Rocker Shifts - Push Rod at an Angle
pogolo
pogolo is offline
PostPosted: Sun Feb 27, 2011 11:23 am    Post subject: Rocker Shifts - Push Rod at an Angle Reply with quote
Heard a loud tapping when starting up my '76 2.0L FI bus with hydraulic lifters. I've had a lifter collapse before, so removed the valve cover on the loud side. I found that one of the exhaust valve push rods had slipped to the side and the top part of the rocker was striking the edge of the valve spring: the rocker had shifted to the right and was not centered. There's a hole in the push rod tube where the push rod was wearing against it at an angle.
I removed the lifter and it appears to be fine. This has happened twice to me over the last 2-3 years.
Only thing I can think is that due to not changing the oil for several months (I know, I know), the lifter got jammed with crud and did not pump up, allowing the push rod to shift. Any other ideas?
Thank you Samba.
busman78
busman78 is offline
PostPosted: Sun Feb 27, 2011 11:53 am    Post subject: Reply with quote
Is the spring betwen the two rockers still there? Is it crunched or broken?
towd
towd is offline
PostPosted: Sun Feb 27, 2011 11:59 am    Post subject: Reply with quote
that rocker can not slide unless something is missing from the Rocker shaft ..
compare that rocker assmebly to the others. you'll find something is missing ..
pogolo
pogolo is offline
PostPosted: Sun Feb 27, 2011 12:53 pm    Post subject: Reply with quote
Yes. The spring is still there and has tension.
busdaddy
busdaddy is offline
PostPosted: Sun Feb 27, 2011 12:56 pm    Post subject: Reply with quote
Hydro rocker shafts don't use springs, they should have solid spacers and thin wavy spring washers, who converted it to hydros?
Слава Україні!
pogolo
pogolo is offline
PostPosted: Sun Feb 27, 2011 1:14 pm    Post subject: Reply with quote
Really?! Hm. Springs all round. That's how the bus came.
Anyone with pics of the solid spacers?
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Sun Feb 27, 2011 1:45 pm    Post subject: Reply with quote
Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page.
pogolo
pogolo is offline
PostPosted: Sun Feb 27, 2011 2:51 pm    Post subject: Reply with quote
Ok. Wow. So should I replace the entire rocker assembly, or just the spacer?
Thanks much for the picture. Very enlightening.
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Sun Feb 27, 2011 2:56 pm    Post subject: Reply with quote
Are you sure yours are hydraulic?
Eric
pogolo
pogolo is offline
PostPosted: Sun Feb 27, 2011 3:22 pm    Post subject: Reply with quote
Definitely has hydraulic lifters.
So the question is - do I need to replace the entire rocker assembly, or can I just source these solid spacers and slip them on what I have?
Thanks.
pogolo
pogolo is offline
PostPosted: Tue Mar 01, 2011 7:30 am    Post subject: Reply with quote
Thanks for the help everyone. I've since put everything back together and the bus is running fine.
I asked at my local shop/junkyard, Austin VeeDub. It appears that the solid rocker spacers in EZ Gruv's picture are an after-market item. I was also shown a bug catalog illustrating that it's a fairly common modification on performance bug engines, but not so much for the Type IVs.
At any rate, from what I've seen (a stock '78 hydraulic lifter engine we looked at had springs) and been told, solid rocker spacers are NOT a factory-installed item - hydraulic lifters came with spring spacers as standard.
Could be wrong and definitely open to debate! There always seems to be a lot of surprising year-to-year variation with the buses. Just hoping this helps someone out down the road.
busdaddy
busdaddy is offline
PostPosted: Tue Mar 01, 2011 7:43 am    Post subject: Reply with quote
Time to start looking for a new shop, those guys obviously shouldn't be anywhere near a type 4.
Слава Україні!
mattcuddy
mattcuddy is offline
PostPosted: Tue Mar 01, 2011 7:47 am    Post subject: Reply with quote
pogolo wrote:
At any rate, from what I've seen (a stock '78 hydraulic lifter engine we looked at had springs) and been told, solid rocker spacers are NOT a factory-installed item.
Nope, its factory.
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Tue Mar 01, 2011 7:58 am    Post subject: Reply with quote
Bingo, Checkmate, and Yahtzee! Those guys are clowns, RUN away!
Eric
busman78
busman78 is offline
PostPosted: Tue Mar 01, 2011 8:55 am    Post subject: Reply with quote
Well lets split some hairs, what you refer to as "solid" VW rocker spacers really where not "solid", VW still used spring washers, better than just having the single spring but really not solid. This kit makes a set of solid rocker spacers.
Wildthings
Wildthings is offline
PostPosted: Tue Mar 01, 2011 9:43 am    Post subject: Reply with quote
VW went to the solid spacers with the hydraulic valves exactly to prevent the problem you are seeing from occurring. With solid lifters the rockers has a moment to recenter each time the lifter ran over the base circle of the cam and there was momentarily a little lash. With hydraulics there is always some compressive force on the valve train even when the lifter is on the base circle, so the rocker can be pushed to the side over a number of revolutions.
RocketRod
RocketRod is offline
PostPosted: Tue Mar 01, 2011 9:59 am    Post subject: Reply with quote
So to butt in on this conversation......is the hyd lifter rocker shaft smaller than a regular shaft? Reason I ask is I got a set from a known used parts seller and the spring washers do not fit on the shaft. 8 spring washers, 8 solid washers & 4 spacers.
Why Yes it is a Magic bus!
Common Sense isn't so common.
busman78
busman78 is offline
PostPosted: Tue Mar 01, 2011 10:32 am    Post subject: Reply with quote
T4 shafts were all the same diameter.
RocketRod
PostPosted: Tue Mar 01, 2011 10:44 am    Post subject: Reply with quote
Thanks, so the wavy washers must be too small.....now where to find some.
pogolo
pogolo is offline
PostPosted: Wed Mar 02, 2011 11:02 am    Post subject: Reply with quote
Anyone with a link to a place where I can buy solid rocker spacers?
Thanks.
