ragnarhairybreeks Samba Member
Joined: October 26, 2009 Posts: 1945 Location: Sidney B.C. Canada
Posted: Tue Dec 08, 2009 11:13 pm Post subject: Call for Webasto BBW 46 info and experiences |
Hi,
Starting to attempt to get my Webasto BBW 46 coolant heater up and running. Yeah, I know, it may well be a dead horse
Anyway, I've started to post info on my blog (http://shufti.wordpress.com/). So far I have linked to Gary Lee's pics and install manual, a parts manual, and an excerpt from the German VW repair manual that actually has the scoop on the Vanagon install.
There were some posts on the UK Brickyard site, I'll link to them too.
If anyone out there has any more info please post.
thanks
Alistair _________________ '86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com |
otiswesty Samba Member
Joined: November 21, 2006 Posts: 1779 Location: Portland
Posted: Wed Dec 01, 2010 10:52 pm Post subject: |
The Bentley has a long writeup on the BBW46, check it out.
Also,
http://www.techwebasto.com/heater_archive.htm _________________ 1978 Sage Green P22 Westfalia
1988 T3 Syncro Single cab
Just a regular guy |
goskiracer Samba Member
Joined: January 15, 2009 Posts: 339 Location: Oslo, Norway
Posted: Sun Dec 02, 2018 10:31 am Post subject: Re: Call for Webasto BBW 46 info and experiences |
I have just bought a NOS Webasto BBW 46 here in Norway... santa came early this year
I have a 2.2L WBX and I am contemplating installing the heater inline with the heater circuit as opposed to the thermostat controlled install on the factory equipped vans. The reason being that the monovalve seems NLA... and Webasto allows for the option of either thermostat (monovalve) controlled or in series with the heater circuit.
Am I missing something here? It seems like the series install is much simpler with fewer connections. As long as my heater valves are open while the motor warmer is in operation it should circulate warmed coolant to the engine block. I could even close the front heater valve to reduce the amount of coolant in circulation by the Webasto during initial warm-up.
Props to Telus for finding the troubleshooting manual,
http://www.telusplanet.net/public/gary2a/rack/bbw46/BBW46.htm
here is the Bently install (monovalve controlled)
[/img] _________________ 86' Syncro 2.2 Vanistan, WBXhaust, ski-pole shifter for +11hp |
T3messie Samba Member
Joined: October 03, 2017 Posts: 215 Location: Germany
Posted: Sun Dec 02, 2018 10:56 am Post subject: Re: Call for Webasto BBW 46 info and experiences |
The setup with the thermostat monovalve first warms the engine a little (55 C) and then delivers warm water to the heater.
Of course it is possible and more simple to install it witout the monovalve.
If the blower fan is not blowing cold air through the heater core there is enough heat to warm the engine to 87 C in half an hour. |
Gordo_89 Samba Member
Posted: Sun Dec 02, 2018 1:17 pm Post subject: Re: Call for Webasto BBW 46 info and experiences |
I bench tested mine and it heated the water up in a large gorilla tub in no time.
I thought the mono valve worked by heating the cooling system first then the engine?
I have found about 3 webasto manuals in total
Bentley version
Webasto installation manual
Fault finding manual
The inline and thermostat controlled are both detailed in the webasto manual. If that's any help? _________________ 1989 Vanagon 2.1L |
Deadchemist Samba Member
Joined: September 09, 2018 Posts: 15 Location: Hedmark
Posted: Mon Dec 03, 2018 9:26 am Post subject: Re: Call for Webasto BBW 46 info and experiences |
I'm also in abit of a fix regarding my webasto BBW46. I've so far been linked to the repair manual and a wiring loom. The display unit is working but if im honest i really dont understand how to get it going.
Can someone please explain it to me? When I press the clock and enter the time the yellow light comes on but no accompanying sound. |
Posted: Mon Dec 03, 2018 11:22 am Post subject: Re: Call for Webasto BBW 46 info and experiences |
I use the flame symbol on the right hand side this should light up green when activated and stay illuminated while it runs
There is a switch built into the heater control leaver (hot and cold leaver) that needs to be on (hot position) for the time relay to be activated and power to be delivered to the heater unit _________________ 1989 Vanagon 2.1L |
Sodo Samba Member
Joined: July 06, 2007 Posts: 10916 Location: Western WA
Posted: Sun Nov 12, 2023 9:14 am Post subject: Re: Call for Webasto BBW 46 info and experiences |
I saw a Canadian Syncro16 a month ago that used this system to heat the floor of the van, the living space. It was a 16, Westified. The guy bought it in Abbotsford BC, was passing thru WA. _________________
'87 Tintop, EJ25, cooled filtered (original) gearbox
....KTMs, GasGas, SPOT mtb
All Vanagons should do this:
Add direct starter-to-chassis cable THEN delete ground strap at front transaxle mount.
The best time to do this mod was in 2010. The second best time is TODAY.
If your starter is slow, this is MORE important. |
rprsamba Samba Member
Posted: Tue Nov 28, 2023 10:55 am Post subject: Re: Call for Webasto BBW 46 info and experiences |
. I have a 89 Doka with a Webasto control panel. I’m not sure I’ve got the heater element and I’m looking for it. Does anybody know the location of the actual heater in doka? Also, it appears that some of the links are old and not working. Please post links for the Webasto manuals you found? I can’t seem to find them
Thank you |
onefred Samba Member
Joined: January 06, 2012 Posts: 283 Location: Thaïland - Geneva
Posted: Tue Dec 09, 2025 4:11 pm Post subject: |
Hello, links is dead. Do you have new link please ?
thanks. |
Posted: Tue Dec 09, 2025 4:13 pm Post subject: Re: Call for Webasto BBW 46 info and experiences |
Hello, this link is dead, do you have other ?
thanks. |
VicVan  Samba Member
Joined: July 01, 2015 Posts: 2002 Location: Vancouver Island, BC
Posted: Wed Dec 10, 2025 4:17 pm Post subject: Re: Call for Webasto BBW 46 info and experiences |
Ok, thank you very much. |
