32 pm    Post subject: Reply with quote
$1888 US - ouch!
1973 Standard Beetle
Joval
Joval is offline
PostPosted: Sat Mar 01, 2008 3:10 pm    Post subject: Reply with quote
LHD for $3k?
http://www.eyeball-engineering.net/a-arm.html
vwairheads
PostPosted: Mon Jan 26, 2009 9:41 am    Post subject: Reply with quote
here it is http://www.classic-centrum.de/Kaefer_Lenkung_1.htm
Laughing
Scott Novak
Scott Novak is offline
PostPosted: Mon Jan 26, 2009 10:13 am    Post subject: Reply with quote
hpw wrote:
Stupid question, but what is the advantage of a rack and pinion over a stock gear box?
The play on a stock VW steering box can be adjusted so that it is tight without slop when the wheels are straight ahead. However, as soon as you turn the wheels in either direction, the play increases significantly, getting worse as you turn the steering wheel further. It's a characteristic of the type of steering gearbox that VW uses.
The play, in a rack and pinion steering gearbox in good condition, DOESN'T change as you turn the steering wheel. It's much more precise.
Also, when set up correctly, you can use equal length tie rods with a Rack and Pinion that reduce bump steer. Bump steer is a condition caused by unequal length tie rods when the direction of steering changes when your wheels go up or down. Longer tie rods also reduce bump steer.
The standard Beetle has unequal length tie rods.
The Super Beetle has long equal length tie rods, but it also has an extra idler arm, and the bushing in the idler arm is notorious for failing quickly.
The rack and pinion setup only uses a total of 2 ball joints per side, also minimizing play.
Scott Novak
CBDZ_CBDZ
CBDZ_CBDZ is offline
PostPosted: Mon Jan 26, 2009 11:52 am    Post subject: Reply with quote
OK...enough with the suspence.
What is that rack from?
vwairheads
PostPosted: Mon Jan 26, 2009 7:11 pm    Post subject: Reply with quote
thats the problem but someone posted in grmanlook.com that it is the same rack and pinion from polo mk1,2,3, 86c, and audi 50. I think you can fabricate the superbeetle rack and pinion aswell because the tierods are mounted on the center.
Bruce
Bruce is offline
PostPosted: Tue Jan 27, 2009 1:43 am    Post subject: Reply with quote
Not true.
Bump steer is caused by short tie rods. The fact they are different doesn't make bump steer happen. The short tie rod on the left side of a LHD Beetle is what causes bump steer. Narrow the beam, you make the problem worse.
The suspension above by red9design is CRAP. Look at those short tie rods on BOTH sides. They've taken the WORST characteristic of a Beetle suspension and DOUBLED it.
51'splitDLX
51'splitDLX is offline
PostPosted: Tue Jan 27, 2009 2:03 am    Post subject: Reply with quote
2x bruce incorrect tie rod angles get worse when narrowing is done; the narrower you go the further out of sink things get!!! Ive been told that modifying the pitman arm can help fix this!
http://www.thesamba.com/vw/classifieds/detail.php?id=711188
Scott Novak
PostPosted: Tue Jan 27, 2009 3:00 am    Post subject: Reply with quote
Bruce wrote:
Not true.
Actually, unequal length tie rods can cause bump steer, and shorter tie rods can make bump steer worse in some cases. In other cases, longer tie rods can CAUSE bump steer.
With a stock standard Beetle, if you hit a bump that moves both wheels upward the same distance and you have unequal length tie rods, the toe in or toe out on one wheel would be different than the toe in or toe out on the other wheel and the vehicle will be pulled to one side.
If the tie rods were equal length and both wheels moved upward the same distance, no matter what the length of the tie rod, both wheels would toe in or out by the same amount it would NOT create bump steer.
If you hit a bump with one wheel only, it will toe in or out and it will also pull the vehicle to one side. The shorter the tie rod, the worse the bump steer. There will ALWAY be some bump steer with it's geometry design.
However, if you had a double wishbone suspension with equal length upper and lower arms, and the short tie rods were also the same length as the wishbones and the tie rods were at the correct height, you would have ZERO bump steer, while the wheels were in the straight ahead position. A longer tie rod would actually CAUSE the bump steer.
How the length of the tie rod affects the bump steer depends on the type of suspension geometry.
Scott Novak
Scott Novak
PostPosted: Tue Jan 27, 2009 3:08 am    Post subject: Reply with quote
I don't suppose that the stock gas tank will fit with this rack and pinion modification, or will it?
Scott Novak
vwairheads
PostPosted: Tue Jan 27, 2009 3:23 am    Post subject: Reply with quote
Scott Novak
I have no idea but you ca always find away to fit Smile but for those people where asking what kind of rack and pinion is it, its from vw polo mk1,2,3 86c, and vw derby. take a look click here http://cgi.ebay.de/LENKGETRIEBE-OHNE-SERVO-VW-POLO...72%3A1229| and this http://cgi.ebay.de/LENKGETRIEBE-VW-POLO-86C-1-1-33...otohosting
vwairheads
PostPosted: Tue Jan 27, 2009 3:30 am    Post subject: Reply with quote
but I think the rack and pinion from a super beetle can be made also Wink
[/img]
Page 1 of 6
