Brintonian Samba Member
Posted: Sat Aug 29, 2009 1:11 am Post subject: stripped case at oil pressure switch |
I just loaded up my 76 type 4 for it's maiden voyage across the country and I'd noticed some oil around the oil pressure switch. I started to tighten it down gently and it seemed really loose. It kept twisting so I backed it out and the case threads came out with it.
So I'd like to know what I need to do to tap it... Does the engine have to come out for this? Should I tap it for the next larger fitting and run a tube to the switch? I'm panicking. If anyone has any info I will be eternally grateful!!!
Thank you thank you thank you in advance!
Beej  |
ccpalmer Samba Member
Joined: September 17, 2006 Posts: 3851 Location: Ann Arbor, Michigan
Posted: Sat Aug 29, 2009 7:41 am Post subject: |
You should be able to tap the next largest non-metric size (I think 1/4" NPT?), then put a nipple into the case, then a coupler from the nipple to the sender unit - the threads should go in well enough with teflon tape.
After you tap the threads crank the engine a few times (with the coil wire off) and oil will push out any shavings that get in. I've also heard of putting grease on the tap to catch most of the shavings. _________________ '71 Westy |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52747 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Aug 29, 2009 7:56 am Post subject: |
Hooooboy...... you've stepped in a big steaming pile with this one
Engine disassembly is the ideal fix but there are work arounds if you are super careful.
If you can remove the fan shroud and oil cooler you can wash out any chips that may fall down the hole.
Or the panic ghetto fix works if you just don't have the time:
The first thing you'll have to do is fill the hole with grease, from there you have to decide what threads you want in there, they are (were) 10X1.0mm but most extensions for aftermarket pressure gauge senders are 1/8" NPT. There's a chance the tapered NPT tap can make threads in the existing hole slightly deeper but the guaranteed first shot fix would be to go to the bigger 1/4 NPT and install an adaptor back down to 1/8 or 10mm if you aren't going with a pressure gauge (a good upgrade though).
Now that the tapping is done you have to get that chip laden grease out of there, a small hose attached to a shop vac or a syringe or turkey baster should do it, a bit of grease residue left behind won't hurt anything but the chips are not good. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Aug 29, 2009 8:13 am Post subject: |
Genius . Thanks guys I'll let you know how it goes. I owe you one!!!!
Beej |
Posted: Sat Aug 29, 2009 8:42 am Post subject: |
Oh - I didn't see at first that it was a T4...
Busdaddy of course has it right that the best fix is to disassemble the engine...
But I did the quick fix to my 1600dp and it worked fine - it was a 1/8"NPT I used and is pretty much the same size as 10X1.0mm... _________________ '71 Westy |
Posted: Sat Aug 29, 2009 12:56 pm Post subject: |
I tapped with a 1/8" and installed my VDO sender which I hadn't gotten around to yet. The grease worked perfectly. I made a little rig with some 1/4" tube to suck it back up with my shop vac and then combed through the residual with a cue tip. So far no leaks!
Thanks again guys!!! |
ncstagger Samba Member
Joined: June 04, 2010 Posts: 284 Location: Fayetteville, NC
Posted: Mon Feb 18, 2013 5:00 pm Post subject: |
So I installed the first non-stock item on my engine today and of course it ended in disaster.
I removed my stock oil pressure sender and installed a new 10mm dual pole VDO sender. In the process, I overtightened and stripped the case, the threads came out when I removed the new sender.
What's the options here? I'd like to use the VDO sender so I'll need the threads back to 10mm. Do I need to drill and tap a size larger and then install a 10mm insert? If so, what size drill and tap?
Or can I use a 1/8" tap to cut new threads and hope the 10mm sender goes in and seals with a little teflon? Sounds sketchy. Maybe an adapter?
Open to advice. Thanks.
Its a Type I engine and its out of the bus but fully assembled. _________________ 71 Westy Tintop - 1600 DP 34PICT3/009 - Pastel White
Resto thread here: http://www.thesamba.com/vw/forum/viewtopic.php?t=549162
"Take your most realistic time frame and dollar amount.. then add half of that amount. When you get that total... double it. Only then will you be in the ballpark." - sofaking |
Posted: Mon Feb 18, 2013 5:52 pm Post subject: |
Fill the hole with grease and drill/retap larger so you can use a reducer fitting (drill size charts for various taps are everywhere online), 1/8"NPT is so close to 10mmX1.0mm that you won't gain anything by retapping to that size. I think you'll have to go up to 1/4" NPT and find a suitable reducer/adaptor. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 4090 Location: Seattle, WA
Posted: Mon Feb 18, 2013 5:54 pm Post subject: |
Thread inserts work pretty well. Timeserts are well-regarded for fixing stripped threads.
Lots of other brands too. Timesert supposedly has a M10x1.0x8mm insert that would
probably work well.
1/8 NPT should NEVER be mixed with M10x1.0 unless you don't care about borking the threads. _________________ '67 bug: seized by the authorities
Posted: Mon Feb 18, 2013 6:12 pm Post subject: |
A full solid insert could work with enough sealer but I wouldn't even attempt getting a coiled thread repair like a Helicoil to seal against oil pressure. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Feb 18, 2013 6:43 pm Post subject: |
I wouldn't use a Helicoil, heard too many negative reports.
aircooled.net has a loaner 1/8 npt timesert kit. I could do that and use this adapter to get back to 10mm,
http://pitstopusa.com/i-5064685-auto-meter-metric-adapter-1-8-npt-to-10mm-x-1.html.
Sucks to have to take half the parts off the engine again to do this but I dont see an option thats both easy and good. _________________ 71 Westy Tintop - 1600 DP 34PICT3/009 - Pastel White
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42441 Location: at the beach
Posted: Mon Feb 18, 2013 9:30 pm Post subject: |
Heli-coils work well but not for the application you are working on. Don't even think about it. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Mon Feb 18, 2013 9:41 pm Post subject: |
You might be able to tap it to a straight thread, like 7/16" and then use an adapter to go to 10x1 or whatever you need. I would not screw a heavy dual sender into the stock location even if everything where A-1. Mount the sender elsewhere and use a section of hydraulic hose to connect it. |
SGKent  Samba Member
Posted: Mon Feb 18, 2013 9:55 pm Post subject: |
Wildthings wrote: |
X2 _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Danwvw Samba Member
Joined: July 31, 2012 Posts: 8895 Location: Oregon Coast
Posted: Mon Feb 18, 2013 10:03 pm Post subject: |
I would try JB Weld and avoid the metal shavings until you rebuild. You will need to clean it up good though. Use paint thiner followed by Carburetor Cleaner in spray can or even brake cleaner. Give it a good 24 hours to set. JB weld is a 5 minute epoxy but they also make a 4 hour version that is stronger but should dry longer. It is so strong the 5 minute would be fine if you can get all the oil out of the joint you make. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Desertbusman Samba Member
Posted: Mon Feb 18, 2013 11:12 pm Post subject: |
Nothing at all wrong with the VooDoo dual post sender in the stock location on a t-1. _________________ 71 Superbug
71 Westy |
Posted: Tue Feb 19, 2013 1:10 am Post subject: |
Desertbusman wrote: |
Nothing at all wrong with the VooDoo dual post sender in the stock location on a t-1. |
I don't find either aluminium or magnesium to be great substances to thread heavy senders into. |
Posted: Tue Feb 19, 2013 6:16 am Post subject: |
Wildthings wrote: |
This is a good thought. I really dont like the idea of having an adapter and the big sender both hanging from the case. This way I could have all of that supported elsewhere on a mount in the compartment. _________________ 71 Westy Tintop - 1600 DP 34PICT3/009 - Pastel White
Posted: Tue Feb 19, 2013 6:20 am Post subject: |
Danwvw wrote: |
I would try JB Weld and avoid the metal shavings until you rebuild. You will need to clean it up good though. Use paint thiner followed by Carburetor Cleaner in spray can or even brake cleaner. Give it a good 24 hours to set. JB weld is a 5 minute epoxy but they also make a 4 hour version that is stronger but should dry longer. It is so strong the 5 minute would be fine if you can get all the oil out of the joint you make. |
Are you talking about cold welding the sender into the case? That might work but would make it permanent until rebuild. Not sure I want to do that. Would the JB Weld still give a good ground? _________________ 71 Westy Tintop - 1600 DP 34PICT3/009 - Pastel White
Danwvw Samba Member
Posted: Tue Feb 19, 2013 3:37 pm Post subject: |
JB weld is just epoxy but I have used it for things like VW type 1 Dowel Pin hole repair and on water cooled engines plastic radiators to hold temperature sensor in where it was stripped out. Have been thinking of using it around my main bearings on my next engine.
I suppose there is a chance you would loose sensor ground with the VW Type 1,2,3,4 applications but if part of the old metal thread is still there then you will likely have a ground. Just have to try it. I would use a lot and build it up quite a bit even going back and re-applying more after the first batch hardens. http://www.jbweld.com/product/j-b-weld/ _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
