Shifter problem - please help evaluate my parts
oleflorida
oleflorida is offline
PostPosted: Sun Nov 18, 2012 4:21 pm    Post subject: Shifter problem - please help evaluate my parts Reply with quote
So my 67 bus hasn't shifted correctly since I got it. I've changed the front bushing and lubed everything up, but the ball keeps popping out of the cup. I haven't been able to drive it much, but the little I have, I'm able to find gears but with a shifter that swings all over the place. I've done my searches and now I think it might be the rear coupler (the bolts aren't lined up straight). I believe the shifter is the OG longer later model one. One thing I notice is where the rear shift rod come out of the tube to the front coupler, it lays very low and might even touch the bottom of the tube. Is this correct? Also if the front bushing is new and in the "pin" guide properly, how can the cup be in the wrong location (presumably lower)? I could use some input on my shifter parts to help me narrow/fix my problem.
Here's the ball out of the cup:
Are there suppose to be two holes in the front shifter rod? :
Darren
67 SO-42
quartermilecamel
quartermilecamel is offline
PostPosted: Sun Nov 18, 2012 8:42 pm    Post subject: Reply with quote
You might try getting the correct shifter for your bus if thats not a 67 shifter. Also, you dont show a lockout plate in your photos. Are you using one?
Waiting for santa to drop off funky green. I can wish can't I????
quartermilecamel
PostPosted: Sun Nov 18, 2012 9:04 pm    Post subject: Reply with quote
Still staring at that underside pick. Either you dont have all 67 parts or that locating pin has been moved. Unless that shifter housing that holds the spring is so far gone, the shifter is popping through it.
Clara Premium Member
Clara is offline
PostPosted: Mon Nov 19, 2012 9:11 am    Post subject: Reply with quote
reverse lock out plate:
http://www.thesamba.com/vw/forum/viewtopic.php?t=215229
66-67 differences:
http://www.thesamba.com/vw/forum/viewtopic.php?t=190619
http://www.thesamba.com/vw/forum/album_search.php?...r=hazetguy
(cut and paste the whole link, look at both pages)
looks like the rod is correct.
what happens at the back of the bus will not make the ball pop out of the socket.
? the thing bolting to the floor is wrong?
the spring is wrong?
ah- ha! looks like the spring is broken. the fat end of the curl is rusted off
cru62
cru62 is offline
PostPosted: Mon Nov 19, 2012 9:38 am    Post subject: Reply with quote
I wouldn't get too excited about the spring. It just holds the shifter UP into the shift plate. Is your shifter cup (the one that fits over the shifter and bolts to the floor) worn out? Lack of lube will cause that to wear rapidly. It isn't apparent sometimes because it is double walled. If that AND the ball are worn it could be enough to let the end of the shifter pop-out of the rod.
"My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
oleflorida
PostPosted: Mon Nov 19, 2012 11:46 am    Post subject: Reply with quote
Here's the lockout plate:
And here's the locating pin (looks like it's where it's suppose to be):
I don't have a picture of the the shifter cup right now but I do recall it showing some wear and maybe even having a crack in it. I see that BusBoys sells a complete shifter assembly for a 66-67 that includes the cup and spring. Anyone have any experiences with this part? Also, if I were to get some used parts, is the spring the same size for earlier and late splitties? Thanks everybody for the help!
Darren
67 SO-42
BarryL Premium Member
BarryL is offline
PostPosted: Mon Nov 19, 2012 7:05 pm    Post subject: Reply with quote
Try buying a good used german shift housing off the classifieds and I'll bet your troubles go away.
oleflorida
PostPosted: Thu Dec 06, 2012 4:19 pm    Post subject: Reply with quote
Well, I got a used housing and spring. It's obvious that my parts were shot:
new spring on the right
new housing on the left
After installing the new parts it still didn't work well. A little better but still would pop out and the shifter would be able to swing around loosely. I noticed as I was shifting that the housing would move a bit even though it was bolted as hard as I could get it. Looked like the floor itself would move a bit. So as I was unbolting the unit, I noticed one of the bolts was at an angle and it looks like the PO just spot welded a nut under the floor. Of course the nut came off and now I have no way of even putting the shifter back on Crying or Very sad
Here's what I got going on now:
So what now? I've got no welding skills but a have couple of friends that might be able to help. Don't mind bringing it somewhere, just got some other engine kinks to fix. Ugh, 0 steps forward 4 steps back.
Darren
67 SO-42
DubStyle
SBS Hit Squad
DubStyle is offline
PostPosted: Thu Dec 06, 2012 5:39 pm    Post subject: Reply with quote
What about the bushing that guides the rod? I've seen that wear and the shifter not sit in the cup.
As far as welding skills... find a local VW guy with a welder and offer them some beer. That isn't that miuch work. Hell if I were near you I'd do it for FREE.
Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club"
oleflorida
PostPosted: Thu Dec 06, 2012 6:25 pm    Post subject: Reply with quote
This is a 67. It doesn't have the bushing guide (pre 64 I think) but the bushing is inside the rod that fits on the guide pin. I already changed that. Anyone have a pic of the part that the shifter housing bolts to? Looking for an above and below shot, with or without the floor.
Thanks for all the efforts.
Darren
67 SO-42
DubStyle
SBS Hit Squad
DubStyle is offline
PostPosted: Thu Dec 06, 2012 7:40 pm    Post subject: Reply with quote
Well according to WW yours has one, just further back.
Anthony
SBS #1
SBS #1 on FB
Derek Waycaster
Derek Waycaster is offline
PostPosted: Thu Dec 06, 2012 7:54 pm    Post subject: Reply with quote
Besides the above mentioned ideas, thoroughly check everything from front to back for wear/play. The shifter is limited in its travel ultimately by the shift shaft coming out of the nose cone, (provided everything else is tight) as it can only rotate so far to between 1&2 to 3&4. If the problem in fact is not your combination of parts up front, check the rest of the assembly to see what is allowing the shifter to go so far to one side or the other.
61 Turkis 11 window. Rough, patina'd, slammed, 2110, Fun.
68 Westy
71 SC (wrecked) 😢
72 SB stock daily cream puff
79 SB Vert project
vwserphguy
vwserphguy is offline
PostPosted: Thu Dec 06, 2012 9:55 pm    Post subject: Reply with quote
I just went through a similar process of dissecting my entire shifting system on my 58. After going through everything, and lots of trial and error, I found that any play in the system would not allow all gears to function or better yet find them all. My rear coupler was diffective and had a quarter inch of movement. The movement you have up front at the floor could be suspect. Research how the '67 assembles, etc and minimize any unwanted movement (such as the bolt that broke off). Hope that helps. Keep at it a little at a time. When you get it, the reward is great!
"Relax and just enjoy the ride knowing everybody passing is wishing they had one."
Eric&Barb
Eric&Barb is offline
PostPosted: Fri Dec 07, 2012 7:19 am    Post subject: Re: Shifter problem - please help evaluate my parts Reply with quote
oleflorida wrote:
How is the hole in the front of the shift rod that the bolt seats into??
There should be two rear shift rod bushings also.
In Stereo, Where Available!
Clara is offline
PostPosted: Fri Dec 07, 2012 9:26 am    Post subject: Reply with quote
Glad you got some bad pieces replaced.
The bottom of the floor looks like someone took a grinder and ground off some of the reinforcement.
The earlier (to ch 501 xxx) floors are not as reinforced there, and do tend to get cracks with lots of use. Then they flex. I think VW reinforced that area against cracking. Think that every time you shift gears the floor is acting as a fulcrum of a lever, the reinforcement is helpful. But some one cut a bunch of yours off with a grinder Sad so I can see how the floor could flex.
I'm just looking at that under floor pic and thinking WTF.
Then again, I have driven many miles in a 56 bus with flexy cracked floor, and decent shifting.
You need help installing the shifter... one person in the cab, another under the bus. Install the front nut & bolt first, and use BIG washers under the nuts.
or get it welded up right... but I'd try w/ big washers and help from a friend first.
oleflorida
PostPosted: Fri Dec 07, 2012 9:47 am    Post subject: Reply with quote
Thanks Clara. Good idea for a temporary solution. Now that you say it and I look at it you can see the grinder marks on the forward part under the e-brake Evil or Very Mad
What is this part even called? This is got to be the main part of the problem. The shifter housing was bolted to the floor, not to a support piece underneath. Is this going to require cutting the floor to even get access to that piece? Still would love a picture of the piece underneath. Might help me in a WTB ad. Ugh...
Darren
67 SO-42
BarryL is offline
PostPosted: Sat Dec 08, 2012 10:17 am    Post subject: Reply with quote
What Clara said will probably get you back in the saddle. Put fat fender washers under there under the nuts but you will need someone to put them on while you push down from the top. In your first post pic I saw what looked funky up there but then I saw the smooth metal and your smooth shift guide plate so I didn't figured I was seeing it wrong. That's definitly your problem why it's popping up. To do it all right you could try to get a donor floor area at the shifter area and have a body guy scarf in the piece but I bet you the washer system will work for a long time.
quartermilecamel
PostPosted: Sat Dec 08, 2012 2:37 pm    Post subject: Reply with quote
Im not all to sure what that areas supposed to look lilke but couldnt you just readd the missing material metal? Like cut out the floor section, weld metal in then tack the floor back in?
oleflorida
PostPosted: Sat Dec 08, 2012 3:28 pm    Post subject: Reply with quote
I'm still looking for a picture of what the piece actually looks like. Anyone? If I just weld a piece of metal to close the cut gap, I need to know where to put the nut to bolt down the shifter housing. Does it go on top, underneath or inside that piece of metal?
Darren
67 SO-42
Eric&Barb
PostPosted: Sat Dec 08, 2012 4:48 pm    Post subject: Re: Shifter problem - please help evaluate my parts Reply with quote
Bueller, Ferris Bueller... Wink
