20w-50 ok for stock 40 hp?
[email protected]
twk@eurekanet.com is offline
PostPosted: Fri Jul 26, 2002 5:38 am    Post subject: 20w-50 ok for stock 40 hp? Reply with quote
The oil light will flicker at idle when the engine/weather is hot. I have turned up the idle just a 100-200 rpm which helped a bit. I cannot afford to do any engine work at the present time. 20 w-50 help keep pressure up a bit?
Thanks,
DD
PostPosted: Fri Jul 26, 2002 9:13 am    Post subject: 20w-50 ok for stock 40 hp? Reply with quote
I run 20w50 all year in my '55 Bus because the oil light flickered when it was hot in Arizona > 100F. No problems for 12,000 miles.
A lot of people in Arizona run 40wt or 20w50 year round.
TimGud
TimGud is offline
PostPosted: Fri Jul 26, 2002 11:12 am    Post subject: 20w-50 ok for stock 40 hp? Reply with quote
I have run 20w50 in my VW's for fifteen years and wouldn't use anything else.Running it in a 40 horse will help unless there is also a knock in the bottom end, then its rebuild time.
ach60 Premium Member
ach60 is offline
PostPosted: Thu Aug 01, 2002 8:08 pm    Post subject: 20w-50 ok for stock 40 hp? Reply with quote
I used to run 20-50 in VW's but went back to 30wt because of blowing 2 oil coolers on other project VW's.
My 2 cents
Al
View user's profile Send private message Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
IndianaVWKid
IndianaVWKid is offline
PostPosted: Wed Aug 21, 2002 12:58 pm    Post subject: 20w-50 ok for stock 40 hp? Reply with quote
IF YOU GET THIS...PUT IN A NEW OIL PUMP! THAT'S THE PROBLEM! WORN OUT GEARS BABY! AT LEAST RESERVACE THE COVER PLATE, IF YOU"RE CHEAP!
