Engine compartment pillows . . . again
gerg
a.k.a. 6volt65
gerg is offline
PostPosted: Thu Oct 15, 2009 6:16 am    Post subject: Engine compartment pillows . . . again Reply with quote
I have the original set of pillows for my '65 that I need to reinstall before my tar boards get placed. I cannot remember how far they actually go though.
I am looking at this picture and have a few questions . . .
1) The TOP picture is not the same as the triangular pillows that the car had, but an additional piece of foam for extra noise / dust control?
2) The lower picture looks like the pillow I have - is that where it goes, I mean, that is as far up?
I tried cramming it way up the C pillar and it was a disaster. I thought it went way up in there, but the lower picture looks more likely.
Thoughts?
Thanks!
Gerg
. . . I got 99 problems and my bus ain't one . . .
'65 Sunroof Beetle
'65 Vert
'60 Singlecab
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger Gallery Classifieds Feedback
usrname
usrname is offline
PostPosted: Thu Oct 15, 2009 8:08 am    Post subject: Reply with quote
That bottom picture looks like the case with my '62. I can see the bottoms of 'em from inside the engine compartment.
gerg
a.k.a. 6volt65
gerg is offline
PostPosted: Thu Oct 15, 2009 8:42 am    Post subject: Reply with quote
Cool, thanks!
I just don't remember taking them out, and presumed they were 'way up in there' . . . .LOL
Gerg
'65 Sunroof Beetle
'65 Vert
'60 Singlecab
BWD
Samba Mailman
BWD is offline
PostPosted: Thu Oct 15, 2009 4:58 pm    Post subject: Reply with quote
They're stuffed up high in my 66.
BWD
JHC
member #2850
1966 Beetle
_____________________________
tasb
The Distributor Distributor
tasb is offline
PostPosted: Thu Oct 15, 2009 7:06 pm    Post subject: Reply with quote
Probably depends upon wether your car was made on a Monday at 7am or a Friday at 5pm or some other day/time duriing the week Razz
Roads Scholar
Member# 2059
usrname
usrname is offline
PostPosted: Thu Oct 15, 2009 7:39 pm    Post subject: Reply with quote
I'm convinced the top picture is actually a drawing of the pillows. That's why they don't look like real triangles. I can understand how it would be hard to draw, realistically, an image of a puffy, folded triangle object. The bottom picture is, I think, the real deal.
Culito
11010101
Culito is offline
PostPosted: Wed Feb 16, 2011 4:12 pm    Post subject: Reply with quote
New question.
Is there any sort of alternative to the pillows that won't hold moisture? I'm not worried about overall correctness, just keeping fumes and noise out of the cabin.
I know spray foam is a sin, but I have a fresh can in the basement...
© CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
KTPhil Premium Member
KTPhil is offline
PostPosted: Wed Feb 16, 2011 4:18 pm    Post subject: Reply with quote
Open cell foam wrapped in a porous cloth.
Arnolds64
Arnolds64 is offline
PostPosted: Wed Feb 16, 2011 4:25 pm    Post subject: Foam? Reply with quote
So that is what came falling out recently. All brown and crusty. I wondered what the hell it was? LOL! Rot I guess. What is it for, Noise?
64 Bug, White, 2017, Dual Weber 44's, Engle 130/Engle lifters, Home P&P'd 40X35 heads, CB 4340 nitrided crank, Eagle knock off H Beam 5.5" rods, Lowering Beam, Rancho Trans, Traction Bar. 225X60's rear, 145's front on Porsche Chrome Nipple Wheels.
Arnolds64
KTPhil is offline
PostPosted: Wed Feb 16, 2011 4:27 pm    Post subject: Reply with quote
61SNRF
61SNRF is offline
PostPosted: Wed Feb 16, 2011 6:42 pm    Post subject: Reply with quote
In general it's not the dreaded foam that is at fault, it's the condensation from inside the roof that runs down and collects wherever there is a dam, be it foam or pillow. I've noticed it's a big problem here in California due to the hot days and cold nights. Pillows probably allow more water to drain off and dry up quicker though.
If i were doing a total ground up, I would consider applying Dynamat or some other self stick insulation on the inside of the roof itself. I believe if it were insulated better, there would be less condensation forming and running down. Same reason they wrap ducts and such in homes, to prevent condensation forming on the exterior. If the roof were insulated, you could safely spray expanding foam in the void for a much better sound and fume isolation.
-Bruce
An ounce of prevention is worth a pound of cure.
Culito
11010101
Culito is offline
PostPosted: Wed Feb 16, 2011 7:26 pm    Post subject: Reply with quote
Well, I don't have a headliner or plan on doing anything to the inside of the roof in general. It has a nice trippy spray-glue pattern.
It seems like pretty much anything is going to trap moisture at some point. Maybe I could just make some block off panels for the sides of the engine compartment, with a tiny drain at the bottom?
'62 bug
johnnypan wrote:
64caldub
64caldub is offline
PostPosted: Wed Mar 02, 2011 8:32 pm    Post subject: Reply with quote
On my 64 some one said they cause rust and it appears that if you look close its started not to big a deal cause I was planning on striping down to metal and repainting it (after treating it in rust smort) so what I want to know is are do I need them?
DaveOBrien
DaveOBrien is offline
PostPosted: Thu Mar 03, 2011 7:44 am    Post subject: Reply with quote
The OP scans appear to be from 58'-59' according to the chassis #'s.
It looks like there was a secondary pillow stuffed deeper up the channel. Has any one found a second inner pillow? Curious.
I have been progressively quieting down my 64' and last weekend discovered a missing pillow. I stuffed a rag up there for the short term and the difference was amazing!
It also cleaned up the cabin air which I thought was from ill fitting heater tube connectors.
edit: I found this post also shows loose fill inside with the pillows to seal or plug the bottom. What material would you use today? http://www.thesamba.com/vw/forum/viewtopic.php?t=448813&highlight=pillows
Dave
roadkingdoc
roadkingdoc is offline
PostPosted: Thu Mar 03, 2011 8:26 am    Post subject: Reply with quote
i am thinking of using bubble wrap in some nylon? any thoughts?
EODinert
EODinert is offline
PostPosted: Thu Mar 03, 2011 12:37 pm    Post subject: Re: Foam? Reply with quote
If you have a car with oil containment issues, and you don't have the pillows, smoke can fill the cabin, and a light coat of oil can get on things, especially if your dome light is not installed Smile
'61 rag top beetle, '73 type 181, '66 13 window deluxe
tb03830
tb03830 is offline
PostPosted: Thu Mar 03, 2011 2:36 pm    Post subject: Reply with quote
Do verts have these? I have not seen any and there is not much distance.
"Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
1964 Convertible Bug - 1600cc SP engine with a stock H30/31 Carb and SVDA Distributor - Swing Arm Highway Flyer Tranny, Gene Berg's Temperature Dipstick, 2.5" drop spindles, 2" narrowed adjustable front end. Chromed OEM fan tower.
Bart Dunn
Samba Consiglieri
Bart Dunn is offline
PostPosted: Thu Mar 03, 2011 3:07 pm    Post subject: Reply with quote
KTPhil wrote:
I've seen that pillow before.
Not enough car seats fit into my:
'58 Beetle convertible
'58 Beetle sedan
stale air
stale air is offline
PostPosted: Thu Mar 03, 2011 3:48 pm    Post subject: Reply with quote
Terry, aka Agave58 posted this pic over on the 58/59 thread. I thought I would post it here. In the backround on the right side you can see a huge box full of pillows waiting to be installed on the assemble line.
