1967 Reduction box torque spec
1105 is offline
PostPosted: Fri Apr 19, 2013 6:39 am    Post subject: 1967 Reduction box torque spec Reply with quote
Rebuliding 1967 reduction boxes. Does anyone know the torque spec for the the nut on the stub axel that holds the stub axel in the reduction box. Not the axel nut. Also the torque spec for the 8mm bolts that hole the reduction box case halves together.
Thanks for your help.
1105
hazetguy
hazetguy is offline
PostPosted: Fri Apr 19, 2013 8:48 am    Post subject: Reply with quote
41mm headed nut on driven axle: 150Nm (110 ft. lbs).
reduction box case cover bolts: i usually torque these to 25Nm (18 ft. lb).
1105
1105 is offline
PostPosted: Sun Apr 21, 2013 7:42 am    Post subject: Reply with quote
Dear Hazetguy,
Thank you for the reply.
Yours,
1105
