GregEdgar Samba Member
Joined: October 27, 2005 Posts: 121 Location: Yakima,Washington
Posted: Tue Jun 17, 2008 10:23 am Post subject: still having fuel gauge problems! |
i replaced the sending unit, and still no sign of fuel in the tank. could the fuel gauge not work properly without the right fuse. my dad was telling me it could be the wrong fuse in the fusebox? im just not sure.
so ive replaced the sending unit. and i dont know what to check for now. please help. any suggestions?
thanks,
Greg |
QUADRADO Samba Member
Joined: August 10, 2005 Posts: 135 Location: 91sickness
Posted: Tue Jun 17, 2008 1:04 pm Post subject: |
check your grounds near the tank. _________________ "Sometimes you're the bug sometimes you're the windshield" |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35919 Location: Conejo Valley, CA
Posted: Tue Jun 17, 2008 1:08 pm Post subject: |
Ground the wire at the sending unit using a jumper wire to a good chassis ground. The gauge should read full. If it does, check the grounding of the sender, and suspect the new sender is brokewn or the wrong one. If the gauge doesn't read full when grounded, suspect the gauge, the wire, or the gauge cluster wiring. |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4659 Location: Oklahoma City, OK
Posted: Tue Jun 17, 2008 1:13 pm Post subject: |
Also verify you have power at the gauge |
COFBack Samba Member
Joined: July 05, 2005 Posts: 2148 Location: Colorado Springs
Posted: Wed Jun 18, 2008 6:49 pm Post subject: |
check the procupine ground behind the gauge.
Clean up all the terminals and use some dielectric grease
then
check the terminals on the gauge. _________________
iowegian wrote: |
Henceforth he shall be known as "Trameltoe".
Chickengeorge's wife wrote: |
bing chow ching fong fang T.J. fang ching dow fong |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Thu Jun 19, 2008 8:26 am Post subject: |
The screws that hold the sender in the tank have seals on them. They are a plastic seal, except for one. It is supposed to be a copper washer. For ground. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
spoon Samba Penetrator
Joined: September 08, 2005 Posts: 1458 Location: Monterey, CA
Posted: Fri Oct 10, 2008 1:48 pm Post subject: |
I need to bring this up again. My gage is reading about 1/4 tank LOWER than what's really in there. Is this a gage issue? In the meantime, I will go and try jumping the wire at the sender to ground, and will observe my gage's reading while doing so. _________________ Pit Bull Myths, Busted!
http://www.badrap.org/monster-myths
EverettB wrote: |
Type 3 > Type 1 |
abgwin Samba Member
Joined: August 22, 2004 Posts: 1490 Location: Toledo, oHIo
Posted: Fri Oct 10, 2008 4:32 pm Post subject: |
and not to hijack, but on a sort of related note: my gas gauge is my next project too. it currently just jumps a bit when the car starts, but nothing more.
on other 6v to 12v conversion threads, some people say you have to swap out the gas gauge and some say you don't. do you?
since i don't have the luxury of a handy 12v gauge, will a voltage drop work?
sorry if i'm being dense, but electrical stuff makes no sense to me - just does not compute |
tstracy39 Samba Member
Joined: May 14, 2008 Posts: 3295 Location: Seattle, WA
Posted: Fri Oct 10, 2008 10:34 pm Post subject: |
The fuel gauge is sensitive to fluctuations in voltage, so when the engine is starting up and the generator isn't spinning at the proper rpm the needle can jump around. On my car it would even read Empty whenever the engine was turning less than 1000 RPM but whenever I opened the throttle it would read the actual fuel level, though I'm sure it's not supposed to do that. _________________ Check my classifieds for kewl gauges:
http://www.thesamba.com/vw/classifieds/search.php?username=tstracy39
EverettB wrote: |
I like your fork. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18046 Location: Eugene, OR
Posted: Fri Oct 10, 2008 11:18 pm Post subject: |
The fuel gauge on our 69 read about 1/4 tank MORE when we got it. We'd run out of gas when it showed 1/4 tank! We robbed the sender out of the 67 after Jack had wrecked it and the 69 reads real accurate now! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
ggreenggiant Samba Member
Posted: Mon Jan 13, 2020 9:12 pm Post subject: Re: still having fuel gauge problems! |
Where are the grounds to the tank? I am also having issues with my tank reading anything. I replaced the sending unit and even went direct from tank to back of gauge to make sure to eliminate the wire being broke. Can I get some help on where to check the ground? |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13948 Location: White Mountains Arizona
Posted: Tue Jan 14, 2020 7:26 am Post subject: Re: still having fuel gauge problems! |
What I had to do was to run a wire from ground to one of the screws on the tank sending unit. Works fine. My gauge does read weird but it does let me know when it gets near the R on the gauge.
When I fill the tank it takes about 90 miles for it to move off of full mark. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23394 Location: Kimball, Mi
Posted: Tue Jan 14, 2020 2:16 pm Post subject: Re: still having fuel gauge problems! |
gt1953 wrote: |
When I fill the tank it takes about 90 miles for it to move off of full mark. |
Yup, that seems to be a common fix (adding a separate ground wire off 1 of the sensor screws). Supposedly, the 3 bolts with washers that hold the tank in place are the ground for the sending unit (fuel tank ground). If you painted the tank, you might have too much on to get a good ground. So look that edge over real good, and maybe even scrape some paint off. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
blues90 Samba Member
Joined: March 14, 2009 Posts: 1912 Location: Hollywood ,CA
Posted: Fri Jan 17, 2020 4:23 pm Post subject: Re: still having fuel gauge problems! |
My fuel gauge has always had issues since I got it. I'm not sure if earlier model year gauges are different I know the senders are the same.
Mine always jumped when it got near 1/4 tank and when the tank was full it would read a bit past full. I removed the sender once to see that might be wrong, Then I used to long jumper wires one to ground and one to the gauge to sender and had the round cover tube off and slowly moved the float and it read perfect , couldn't get it to jump it still read a bit over full.
Once I put the sender back in it did the same thing jumped. I have two gauges a 72 and 73 both complete in their housings with all the other lights.
There are stops on each side of the needle so you can set where the needle stops they are small L shaped tabs. I could see the 73 stop allowed the needle to pass full.
In 2015 when it was hit on the right front bumper guard by a red light runner it does not go to past full any more. I tried the ground on the sender deal didn't work. I added a ground to the gauge even though one exits on the bakelite black plug yet it had a loose connection so I used a good spare I had cleaned all the three contact pins and didn't change a thing. At one point used to jump if the 4 ways were on.
I pulled in the 72 and it did the same thing jumping. I checked the wire from the sender disconnected to the pin it connects to on the gauge and read 44 ohms I cleaned the tab on the sender and the 1/4" female connector no change . I was going to run a new wire and never did thinking this would affect the reading and possible make it jump.
After the accident it jumps no matter how much fuel is in the tank more so above the 1/2 tank and below.
Some day I will fix it , for now when it is steady near the red I know I need gas meaning it stops jumping. Maybe the jolt knocked the tube cover off and this is why is moves on turns then comes back. I don't see how the jolt could yet it may have.
Why VW didn't it different on the type 3 than on a beetle I have no idea. Old american car/trucks have a float and a voltage regulator , all fuel tanks slosh fuel never had a problem unless the float went bad and sunk of the reostat on the sender went bad or the VR. They just got a pulse voltage. |
gt1953 Samba Member
Posted: Fri Jan 17, 2020 5:28 pm Post subject: Re: still having fuel gauge problems! |
Oh My. Fuel sending unit issues.
Have you disassembled the unit. If not be careful. It is a simple float that slides up and down on two small wires. Be careful with those.
What I had to do with mine was to clean the wires and small electrical contacts that contact the wires on the float that slides up and down.
Took care of the problem and ground it good.
Jim Adney repairs them. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Fri Jan 17, 2020 7:30 pm Post subject: Re: still having fuel gauge problems! |
gt1953 wrote: |
Jim Adney repairs them. |
Sure have , had it apart a few times and know what the float and it's contacts and the 2 thin wires. Last I cleaned them was in 91. Combined they change resistance across the wires that the gauge reads. |
Posted: Sat Jan 18, 2020 10:17 am Post subject: Re: still having fuel gauge problems! |
gt1953 wrote: |
Yes, Jim repairs them. He even has the correct wire in case you broke one or both. Although he would prefer you to send your unit to him for repair work. I believe he even has a jig set up for them. He took a long time finding the right wire to use for the sending units as well.
On my own unit, I had to re-stake the ground connection in the sender to get it to work, as the rivet had come loose. This took care of the jumping needle too. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
gheezerghia Samba Member
Posted: Sun Feb 13, 2022 10:17 pm Post subject: Re: still having fuel gauge problems! |
Bobnotch, Do you have Jims info so I can send him my fuel gauge if I need to? Thanks man! |
Ossipon Samba Member
Posted: Mon Feb 14, 2022 11:06 am Post subject: Re: still having fuel gauge problems! |
gheezerghia wrote: |
He is listed here under his services ad
https://www.thesamba.com/vw/classifieds/detail.php?id=1807851
I had my Master Cylinder rebuild done by him. Great Service and reasonable prices. _________________ Ossipon
--Two truths in life: Volkswagens Rust and everything will die at some point --
VWs in my life:
Air
Type 1 - 59, 62, 63, 71 Super 68 KGhia/ Type 2 - 59 Single Cab / Type 3 - 64 Notch
Water
GTI 83, Jetta 81, 85, 87, 91 TDI, 98 TDI, 09 / New Beetle 99 / SportWagen 05, 13 / Tiguan 18 / T3 92 /Taos 24... And don't about me and my experiences with my Dasher and Quantum |
