Reliable pressure plates for a bus?
Micropassatman
Micropassatman is offline
PostPosted: Thu Jan 19, 2012 6:12 pm    Post subject: Reliable pressure plates for a bus? Reply with quote
Just had my SECOND SACHS Brazilian PP FAIL on me today. This is my work vehicle and I can't have this unreliable SHIT in my bus anymore. Any ideas in terms of what might be the MOST reliable plate out there right now for a bus? KEP? LUK?
I need this baby R&R'ed by Monday and could use your help. Please!
Inane Cathode
Inane Cathode is offline
PostPosted: Thu Jan 19, 2012 7:11 pm    Post subject: Reply with quote
KEP is who i chose for my pressure plate (stage II) (along with the KEP gold friction disk). It's held up just fine with 140 some odd hp the ej22 puts out, so im sure it's ok with the lawnmower you've got (j/k).
Only had one clutch cable break, and it was worn through at the clutch pedal (and also was as ancient as the rest of the bus i'm sure). Clutch feel is just fine.
<edit> Although now that i think about it i'm pretty sure i've actually got a 200mm pressure plate and clutch disk. so thats not really that helpful :/
Desertbusman
Desertbusman is offline
PostPosted: Thu Jan 19, 2012 7:16 pm    Post subject: Reply with quote
Why did it fail?
I've never had any problems with them. Got a picture of it? And you might tell us what year. Which T/O bearing system?
71 Superbug
71 Westy
Micropassatman
PostPosted: Thu Jan 19, 2012 8:07 pm    Post subject: Reply with quote
A few of the 'fingers' on the release mechanism just 'weaken'. It works but it feels like shit. Eventually it won't work at all. It's a '70 S/P 1600 with an 091 in it. Sleeved T/O bearing w/o collar on P/P - 200mm('71 bus or any late beetle).
Micropassatman
PostPosted: Thu Jan 19, 2012 8:09 pm    Post subject: Reply with quote
My local vendor has an EMPI knockoff of Kennedy's 1700lb plate for $99. Worth the risk? I'd rather have a 3-fingered plate at this point.
SGKent Premium Member
SGKent is offline
PostPosted: Thu Jan 19, 2012 8:13 pm    Post subject: Reply with quote
You have an 002 Bellhousing on it? What type disk?
Micropassatman
PostPosted: Thu Jan 19, 2012 8:15 pm    Post subject: Reply with quote
Regular Sachs sprung 200mm disc.
Micropassatman
PostPosted: Thu Jan 19, 2012 8:17 pm    Post subject: Reply with quote
Let me clarify:I drive delivering parcels in my bus for 8 hours a day. I need a plate that can be sprung/unsprung 1000 times a day and remain reliable. Clamping force isn't the issue here.
SGKent is offline
PostPosted: Thu Jan 19, 2012 8:49 pm    Post subject: Reply with quote
Wow. You might want to call FAT Performance as they show a German made F&S (Fichtel & Sachs) 200 mm diaphragm style in their catalog. Everywhere else showed Brazil. If they work you might stockpile a couple cause that is a lot of driving in a bus and it will tear up a clutch using it heavy duty like that. Stay away from anything unsprung or racing.
Micropassatman
PostPosted: Thu Jan 19, 2012 9:15 pm    Post subject: Reply with quote
I think I just found what I need:
http://www.germansupply.com/home/customer/product.php?productid=17114
SGKent is offline
PostPosted: Thu Jan 19, 2012 9:34 pm    Post subject: Reply with quote
I had a similar 3 finger on my Jeep and it didn't last a long time HOWEVER if you can get a gauge block to set the finger height it is adjustable and you can get the height back. The drawback on a 3-finger is that they have more vibration in my experience.
Micropassatman
PostPosted: Thu Jan 19, 2012 9:40 pm    Post subject: Reply with quote
Vibration? At speed or during engagement? Anybody else have experience with the 3-fingered plates?
SGKent is offline
PostPosted: Thu Jan 19, 2012 10:12 pm    Post subject: Reply with quote
engagement. If one finger gets a tiny bit softer or wears more, the TO will rock as the pressure plate spins. It is less likely on a spring diaphragm. That is why three finger plates are adjustable. There is a gauge block tool where one uses the gauge block to measure the finger height above the flywheel so all three fingers are the same as the pivots wear and the springs get some miles.
SGKent is offline
PostPosted: Thu Jan 19, 2012 10:27 pm    Post subject: Reply with quote
one thing you might consider, is maintenance. As a clutch wears it tightens up. That removes freeplay. It also causes the diaphragm to be pushed in further each time you step on the clutch. Bowden tube bend also affects that. if you are over centering the clutch and pushing it in too far the diaphragms will wear out sooner. Also the clevis pin and parts can wear and give the illusion of freeplay when actually there is less than design. I relegiously maintain my clutch at 5/8 - 3/4 inch freeplay. That will help the clutch diaphragms last longer. At stop lights put it in neutral. On the freeway when stopped put it in neutral or move slow in 1st. That will also protect the engine thrust bearings.
Micropassatman
PostPosted: Thu Jan 19, 2012 10:34 pm    Post subject: Reply with quote
I also am religious about clutch maintenance. 3/4" freeplay, just replaced the clevis-pin and cable.
SGKent is offline
PostPosted: Thu Jan 19, 2012 10:46 pm    Post subject: Reply with quote
I think you are up against 1000 pushes a day. If you can get a German steel diaphragm that would be your best bet. I agree that it is the number of cycles that is wearing it out and not abuse or load. Metal only flexes so many times before it wears out. I used to drive a stick shift 71 bus, 73 fiat and 82 jeep cj7 in LA stop and go traffic. Only once did a pressure plate break or crack and that was a Borg and Beck diaphragm on the jeep at 80,000 miles. Usually they get weak or glazed. I would think maybe you could expect 30,000 - 40,000 miles between pressure plate replacements at 1000 pushes a day (2 yrs x 15,000 - 20,000 miles a year). Normally a disk would last me 40,000 to 50,000 in LA traffic and the pressure plate was good for two disks. I am doing this from memory but I do remember replacing them many times in the 300,000+ I owned each of those cars. I think the bus had 370,000 on it and the jeep 410,000 when I sold them. The fiat was only about 140,000.
Hoody
Hoody is offline
PostPosted: Fri Jan 20, 2012 12:40 am    Post subject: Reply with quote
Once again as predicted the market did not bare the cost of Original German. Find an original German one. PM me with the specifics.
josh
josh is offline
PostPosted: Fri Jan 20, 2012 2:59 am    Post subject: Reply with quote
I'd probably go for a good used or NOS german pressure plate or a KEP plate if they are still american made.
I delivered pizzas from a bus for several years in the '90s. didn't have any clutch problems.
modok wrote:
...If If stoner A takes a hit and then stoner B goes right away(not waiting two seconds), he's trying to suck on it while it's still got a vaccum, doesen't get much of a hit at all! Cause it hasn't filled back up all the way yet.
Stoner A is cylinders #2/4 B is #1/3 The plugged bowl is the throttle, the bong is the manifold
DakDak67
DakDak67 is offline
PostPosted: Fri Jan 20, 2012 3:53 am    Post subject: Reply with quote
Yeh, i'm using a Kennedy stage 1 with a gutsy 2276.. no issues.
jtauxe Premium Member
jtauxe is offline
PostPosted: Fri Jan 20, 2012 8:04 am    Post subject: Reply with quote
SGKent wrote:
On the freeway when stopped ...
I guess that's a Big City problem. Confused
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
