Front Door seals/gaskets
cambarner
cambarner is offline
PostPosted: Mon Oct 24, 2011 7:20 pm    Post subject: Front Door seals/gaskets Reply with quote
This may belong in the stupid questions thread, but...
While I have searched on this topic, I have not found an answer to my specific question.
First, when installing the front door seals do the doors need to come off? I would think you could replace it with out removing the door...
And Second, should I use any glue in attaching the seal to the door?
Thanks in advance,
Cam
1972 Microbus, AKA 'SurfBus'
VDubTech
VDubTech is offline
PostPosted: Mon Oct 24, 2011 7:44 pm    Post subject: Reply with quote
No, and no.
First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote:
a measurement of your rod would be extremely useful.
notchboy wrote:
my dad wasnt a belittling cock when he tought me how to wrench on cars.
One photo = good for reference.
10 photos = douchebaggery
curtis4085
curtis4085 is offline
PostPosted: Mon Oct 24, 2011 7:47 pm    Post subject: Reply with quote
No and maybe. my OG seals i pulled off had a bit of it in places.. and no it did not apear to be from PO. I pulled all the seals off my bus and some had and some didnt. So Im up in the air.
Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com
kreemoweet
kreemoweet is offline
PostPosted: Tue Oct 25, 2011 12:16 am    Post subject: Reply with quote
The checkstraps will need to be disconnected. The front of the door does
not have a channel to retain the seal, and will certainly require glue. As I
recall, the top corners will also flop around if not glued.
'67 bug: seized by the authorities
cambarner
PostPosted: Tue Oct 25, 2011 4:15 am    Post subject: Reply with quote
Then how come everyone else said I didn't need it? haha. What type of glue would you recommend?
poptop tom
poptop tom is offline
PostPosted: Tue Oct 25, 2011 5:48 am    Post subject: Reply with quote
First of all, make sure the channel is good and clean where the seal sits. Then do a dry run. Set the seal in place, make its correctly installed, and see how the doors close.
At this point, if you feel comfortable with the fit, you can use a bit of adhesive where necessary. You may get away without using adhesive at all. The quality of seal you are using will probably have an impact on whether you need adhesive, or not.
I used quality door seals when I did mine, but still decided to use adhesive in a few areas - corners, at the top, etc.
This is what I used:
http://www.permatex.com/products/Automotive/adhesi...ealant.htm
'76 Deluxe Campmobile
SGKent Premium Member
SGKent is offline
PostPosted: Tue Oct 25, 2011 5:55 am    Post subject: Reply with quote
3-m yellow weatherstrip glue. VW used glue.
George Carlin:
Skills@EuroCarsPlus:
1971 deluxe (sold)
1977 deluxe
Desertbusman
Desertbusman is offline
PostPosted: Tue Oct 25, 2011 6:10 am    Post subject: Reply with quote
Weatherstrip glue or contact cement. There will be places that do need an adhesive.
71 Superbug
71 Westy
poptop tom
PostPosted: Tue Oct 25, 2011 6:38 am    Post subject: Reply with quote
You are correct. Indeed that is what I used. It's been a few years, and I was almost certain it was a Permatex product. Embarassed
Tuna Tim
Tuna Tim is offline
PostPosted: Tue Oct 25, 2011 7:22 am    Post subject: Reply with quote
I just did my driver's door seal last week. It was eezy-shmeezy.
- Remove the old seal.
- Clean the contact area well.
- Pop the pin out of the check-strap to allow the front portion of the seal to be positioned.
- Install the seal without adhesive, but using blue painters' tape to hold it in place. Taping the seal in place will allow you to identify those areas of the seal that require some adhesive, without it flopping all over the place. (It's the next best thing to having a third arm)
- Lift the section of seal that requires adhesive, apply glue, tape back down. If the adhesive is a quick set you can skip the tape.
- Move on to next section that requires adhesive.
- Follow manufacturer's recommendation for time to allow adhesive to cure.
- Remove tape
- Reinstall check-strap.
- Admire your handy work.
Words of wisdom:
- Not all seals are created equal.
- The door may be difficult to close for awhile, until the seal compresses.
- The latch may require adjusting.
1974 Bay
CSII
091
Dual 40 Dells
Unilite
Thunderbird Extractor
cambarner
PostPosted: Tue Oct 25, 2011 2:21 pm    Post subject: Reply with quote
Quality info. Thank you very much!
stevo
stevo is offline
PostPosted: Tue Jul 03, 2012 9:31 pm    Post subject: Reply with quote
does the check strap pin pop out? appears that it should. i removed the circlip, tapped it hard with a hammer and it hasn't budged. should i hit from below full force?
Tuna Tim
Tuna Tim is offline
PostPosted: Wed Jul 04, 2012 6:13 am    Post subject: Reply with quote
It does lift out once the clip has been removed. Mine lifts out using my index finger. Hitting it "full force" risks mushrooming the pin. You don't want to do that. Try wiggling the door back-n-forth as you tap it lightly from the bottom. If the pin is still reluctant to move, try some PB Blaster or similar concoction. A few light taps on the strap and side of the pin might also help to free it.
1974 Bay
CSII
091
Dual 40 Dells
Unilite
Poptopcamper
Poptopcamper is offline
PostPosted: Wed Jul 04, 2012 6:35 am    Post subject: Reply with quote
In the early 60's vws were known to be so well sealed that they would float. I remember seeing a YouTube of a bug floating in a lake or some body of water. I don't know about busses. I do remember that a friend got a new bug in the 60's and it was easier on the ears to crack the window before shutting the doors. Do your ears pop when you shut your doors? Do busses really float? I need to replace my door seals too. I'll keep you posted.
If you only have one tool in your tool box, and it's a hammer, pretty soon, everything looks like it needs to be whacked!
1978 VW Riviera
2021 Dodge Ram 3/4 ton
2020 VW Tiguan
2001 Harley Electraglide Classic
1986 BMW R 800cc motorcycle
2002 Chevy Camaro Z28
1999 Harley Sportster 1200 Custom
Busdriver79
Busdriver79 is offline
PostPosted: Wed Jul 04, 2012 6:38 am    Post subject: door seals Reply with quote
Thanks for reminding me to replace my front door seals....I just ordered a pair online a few minutes ago....They will be here within a week.
stevo
stevo is offline
PostPosted: Wed Jul 04, 2012 2:23 pm    Post subject: Reply with quote
thanks tim. that's the way it looks in bentley, but i'm glad to double check before reefing on it. will blaster it.
HarryFD
HarryFD is offline
PostPosted: Thu Oct 03, 2013 8:32 pm    Post subject: Reply with quote
Just did my doors. One of the pins was rusted into place. After trying to drift it out, I gave up and dremeled the head off. It was replaced with a Stainless steel 30 mm M6 buttonhead bolt and nylock nut.
The rubber is thicker than my old rubber and the doors are hard to close but with a bit of energy, close and latch. I will wait a few months before I take more drastic measures.
1970 Deluxe Sunroof Bay Brilliant Blue/Cloud White
1971 Jaguar XKE 2+2 V12 Coupe
1973.5 911 Targa
2009 MB C300
