Electrical Gremlin with ignition
madmike
madmike is offline
PostPosted: Thu May 21, 2009 4:59 am    Post subject: Electrical Gremlin with ignition Reply with quote
Before I get under the Dashboard of my Laser917 "again" I'll ask you guys what do you think?? I'm driving along and the thing runs great,then it just shuts off ?? the alt lite comes on and the elec. oil pressure gage drops to zero,I switch off the universal keyed switch untill the alt lite is off and it starts right back up Shocked every time. then the other day I went to start it and the starter stayed engaged even with the key out Shocked WTF??? I'm thinking the Ing. switch or the starter sylinoid "Opinions please" Thanks in advance Embarassed ,Madmike
'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
"If I'm ever on Life Support,UNPLUG Me, Then Plug me back In see if that Works"
Marv [UK]
Marv [UK] is offline
PostPosted: Thu May 21, 2009 5:47 am    Post subject: Reply with quote
WTF is a laser 917?
Anyway.... sounds like a problem one of my old colleagues had with a GM motor once... Alternator was on it's way out and when the charge dropped below a certain voltage, everything shut down to prevent damage.
No idea if this is anything like what you are having to deal with but thought it might be relevant Smile
ALB
ALB is offline
PostPosted: Thu May 21, 2009 6:46 am    Post subject: Reply with quote
Marv- It's a swoopy, futuristic looking kit car from the 70's.
On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!!
PostPosted: Thu May 21, 2009 9:42 am    Post subject: Reply with quote
Sounds like a bad ignition switch.
Towel Rail
Horizontally Opposed
Towel Rail is offline
PostPosted: Thu May 21, 2009 10:03 am    Post subject: Reply with quote
Yep, it's a smaller-scale fiberglass kit car based on the Porsche 917.
Real:
Laser 917:
A Laser was featured in "Herbie Goes to Monte Carlo", btw:
Not that any of this helps with the ignition problem! Laughing
- Scott
1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009
Letterman7
Letterman7 is offline
PostPosted: Thu May 21, 2009 11:51 am    Post subject: Reply with quote
Actually, sounds like you've got two different situations going on. The car suddenly shutting off sounds like it's either dropping a ground to the coil or power to the coil. Check all your lines from the ignition to the coil, and all your ground lines. A loose ground line can ruin your whole day. Same deal with the starter staying engaged, though that's more likely a sticking Bendix in the starter itself (or sticking solenoid).
Tram
Samba Socialist
Tram is offline
PostPosted: Thu May 21, 2009 12:13 pm    Post subject: Reply with quote
X2.
Bryan67 wrote:
Those who can- do.
Those who can't? Subaru.
