Tri-Bus Samba Member
Joined: November 29, 2005 Posts: 732 Location: Butler PA
Posted: Sat Oct 23, 2010 9:31 am Post subject: Adding deluxe trim |
I am looking at adding deluxe trim to my bus, any one have any tips or pointers?
Also rough distance on longer pieces between clips? this would be going on to a westy _________________ 73 Westy
A VW team with a triathlon problem, or something like that.... |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10798 Location: iT StiNgeD iTseLf tO dEAd
1970fun Samba Member
Posted: Sat Oct 23, 2010 11:14 am Post subject: Deluxe trim hole (holes) locations |
Here are the measurements for the holes
I couldn't find the dressmaking tape measure so I had to use a steel rule, and some of the measurements might seem a bit odd, but they are as close as I could get using this rule, so hopefully they'll be useful
I don't have the original o/s cab door or the o/s sliding door cover so I wasn't able to get any measurements for them. I also didn't measure the o/s rear corner - but the hole positions looked the same as the n/s rear corner - but if you want me to measure them I will
I didn't measure the position of the holes - in relation the swage line as they looked bang on central to me.
cab door (n/s)
7 holes
Centre of Hole 1 is 38mm from front edge of door
Centre of Hole 2 is 115mm from centre of Hole 1
Centre of Hole 3 is 116mm from centre of Hole 2
Next there's a gap of 29mm from centre of Hole 3 to the left most edge of the wing mirror hole
There's also a 29mm gap from the right most edge of the wing mirror hole to the centre of Hole 4
Centre of Hole 5 is 233mm from centre of Hole 4
Centre of Hole 6 is 233mm from centre of Hole 5
Centre of Hole 7 is 233mm from centre of Hole 6
Finally there's a gap of 18mm from centre of Hole 7 to the right most edge of the door
b-post (n/s)
2 holes
Centre of Hole 1 is 10mm from front edge of post
Centre of Hole 2 is 13mm from centre of Hole 1
Finally there's a gap of 10mm from centre of Hole 2 to the right most edge of the post
sliding door (n/s)
5 holes
Centre of Hole 1 is 20mm from front edge of the door
Centre of Hole 2 is 295mm from centre of Hole 1
Centre of Hole 3 is 295mm from centre of Hole 2
Centre of Hole 4 is 295mm from centre of Hole 3
Centre of Hole 5 is 295mm from centre of Hole 4
Finally there's a gap of 20mm from centre of Hole 5 to the right most edge of the door
sliding door cover (n/s)
5 holes
Centre of Hole 1 is 10mm from front edge of cover
Centre of Hole 2 is 297mm from centre of Hole 1
Centre of Hole 3 is 300mm from centre of Hole 2
Centre of Hole 4 is 300mm from centre of Hole 3
Centre of Hole 5 is 280mm from centre of Hole 4
Finally there's a gap of 10mm from centre of Hole 5 to the right most edge of the cover
Rear corner (n/s)
4 holes
Centre of Hole 1 is 20mm from front edge of seam
Centre of Hole 2 is 135mm from centre of Hole 1
Centre of Hole 3 is 135mm from centre of Hole 2
Centre of Hole 4 is 135mm from centre of Hole 3
Finally there's a gap of 10mm from centre of Hole 4 to the edge of the panel
Rear hatch (n/s)
5 holes
Centre of Hole 1 is 27mm from front edge of hatch
Centre of Hole 2 is 300mm from centre of Hole 1
Centre of Hole 5 is 300mm from centre of Hole 4
Finally there's a gap of 10mm from centre of Hole 5 to the right most edge of the door
sliding door (o/s)
5 holes
Centre of Hole 1 is 32mm from front edge of the door
Centre of Hole 3 is 297mm from centre of Hole 2
Centre of Hole 4 is 297mm from centre of Hole 3
Centre of Hole 5 is 297mm from centre of Hole 4
Finally there's a gap of 18mm from centre of Hole 5 to the right most edge of the door |
Posted: Sat Oct 23, 2010 2:55 pm Post subject: |
1970fun wrote: |
cab door (n/s)
7 holes
b-post (n/s)
2 holes
sliding door (n/s)
5 holes
5 holes
Rear corner (n/s)
4 holes
Rear hatch (n/s)
5 holes
sliding door (o/s)
5 holes
Holy Detail Batman! thanks for the helpful and detailed response _________________ 73 Westy
1961bluebug Samba Member
Joined: November 11, 2002 Posts: 1137 Location: Czech Republic, Europe
Posted: Fri Jan 22, 2016 2:35 am Post subject: Re: Adding deluxe trim |
wow, thanks a lot _________________
|82x94|
1961 Deluxe beetle, 1971 type 181, 1968 T2a Baywindow, 1973 Type 147 "Swiss Fridolin"(sold), 1966 Deluxe sedan (sold), 1983 "Silver Bug" edition (sold), 1961 beetle (sold) |
