Will this cause no reverse in my 57 SC
oldvolkz
oldvolkz is offline
PostPosted: Sat Dec 15, 2012 1:42 am    Post subject: Will this cause no reverse in my 57 SC Reply with quote
57 Single cab
later bus trans with RGB's and DP Enginge
Concept 1 Nose Cone Conversion Kit
I didnt do the conversion. I drove the SC and all 4 forward gears work great but reverse is hard to find but I find it here and there.
I decided to check the shifter stop plate and this is what I saw.
Would this cause no reverse.?
Where can I get a plate?
I know there interchangeable from bug to bus. But a 57 is old. Will any work for my SC?
"if you want peace, you must work for justice"
bubblehead
bubblehead is offline
PostPosted: Sat Dec 15, 2012 7:28 am    Post subject: Reply with quote
That's a common place for those to break. Pretty much one size fits all as far as replacement. And remember the longer/bent tab goes on the right side pointing
up.
G-wood Todd
G-wood Todd is offline
PostPosted: Sat Dec 15, 2012 11:33 am    Post subject: Reply with quote
Replacing the plate would be a good place to start. According to WW they are all the same. http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211711149
oldvolkz
oldvolkz is offline
PostPosted: Sat Dec 15, 2012 12:10 pm    Post subject: Reply with quote
Thanks guys. Going to get one asap.
PostPosted: Sat Dec 15, 2012 3:02 pm    Post subject: Reply with quote
I don't know if that would cause no reverse at all but that would definitely mess stuff up. I've had things not work right just from wear, let alone a broken plate.
Your plate has some clear wear too, along that same reverse lockout piece that is sticking up.
oldvolkz
oldvolkz is offline
PostPosted: Sat Dec 15, 2012 3:45 pm    Post subject: Reply with quote
I do have reverse (sometimes) its hard to find. I also don't have a front bushing.
Can I replace the bushing without removing the transmission?
cru62
cru62 is offline
PostPosted: Sat Dec 15, 2012 3:52 pm    Post subject: Reply with quote
The bushing may be causing more problems than the crack. And, yes, you can replace the front bushing w/o removing the engine. The front section is removable from the long shift rod.
FWIW Counselors/Therapists call what you did there "Door-Knobbing". It is where you talk about one problem for a while and then as you are leaving, with your hand on the door knob, you drop the bomb. Shoulda mentioned that one first! Wink
"My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
SkooobaSteve
SkooobaSteve is offline
PostPosted: Sat Dec 15, 2012 4:05 pm    Post subject: Reply with quote
The rear bushing on the other hand isn't as user friendly
Jonathan
Romans 6:13
WTB 67 beetle rear seat belts.
59 Euro ragtop build with my dad
http://www.thesamba.com/vw/forum/viewtopic.php?t=493553&postdays=0&postorder=asc&start=0
65 dlx Slow build
http://www.thesamba.com/vw/forum/viewtopic.php?t=391061
bugcollections
bugcollections is offline
PostPosted: Sat Dec 15, 2012 6:16 pm    Post subject: front bushing Reply with quote
Neither is the front one when you try to uncouple the front rod from the rear with that frozen collar that you will probably have to cut off.
oldvolkz
oldvolkz is offline
PostPosted: Sat Dec 15, 2012 6:46 pm    Post subject: Re: front bushing Reply with quote
Going to get all the bushings and collar if I have to cut it out.
Thanks Everett for the knowledge.
@cru62 just keeping you guys on your toes.
oldvolkz
oldvolkz is offline
PostPosted: Thu Dec 20, 2012 7:36 pm    Post subject: Reply with quote
Should the shifter be so in an angle like that? its on 1st gear in this picture. It has the concept 1 nose cone.
But I have reverse now. I installed a new bushing and clip plus the center shift rod coupler. I had to use the red urethane coupler. (for now) will get the WW coupler soon.
Coupler
Bushing & Clip
now to do the center pin
