distributor help
volkswagen4life
volkswagen4life is offline
PostPosted: Wed Jan 18, 2012 12:57 pm    Post subject: distributor help Reply with quote
okay so since I got my car I have been having to re gap the point every month but the last time I did it I noticed that it still kept cutting out in the higher rpms (near the shift mark) so I took it to the air cooled vw mechanic here and he test the vacuum advance and it didn't hold a vacuum at all and he was telling me that my distribute is a .008 and the kind that came originally for that years was .007 but when I look for replacements all I can find is the .009 with that work? or will the advances off the other ones will work on this one
78' Type 2 "little buggie"
74' Type 1
70' Type 3 square
sharkskinman
Lateral Lunatic
sharkskinman is offline
PostPosted: Wed Jan 18, 2012 1:52 pm    Post subject: Reply with quote
http://www.oldvolkshome.com/ignition.htm#C1970FM
NO an 009 is a mechanical ONLY
you need a vacuum advanced one
either you can find a vacuum advance can or an entire distributor
take a look at the link above
It will tell you EXACTLY what dizzy you have or need
AND bug vaccuum cans ARE NOT THE SAME
they have a higher vacuum signature
74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
Me of Course wrote:
Extremity is relative to how far your willing to jump
Ward Cleaver wrote:
You ever try a pink golf ball, Wally? Why, the wind shear alone on a pink golf ball can take the head off a 90-pound midget at over 300 yards
PS4 "NKOGNEATO"
volkswagen4life
PostPosted: Wed Jan 18, 2012 2:06 pm    Post subject: Reply with quote
Okay so where are these parts avalble I could find the at any auto parts store even the air cooled vw guy here in town
74' Type 1
70' Type 3 square
Dfasty
Dfasty is offline
PostPosted: Wed Jan 18, 2012 6:39 pm    Post subject: Reply with quote
your dist no.is VW 311-905-205AB, Bosch 0231 163 008 there is a whole page in the classifieds. the link above will help if you can locate a vacuum can.
70 fastback automatic 06 invader
volkswagen4life
PostPosted: Wed Jan 18, 2012 7:20 pm    Post subject: Reply with quote
He said eather my disrubtor or my whole motor was outta of a 72 so I acually need the numbers for that one he has the canister for the 70 year but its different would that canister work?
74' Type 1
70' Type 3 square
Woreign
Woreign is offline
PostPosted: Wed Jan 18, 2012 11:53 pm    Post subject: Reply with quote
I think the vacuum can will work fine. I recently swapped mine out for the "correct" one and I noticed no change in engine performance.
Bobnotch
Bobnotch is offline
PostPosted: Thu Jan 19, 2012 10:21 am    Post subject: Reply with quote
If you can't find 1 in the classifieds, you might try ordering 1 from Autozone. I think they're only about 55 bucks. I'd order it up for a 70 though, as it'll have a better advance curve.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
volkswagen4life
PostPosted: Thu Jan 19, 2012 11:00 am    Post subject: Reply with quote
Already call auto zone said it'd be between 3 and 18 months
74' Type 1
70' Type 3 square
Bobnotch
Bobnotch is offline
PostPosted: Thu Jan 19, 2012 11:02 am    Post subject: Reply with quote
Ouch, they had mine in, in 2 days. You might try O'Rielly's, or NAPA then.
Tram wrote:
Tram wrote:
IAMIROY
IAMIROY is offline
PostPosted: Thu Jan 19, 2012 11:57 am    Post subject: Reply with quote
Definitely try Orielly's, they have a lot of VW stuff in stock.
volkswagen4life
PostPosted: Thu Jan 19, 2012 1:40 pm    Post subject: Reply with quote
Tried napa they said the can only rebuild them and I was looking for the one for my modle year Ill check orielys
74' Type 1
70' Type 3 square
blankmange
Type 3 Darksider
blankmange is offline
PostPosted: Thu Jan 19, 2012 1:52 pm    Post subject: Reply with quote
not in the classifieds?
http://www.thesamba.com/vw/classifieds/detail.php?id=1136544
http://www.thesamba.com/vw/classifieds/detail.php?id=1188905
póg mo thóin
Certified DHS Technician
Samba Member # 24517
volkswagen4life
PostPosted: Thu Jan 19, 2012 2:36 pm    Post subject: Reply with quote
Hadn't had time to look up in the classifieds but thanks for the links
74' Type 1
70' Type 3 square
MOCHABILL
MOCHABILL is offline
PostPosted: Thu Jan 19, 2012 2:48 pm    Post subject: Reply with quote
Checked on the ADVANCE AUTO web site,one is listed;
http://shop.advanceautoparts.com/webapp/wcs/stores...MS_____BBV
'71 Squareback FI
'07 Passat wagon 2.0
'03 Ranger 4door 4.0
volkswagen4life
PostPosted: Thu Jan 19, 2012 8:25 pm    Post subject: Reply with quote
okay so can I get the info on a distributor out of a 72? so I can try to find a vacuum can for it I think it was a 07 017 but I can't find anything on that
74' Type 1
70' Type 3 square
MagmaJctAz
MagmaJctAz is offline
PostPosted: Fri Jan 20, 2012 4:15 am    Post subject: Reply with quote
This is my barn find! Found it last summer (2011). Wife suggested I pick it up. I paid $200 for it. The guy helped me get it out. Phoenix AZ heat, two tires that didn't hold air, and the other two only for a few hours. We installed two tires from my Super to get it out of the back yard and onto a trailer.
It was last registered in the mid 80s!
1974 Super Beetle. Owned since 1995. Daily Driver. Turned over odometer twice!
1971 Fastback. Check out my Fastback resurrection thread!
http://www.thesamba.com/vw/forum/viewtopic.php?t=627711&highlight=
Dfasty
Dfasty is offline
PostPosted: Fri Jan 20, 2012 5:57 pm    Post subject: Reply with quote
is the vacuum can a duel port. I tried swapping them between single and double and they didn't interchange
volkswagen4life
PostPosted: Fri Jan 20, 2012 7:26 pm    Post subject: Reply with quote
All I can see is one so just a single I sappose
74' Type 1
70' Type 3 square
flyboat
flyboat is offline
PostPosted: Fri Jan 20, 2012 7:59 pm    Post subject: Reply with quote
Search member Glenn. He is the distributor guru. He is often on the 68 and up forum. He will sell you what you need or steer you straight.
79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
09 Z06 Vette track car
sharkskinman
Lateral Lunatic
PostPosted: Fri Jan 20, 2012 9:59 pm    Post subject: Reply with quote
Rockauto.com
PS4 "NKOGNEATO"
