Lobotomy Samba Member
Joined: May 30, 2010 Posts: 517 Location: Traverse City, MI
Posted: Sun May 30, 2010 6:28 pm Post subject: Putting older Bumpers/Fenders on a '74 Super |
Can I do this? I want to put '66 or older front and rear fenders and front and rear bumpers on my Super Beetle to make it look like this:
If I can't do it without modifications, can you direct me to the modifications I need?
I am also aware that the bumpers have different slots, it shouldn't be hard to replace the tubes with the thin metal that the older bumpers use.
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79962 Location: Sneaking up behind you
Posted: Sun May 30, 2010 6:30 pm Post subject: |
The front fenders will not fit. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Sun May 30, 2010 6:31 pm Post subject: |
Glenn wrote: |
The front fenders will not fit. |
Okay, but what about the rear fenders and both bumpers? |
draco24433 Samba Member
Joined: November 29, 2009 Posts: 6 Location: Kissimmee, Fl.
Posted: Sun May 30, 2010 6:38 pm Post subject: |
You will have to change the front apron, get two new fenders and a new hood from that year. I am doing the same thing to my '74. Good luck. _________________ '74 STD bug on resto mode! |
Posted: Sun May 30, 2010 6:41 pm Post subject: |
draco24433 wrote: |
You will have to change the front apron, get two new fenders and a new hood from that year. I am doing the same thing to my '74. Good luck. |
I needed to change the front apron anyway. Awesome. |
Glenn  Mr. 010
Posted: Sun May 30, 2010 6:53 pm Post subject: |
It's a Super.... you can't just change the apron.
If you want a early car, sell your Super and buy a early car. _________________ Glenn
Member #1009
#BlueSquare
doc1369 Samba Member
Joined: March 31, 2010 Posts: 2856 Location: Las Vegas, NV, again
Posted: Sun May 30, 2010 7:11 pm Post subject: |
The problem would be the fact that supers have a different front suspention than a standard. By the time you make it work you could pick up a 66. If you just want to be different, hope your budget agrees. _________________ Fatchicks: Daily drivers, donor cars, collectibles. What can't they do? |
dan macmillan Samba Member
Joined: October 19, 2003 Posts: 3110 Location: Northern Ontario, Canada
Posted: Sun May 30, 2010 7:36 pm Post subject: |
Fill the holes in your existing fenders with steel. cut slots appropriate for the bumpers you want then attach the bumpers. Mods to the bumper mounting points may be needed.
Although not the same as a super, my 74 standard had the shock absorbing bumpers but I wanted the early model T bars. I can mount an early bumper on the front but the rears are too far apart for a stock bumper. This is not due to the original mount location but due to the way my engine cover has been widened.
_________________ Licensed Automotive Service Technician
Licensed Truck and Coach Technician
Licensed Heavy Duty Equipment Technician
CFC/HCFC/HFC A/C handling and installation license
Alignment specialist
66 Modified Manx,68 Kyote,74 Thing,74 Beetle, 76 Transporter,75 self made Double Cab,65 Meyers Manx,78Westy,68 Ghia, 79 Bradley GT2
Current projects:
Built for others:69 Manx Clone |
Posted: Mon May 31, 2010 3:42 pm Post subject: |
dan macmillan wrote: |
So if it was not widened, you could mount a stock earlier model rear bumper on there? |
breadmaster Samba Member
Posted: Mon May 31, 2010 5:26 pm Post subject: Putting older Bumpers on a '74 Super |
Hello everyone, I just got on this site because I have a 74 Super myself. This is my first post. I searched for similiar topics, and found this one. I don't mean to hi-jack, as my question is VERY similiar:
I don't want to replace my fenders, as they are fine. But I would like to buy older Bumpers and put them on my 74 super. Will I have to just drill new holes to install? The 74 super bumpers are just so..... Boring!
http://www.jcwhitney.com/bumpers-and-parts-for-volkswagen/p2004761.jcwx#
(The top two)
Bread |
Posted: Mon May 31, 2010 7:29 pm Post subject: |
Lobotomy wrote: |
Yes as I filled and cut my fenders to locate the bumper brackets. _________________ Licensed Automotive Service Technician
Current projects:
partonkevin Samba Member
Joined: June 10, 2003 Posts: 478 Location: McMinnville, TN
Posted: Tue Jun 01, 2010 5:22 am Post subject: |
I've looked into this myself. You may have some luck doing a search. I have a 74 STD. You have a Super. The rear mods would be the same. The front...not so much. I think that the big elephant foot tailights may look odd with an early bumper, so you may want to swap on 72-down rears fenders. You're front fenders and apron need to stay the same for a super as non-super fenders won't fit. You COULD cut the headlight buckets from an older fender and graft them onto your car.
The biggest thing to consider with adding older bumpers is the bumper height. Take a close look at where the bumpers land on an earlier body and where they land on yours.
I found a couple of threads for you to check out.
http://www.thesamba.com/vw/forum/viewtopic.php?t=407999&highlight=
http://www.thesamba.com/vw/forum/viewtopic.php?t=383823&highlight=bumpers |
dayTripper75 Samba Member
Joined: April 24, 2021 Posts: 11 Location: Travelers Rest
Posted: Thu Jun 24, 2021 12:48 pm Post subject: Re: Putting older Bumpers on a '74 Super |
breadmaster wrote: |
(The top two)
Bread |
Did you ever accomplish this? I have a 75 Super and I'd like to do the same thing (just the more interesting bumpers). Any insight would be appreciated! |
stewartsoda Samba Member
Joined: February 03, 2020 Posts: 89 Location: Treasure Valley, ID
Posted: Thu Jun 24, 2021 1:58 pm Post subject: Re: Putting older Bumpers on a '74 Super |
dayTripper75 wrote: |
(The top two)
Bread |
Dude made five posts and last time he logged on was 10 years ago. Probably not going ot get a reply. _________________ 1972 Super Build |
Paul Windisch Samba Member
Joined: September 02, 2009 Posts: 2546 Location: Clinton Township, Michigan
Posted: Thu Jun 24, 2021 2:13 pm Post subject: Re: Putting older Bumpers/Fenders on a '74 Super |
Anything is possible if you get creative, but it won't be just a bolt-on affair. Super Beetles are about 3" wider in the front than their Standard Beetle brothers. So, the mounting location won't be correct, and the width of the bumper across the front of the car likely won't be correct. But, if you are determined, you can fab up some bumper brackets that will bolt to the car on one end, and the bumper on the other. Then, you'll have to decide if you want to fill the holes in the fender where the original hydraulic brackets used to live.
Just my own opinion, but I think late model cars look better with late model bumpers. _________________ *ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
-1914cc
-L3 Heads 35x32 valves 52cc chambers
-0.040" deck for about 9.1:1 Compression
-Engle W110 cam
-CB Super Stock 1.1:1 Rockers
-Stock Heat Exchangers w/ Tri-Mil Muffler
-Dual Weber IDF 40s w/ 26mm venturis
-034 SVDA Distributor
2013 Chevrolet Volt DD
2005 Pontiac Montana SV6
MAHLE Service Solutions
Applications Engineer |
Chadabear Samba Member
Posted: Fri Jun 25, 2021 4:13 am Post subject: Re: Putting older Bumpers/Fenders on a '74 Super |
Creative Car Craft makes fenders for the Supers that have the old style headlight buckets made into them. They offer them in various width's also. Look them up on FB, best business you will ever deal with. |
windfish Samba Member
Posted: Fri Jun 25, 2021 6:48 am Post subject: Re: Putting older Bumpers/Fenders on a '74 Super |
You really need to make drop brackets otherwise the bumpers end up too high, and a '75 with it's shock bumper mounts makes that a little harder 'cause you can't just do a slight mod to the commercially available '68 - '73 drop brackets.
Can message docswitzer, he did a nice job on his Super and has logged in recently; there's additional 'before' pictures and a couple of his first attempt brackets in his gallery, but none currently of the drop brackets.
jarmchairpilot Samba Member
Joined: March 04, 2013 Posts: 492 Location: GALWAY,IRELAND
Posted: Fri Jun 25, 2021 7:01 am Post subject: Re: Putting older Bumpers/Fenders on a '74 Super |
It's a lot of money and work,
I would just keep it stock, a super bug is a better driving car but uglier than a standard bug.
Add a set of aluminium tbars is what I would do and buy a nice Flat4 steering wheel with the money saved.
Remember you should be spending more time inside your Bug driving it than worrying about how it looks on the outside!
Good luck. |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16693 Location: North Florida, USA
Posted: Fri Jun 25, 2021 7:01 am Post subject: Re: Putting older Bumpers on a '74 Super |
Just to add some context to this topic...
67-earlier Beetles mounted the front bumpers thru the front apron and mounted them inside the spare tire well (STD Beetle).
On '68-later Beetles, the bumper mounted thru the fenders to the fender wells on the outside of the trunk.
So mounting the early style bumpers to the later style Beetles using the later mounting points requires a custom mounting bracket that fits between the stock SB mounting points on the car and the bolt holes in the early bumper. Or you need to cut slots thru the front apron and fabricate custom mount points there behind the apron for the brackets to mount to. On the SB, I'm not sure there is much behind the apron to mount to.
Here is an adapter bracket to mount an early bumper to a later (up to '73) STD Beetle (not SB). I don't believe they will work with the wider SB front end or on '74-later Beetles that used shock absorbing front bumper brackets (tubes), but it may give you some ideas for creating your own.
https://www2.cip1.com/ProductDetails.asp?ProductCode=C13%2D15%2D2045
See this thread where they attempted to use the above brackets on a SB and the wider SB front didn't allow the brackets to work.
https://www.thesamba.com/vw/forum/viewtopic.php?t=680351
But there was a suggestions that cutting and moving the flats where the front bumper mounted might allow it to fit. Basically customizing the brackets. At which point, if you have the means to cut and re-weld the brackets, you have the tools to make your own brackets from flat steel.
Looking at the above pic, the early bumpers look much too narrow for the wide front of the SB.
EDIT: I found a thread where someone did it:
https://www.thesamba.com/vw/forum/viewtopic.php?p=9440068
Read the feedback carefully... the early front and rear bumpers on the SB that looks like it fit used custom made brackets and the bumper blades appear to be custom made stainless steel blades that were wider than stock to fit the wider SB body. _________________ AshMan40
H2OSB Samba Member
Joined: April 14, 2013 Posts: 1540 Location: Modesto, CA
Posted: Fri Jun 25, 2021 10:11 am Post subject: Re: Putting older Bumpers/Fenders on a '74 Super |
windfish wrote: |
To each his own, but personally I think this looks awesome and would love to see the adapter brackets that allow this exact mounting(I have a '74 Super but want the early Euroblade bumpers for my outlaw style autocross car)
H20SB _________________ (o\_i_/o) Funny thing about pigs, they're cleaner than you and me. Well....you. |
