Reverse lights
Pbotsonis
Pbotsonis is offline
PostPosted: Mon Feb 21, 2011 8:04 pm    Post subject: Reverse lights Reply with quote
So a couple of years ago my car was acting up. When I took it to my buddy to have him look at it he reached behind the motor and pulled out a completely bare wire. Anyways from then on my reverse lights have not worked. Anyone know where that wire starts and ends so I can replace it?
Thanks,
Price does not include PayPal fees. Text is the fastest way to reach me
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Feb 21, 2011 8:05 pm    Post subject: Reply with quote
It runs from the positive side of the coil to the tranny switch. then from the switch to a Tee connector in the engine compartment and then to each tail light.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Pbotsonis
PostPosted: Mon Feb 21, 2011 8:07 pm    Post subject: Reply with quote
Is the Tranny switch behind the motor? Thanks for the quick reply
Mr. 010
Glenn is offline
PostPosted: Mon Feb 21, 2011 8:08 pm    Post subject: Reply with quote
Its on the passenger side of the nose cone.... on the tranny.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Semper_Dad
Semper_Dad is offline
PostPosted: Mon Feb 21, 2011 8:13 pm    Post subject: Reply with quote
You may want to follow this thread as well.
http://www.thesamba.com/vw/forum/viewtopic.php?t=326901
Excellent diagram Glenn
Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
Mr. 010
Glenn is offline
PostPosted: Mon Feb 21, 2011 8:16 pm    Post subject: Reply with quote
Not mine, it's from Speedy Jim's website.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Semper_Dad
PostPosted: Mon Feb 21, 2011 8:31 pm    Post subject: Reply with quote
Nice diagram reference Glenn Laughing
Pbotsonis
PostPosted: Wed Feb 23, 2011 9:23 pm    Post subject: Reply with quote
So I just put it in reverse with the key on (motor not started) got underneith it and hit the switch with a test light. it said it wasn't getting power. Does the car have to be started in order to give the switch power? Also I found 2 wires connected to it, so I'm sure I'll have to chase the ends down.
Thanks
Semper_Dad
PostPosted: Wed Feb 23, 2011 9:30 pm    Post subject: Reply with quote
Thanks
Just need to have the key in the "on" position. One of the wires on the transmission is coming from the coil (via the bakelite fuse). Other wire is going to the backup lights (via a t-connector).
Turn the key to the "on" position (not start). Check for 12VDC at the following locations.
1) Bakelite fuse (both ends)
2) Transmission switch (both contacts) Make sure shifter is in reverse
3) Either one of the blue wires in the T4 connector
You can also remove both wires on the transmission switch and check for continuity on the switch (between contacts) with shifter in and out of reverse. Should be 0 ohms (short) when in reverse, Infinity (open) out of reverse. Do not have to have car on or start. In fact, keep key in pocket Laughing
Thing68
Thing68 is offline
PostPosted: Sat May 23, 2020 11:56 am    Post subject: Re: Reverse lights Reply with quote
Reviving an old thread here. Has anyone been able to replace the BU switch without removing the tranny?
BJT
BJT is offline
PostPosted: Sat May 23, 2020 5:58 pm    Post subject: Re: Reverse lights Reply with quote
I personally did not do it, but a guy that I had working on my Thing replaced it without taking out the trans. It should be very reachable.
Thing68
Thing68 is offline
PostPosted: Sat May 23, 2020 6:20 pm    Post subject: Re: Reverse lights Reply with quote
Thanks, if finally found where it is but it looks really tight quarters.
FJBLF
FJBLF is offline
PostPosted: Thu May 28, 2020 5:13 pm    Post subject: Re: Reverse lights Reply with quote
Maybe this helps...
1972 VW 181 SAFARI 1500 cc GRB Trans-axle
