Coolant bleeding joy.
240Gordy
240Gordy is offline
PostPosted: Fri Apr 17, 2009 11:24 am    Post subject: Coolant bleeding joy. Reply with quote
Gentlemen, I give you the Moroso coolant bleeding valve,
you must push the button to bleed. Only do this while engine is cold.
Tencentlife said,
"So, now that you know what you're doing, go to town."
2010 GOLF TRENDLINE 2.5
1985 GL now with more! a 2.1L
H&R SPORT(RED) Springs FRONT , SLAM SPECIALTIES RE6 AIRBAGS REAR
danfromsyr
danfromsyr is offline
PostPosted: Fri Apr 17, 2009 11:41 am    Post subject: Re: Coolant bleeding joy. Reply with quote
SURE you give us the Image and a ahint, but you didn't really give us the valve.. one problem is it is 1/8NPT and the front rad screw is a fine thread metric.
What I did was to hook a CIS injection Banjo fitting to that screw then to a small hose with a lever/swing valve in it with a drain hose down towards the ground/spare tire.. I put that into a bucket and open the valve to burb the coolant. but I also use a Garden pump Sprayer to pressurize and charge the system to get the coolant & air moving.. you can have this hooked up while the engine is running to no ill effect..
Morosso wrote:
Here's the Link: Morosso Air Bleed valve
Bleeds air from any cooling system
Resistant to fuels, oil and anti-freeze
Brass construction with push button to release pressure
Fits 1/8" NPT thread
Abscate wrote:
240Gordy
240Gordy is offline
PostPosted: Fri Apr 17, 2009 12:22 pm    Post subject: Re: Coolant bleeding joy. Reply with quote
I figured guys would be able to find it and put two and two together.
doesn't that create a siphon effect and suck out more than you need to?
Tencentlife said,
danfromsyr
PostPosted: Fri Apr 17, 2009 1:00 pm    Post subject: Reply with quote
well I guess my method is more of a flush then a burp..
as I've got incoming fluid from the spray bottle. and if there's air up there it burps with the flush.. only less then a pint anyways..
if I just had the banjo fitting and a short hose to a swing valve.. then it'd burb butmake more of a mess.
like you, I'm just offering out ideas on what may or may not make sense to the rest of the class.
both are nice ideas.. but yours won't thread into the rad.. nor the cooling loop without modification..
there are also 1/8NPT Radiator bleed vlaves that are a twist type.. but same thread issue.
I do like this valve.. and will keep it in mind.
Dan in NY
Abscate wrote:
240Gordy
240Gordy is offline
PostPosted: Fri Apr 17, 2009 2:23 pm    Post subject: Reply with quote
cool, what does a CIS injection Banjo fitting look like?
(seriously I have no idea)
Tencentlife said,
jimbelmont
jimbelmont is offline
PostPosted: Fri Apr 17, 2009 3:20 pm    Post subject: Re: Coolant bleeding joy. Reply with quote
Would you happen to know the metric thread size?
levi
levi is offline
PostPosted: Fri Apr 17, 2009 4:24 pm    Post subject: Re: Coolant bleeding joy. Reply with quote
Why do it when the engine's cold? You're just going to suck in air that way.
One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40
240Gordy
240Gordy is offline
PostPosted: Fri Apr 17, 2009 4:42 pm    Post subject: Re: Coolant bleeding joy. Reply with quote
CUZ you must push the button down manually. so maybe this thing is not that great but I think there was another reason to do it cold. if you use a Libby bong that will stand up on its own you can run around and push the button to let the air out you don't have to run the engine or try to thread the bleeder bolt with coolant gushing out.
Tencentlife said,
tencentlife
tencentlife is offline
PostPosted: Fri Apr 17, 2009 6:08 pm    Post subject: Re: Coolant bleeding joy. Reply with quote
Mine is M8 x 1.25.
Coarse in that size, actually. Fine is 1.0. At M10 fine becomes 1.25, coarse 1.5.
I like Dan's banjo fitting idea. Nice to control the fluid instead of dribbling it all over the place.
Are some of the rads fine thread? Aren't CIS banjo bolts fine?
I made this up awhile ago:
Bad pic but you get the idea. Works nice; you don't have to manage rethreading the bolt while fluid is spewing out. I wanted to make up a bunch and give them away, but haven't found the right length bolt in SS in small pkgs. Can't see going to the trouble to make them in plated.
At birth you only know how to suck. Spend the rest your life learning how not to.
danfromsyr
PostPosted: Fri Apr 17, 2009 9:23 pm    Post subject: Reply with quote
*winks
Google links
Abscate wrote:
Wildthings
Wildthings is offline
PostPosted: Fri Apr 17, 2009 9:43 pm    Post subject: Reply with quote
Maybe I am missing something, but I have always found bleeding either the 1.9 or 2.1 Vanagons to be very easy. No special toys needed. It seems to me that people fear the bleeding process so badly they end up making it many times harder than it really is.
240Gordy
240Gordy is offline
PostPosted: Fri Apr 17, 2009 10:43 pm    Post subject: Reply with quote
danfromsyr wrote:
*winks
Google links
so what tencent made?
Tencentlife said,
tencentlife
PostPosted: Sat Apr 18, 2009 7:29 am    Post subject: Reply with quote
Maybe you are missing something, then: that this is one of the rare cooling system bleeding threads where no one said anything about it being hard. These are just creative ideas to make it a little more convenient, and/or less messy.
I like them all. I think Gordy's is cool, too bad it's the wrong size.
But since you don't like special toys, just straight-up old school for WT, if I do get around to handing out bleeder bolts, I guess you'll want me to cross your name off the list.
dobryan Premium Member
dobryan is offline
PostPosted: Sat Apr 18, 2009 8:22 am    Post subject: Reply with quote
You can also take a dremel cutoff wheel and make a vertical slot in the threads for the bottom 2/3 of the bolt. That way when you unscrew the bleeder bolt a few turns you expose the slot and let the air out without having to remove the entire bolt. Same idea as drilling a hole but was easier for me to produce. Both ideas work great. Very Happy
Dave O
Traveling after Building a bus for travel in Europe (euroBus)
The Western Syncro build
tencentlife
PostPosted: Sat Apr 18, 2009 8:26 am    Post subject: Reply with quote
Yup, that works, too. It's just that I got a lathe and like to play.
msinabottle
msinabottle is offline
PostPosted: Tue Apr 28, 2009 3:40 pm    Post subject: Keep at it, Chris! Reply with quote
Keep at it, Chris, your modified bolt would be a great improvement on the stock bleeder bolt.
I wonder if that banjo bolt rig could have some soft of valve on that. Moroso expects you to drill a hole in your radiator, I think they'd do better with a series of threaded collar adapters for the valve body. But I suppose a lot of the old iron to which they cater doesn't have a bleed screw at all.
Best!
'Winston,' '84 1.9 WBX Westy
many ways, but never, never, never in silence."
