68 Beam end plate dimensions
Split 1
Split 1 is offline
PostPosted: Sat Mar 08, 2008 2:46 pm    Post subject: 68 Beam end plate dimensions Reply with quote
I want to narrow my 68 beam to fit my split has anyone got the dimensions to make some end plates.
Dave
Alaskan Adventurer
Alaskan Adventurer is offline
PostPosted: Sat Mar 08, 2008 4:45 pm    Post subject: Reply with quote
Be carefull using ball joint beam if you plan on slamming it, You will have -caster with droped spindels, it will ride nice but drive bad. their is a cure for the caster, I found out the hard way.. Kevin
63 DC
60 SC daily driver
Split 1
Split 1 is offline
PostPosted: Sat Mar 08, 2008 5:11 pm    Post subject: Reply with quote
I'm not going that low, just a couple of inches.
I want to use the ball joint beam as I am fitting the later discs from a 74, I want small 5 and its cheaper this way to get discs than staying large 5 and having to buy a new disc set up.
Dave
VWsArent4Hippies
VWsArent4Hippies is offline
PostPosted: Sat Mar 08, 2008 6:00 pm    Post subject: Reply with quote
68 beam sideplates have the same bolt pattern as your split.
aeromech wrote:
in my opinion you don't know shit
Split 1
Split 1 is offline
PostPosted: Sat Mar 08, 2008 7:40 pm    Post subject: Reply with quote
Yes I know, thats why I am using it.
I would like some drawings with dimensions of the flat end plates that you can buy so I can make my own narrowed beam
Thanks
Dave
VWsArent4Hippies
PostPosted: Sat Mar 08, 2008 9:00 pm    Post subject: Reply with quote
Via JeremyRockJock
Split 1
Split 1 is offline
PostPosted: Sat Mar 08, 2008 9:20 pm    Post subject: Reply with quote
Thanks for that.
Dave
Split 1
Split 1 is offline
PostPosted: Mon Mar 10, 2008 12:50 am    Post subject: Reply with quote
Has anyone got a clearer picture as I cant make out the dimensions on some of them.
Thanks
Dave
campingbox Premium Member
campingbox is offline
PostPosted: Mon Mar 10, 2008 11:07 am    Post subject: Reply with quote
Thanks
Dave
Click on the photo, it will enlarge it.
Daddybus
Daddybus is offline
PostPosted: Mon Mar 10, 2008 11:38 am    Post subject: Reply with quote
According to the drawing, the lower tube is offset to the front by 1/8". If you are worried about caster, add more offset. The offset lays the top tube back as compared to the bottom tube, thus adding caster. Too little caster and the bus will be squirrelly and unstable at speed. Too much caster and the bus will cruise straight ahead at speed, but will steer like a pig at low speeds (parkinglot manuveres). Somebody on thesamba should've figured out the proper tube offset when using aftermarket side plates to lower a balljoint beam.
Split 1
Split 1 is offline
PostPosted: Mon Mar 10, 2008 5:55 pm    Post subject: Reply with quote
campingbox wrote:
Thanks
Dave
Sorry, I have tried that and still cant make out the measurements properly.
Dave
Mr. Bubblehead
El Chupa Nibre
Mr. Bubblehead is offline
PostPosted: Mon Mar 10, 2008 9:24 pm    Post subject: Reply with quote
Are you going to make them yourself or have them cut? I have a .dxf file for the plates that you can give to your machine shop if they are going to be water jet or laser cut.
BTW, I have found that moving the shock mount back a couple inches from where Jeremy has it works better if you are going real low.
OGST
Samba Member #4862
Hebster52
Hebster52 is offline
PostPosted: Tue Sep 30, 2008 4:57 am    Post subject: Reply with quote
Hmm.. Seems to be missing some essential measurements in the drawing posted above... Very Happy
~Kris~
"The Hebster52" my Hebmuller replica build
The 912ST
The KidVRod project
The 356 Pre-A replica,SOLD
The 1966 Kommanderwagen, SOLD
brettsvw
brettsvw is offline
PostPosted: Tue Sep 30, 2008 2:17 pm    Post subject: Reply with quote
I am fitting the stock 74 calipers and rotors to my linkpin beam with a adapter, the only thing I am missing is a seal that will work.
My 59 kombi build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=635003&highlight=
My buggy build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=558601&highlight=
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807
Hebster52
PostPosted: Tue Oct 07, 2008 11:56 pm    Post subject: Reply with quote
Could someone measure the following measurements on a Baywindow beam that are missing in JeremyRockJocks drawing posted above?
Please? Very Happy
I'm not able to measure those without pulling the beam out of mine and not yet going to pull it either but would be great to get the endplates done...
~Kris~
The 912ST
The KidVRod project
33 Willys
33 Willys is offline
PostPosted: Wed Oct 08, 2008 6:06 am    Post subject: Side plates Reply with quote
I have a template for mine but started to think about the thickness needed. I am leaving the inner original metal and just adding the plate over it. Should I go with 3/8" or is 1/4" enough? Don't forget, it will be welded to existing side plates.
demon1018
demon1018 is offline
PostPosted: Tue Jan 24, 2012 6:08 pm    Post subject: Reply with quote
I would love to have that file. My buddy has a water jet .
Hebster52
PostPosted: Tue Jan 24, 2012 7:52 pm    Post subject: Reply with quote
Here is a link to the final Baywindow endplate pdf that I designed.
Baywindow endplate.pdf
PM me if you want it as .dxf or .dwg. Wink
~Kris~
The 912ST
The KidVRod project
cyarnz
cyarnz is offline
PostPosted: Wed Sep 11, 2013 12:48 am    Post subject: Reply with quote
Ki Krisian.
Can You send me dxf drawings of end plates for bay on email [email protected] ?
THANKS Twisted Evil
lightice
lightice is offline
PostPosted: Sat Aug 26, 2017 12:01 am    Post subject: Re: 68 Beam end plate dimensions Reply with quote
Anyone still have the .dxf or .dwg files available?
Trying to make a pair to fit a narrowed late beam into my split.
