90xjlimited4x4 Samba Member
Posted: Tue May 06, 2008 7:21 pm Post subject: 90xj's baja build |
Last edited by 90xjlimited4x4 on Thu Oct 23, 2008 5:44 pm; edited 11 times in total |
Posted: Thu May 15, 2008 5:03 pm Post subject: |
that point sticking up is the end on the passenger side kicker
made a little progress
what do you guys think?
Last edited by 90xjlimited4x4 on Sun Jun 01, 2008 8:46 pm; edited 1 time in total |
neonrick Samba Member
Joined: February 03, 2006 Posts: 579 Location: Tampa, Florida
Posted: Thu May 15, 2008 6:19 pm Post subject: |
| Lookin' good ... what kind of pipe bender are you using? |
Posted: Fri May 23, 2008 5:30 pm Post subject: |
bought my seats from mckenzies and the seat mount bar.
got a question at this point the seat is on 2x4's for mockup will 1/4 thick flat steel be strong enought to ruin from the tunnel to the bar for my seat mount of should i run tube from the bar to the tunnel to mount the seats on??
Last edited by 90xjlimited4x4 on Sun Jun 01, 2008 8:47 pm; edited 1 time in total |
Skidmark Samba Member
Joined: June 17, 2005 Posts: 2988 Location: Minden, NV
Posted: Fri May 23, 2008 5:39 pm Post subject: |
I would run the tubing fromthe tunnel to the cage, then run the 1/4 flat bar front to rear to mount the seat to... use at least 1-1/2" wide flat bar at 1/4 thick. _________________ "It's not complicated, it's just expensive!"
WARNING! This person has been consumed by the Dark Side.
www.socalbajas.com
http://i135.photobucket.com/albums/q148/bajaskidmark/SCBaja.jpg |
neanders Samba Member
Joined: November 12, 2007 Posts: 1146 Location: Spokane, WA
Posted: Fri May 23, 2008 5:40 pm Post subject: |
I'm planning to run square tubing between the heater channels and the tunnel. I would be concerned about flex in flat stock, even 1/4 inch. _________________ It's mine now and I want a BAJA!!! |
Posted: Fri May 23, 2008 7:05 pm Post subject: |
thats what i thought... my cousin was talking out of his butt but he gave me the flat steel idea.....
thanks guys! |
crisis68 Samba Member
Joined: March 17, 2008 Posts: 199 Location: yucaipa,ca
Posted: Fri May 23, 2008 7:36 pm Post subject: |
I ran tube from the tunnel to my cage, and i just welded tabs for the seats. i didnt use sliders, soooo no one can ask to drive my car unless they can fit into my seating position... also the front of my seat is about 1 in higher than the back, to get rid of the straight up and down sitting position. its just to uncomfortable for me to drive sitting straight up for an extended period of time.. your cars looking pretty good.
Jose |
Posted: Sat May 24, 2008 8:39 pm Post subject: |
4" X 4" 3/16 plate welded to the tunnel
mirror is for welding the bottoms of tubes. (not fun)
took your advise got them fabbed up now i just need some tabs....
Posted: Sun May 25, 2008 9:34 am Post subject: |
looks pretty dang good, I used plates also. tabs are readily available almost anywhere now, and just as easy to make. for 1 or 2 bucs a piece I just bought mine, although I did have to make my front ones because the rake of the seat.
Jose |
towd Samba Member
Posted: Sun May 25, 2008 9:39 am Post subject: |
I run tubes to the tunnel .. then use tabs .. That does help keep the weight down.. BUT
at the doors I have the tube between front and rear hoops lower than you do,, I put the right at the floor ... so welding has to be done it stages,, in order to get a full weld..
then at the tunnel,,, mark where a plate will be to support the end of the seat tubes,, drill holes in the plate,, drill holes in the tunnel ,,, dimple the tunnel holes and weld in large nuts or threaded couplers....
bolt the plate to this and weld in the seat tubes.. this way the cage can be unbolted from the pan
This is more for a Fiberglass buugy,, where you would do a body lift the use that as a Base for the upper cage
I'am dead againest fastening a roll cage to the floor ( pans) if there stock,, there rusted,, if there aftermarket there about as thich as a beer can
I can just picture me upside down,, top smashed to the doors,,,,, the roll cage stick out the bottom and I'am sitting in the car going WFT ??? |
Posted: Sun May 25, 2008 1:01 pm Post subject: |
| crisis68 wrote: |
Jose |
thanks i appricate the complement. this being my first attempt at a baja more lessa full cage car it means alot.
as of right now the seat rake is about 1/2 of a inch! i think im gonna lean it a bit more when i weld the tabs on... |
motorbreath53 Samba Member
Joined: September 08, 2005 Posts: 901 Location: POWAY
Posted: Sun May 25, 2008 1:37 pm Post subject: |
looking cool friend.... I like the cage being pushed as far forward as possible like that.... baja's are small enough inside without a poorly built cage cluttering up the space.... _________________ Shameless buildthread plug:
..."cut n' turn in progress"... |
Posted: Sun May 25, 2008 7:30 pm Post subject: |
ok so im starting to plan the suspension....
im going to pick up a irs bus trans next week and i want to go 3x3's in the rear with some wider arms up front im gonna be running a 12inch fox res in the rear and a 10in fox res in the front (got two of the shocks already from a previos project)
i need some opinions on rear arms, axles, ect... hopefully a complete kit please keep in mind i want to keep stock style suspension. and what type of arms for the front want something around 2.5 inches wider perside....
im gonna have Big Bob make me a fuel cell for the bug something around 16 gallon with a fuel sender....
any and all opinions are greatly appricated this is my first bug build and i have the general idea of what im doing, but i know i have experts on this website that can save me the trouble of doing this twice!
thanks
Chad |
Posted: Tue May 27, 2008 6:31 pm Post subject: |
got the tabs mounted up so the seats are finished.... untill i get my seat belts then i can run the seat belt bar behind the seats. nows the time to start running tubes forward to the front.
i have been tossing up the idea of moving the front axel tube forward to extend the wheel base about 3inches any advantages? is it worth the effort?
also no ideas on suspension besides going to mckenzie's and piece by pieceing it? |
Posted: Tue May 27, 2008 6:42 pm Post subject: |
| Skidmark wrote: |
Looks like we will have a lot to talk about tomorrow night....  |
are you planning on bring the bug with you? |
Posted: Tue May 27, 2008 6:57 pm Post subject: |
| Skidmark wrote: |
| Of course! Why come to a baja meet without your baja (if it's drivable)? |
sweet im hopeing i get atleast 10 to gock at! give me a goal for when im done im hopeing to make this a 6month or less build.... |
