Chris_914 Samba Member
Joined: September 16, 2011 Posts: 344 Location: Las Vegas
Posted: Sat Jun 15, 2013 10:23 pm Post subject: Throttle Body Rebuild FAQ |
To link to this thread
Code: |
[url=https://www.thesamba.com/vw/forum/viewtopic.php?t=559556&start=0&postdays=0&postorder=asc&highlight=]Throttle Body Rebuild FAQ[/url] |
Took the plunge and had the throttle body rebuilt.
Saw some pictures of the work whip618 did on Vanagon T/B's and asked if he would do a bay T/B. He said yes so here's a shameless plug for the quality of his work. He rebuilt the shaft, bored it out for a new butterfly valve, made new butterfly valve, new seals, and cleaned all parts and plated the hardware. Simply put, 38 years of wear have been reset to better than factory specs. I say better because I know the assembly line didn't take near the attention to detail Phil did.
Take a look at whip618's gallery for other work Phil has done and my gallery for addition pics of my T/B.
Before:
After:
_________________ '75 Westfalia Camper FI 1.8L
'75 914 2.0L |
tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
curtis4085 Samba Member
Posted: Sun Jun 16, 2013 7:42 am Post subject: |
Wow please PM me Phils contact info? I would love to have mine redone. If you can please include cost and how it performs on your bus.
Thnk you for posting this. _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
rustbus Samba Member
Posted: Sun Jun 16, 2013 8:12 am Post subject: |
i had phil rebuild mine too a ear or two ago:
super high quality work, and nice to know that the worn out TB and butterfly valve can no longer be the source of any idle problems. _________________ May of '72 Deluxe. 2.0L L-Jet CS & 091 trans conversion
my Bus thread |
Posted: Sun Jun 16, 2013 8:44 am Post subject: |
Did I miss Phil's contact info?? Would love to have mine done. Very nice quality work. _________________ Special Thanks to:
1975 Kombi Samba Member
Joined: August 12, 2007 Posts: 2459 Location: Acton, Ontario, Canada
Posted: Tue Aug 06, 2013 8:33 am Post subject: |
How did whip redo the top throttle shaft bushing/seal mount. The OG bushing is no longer available so a mod is necessary to seal the shaft. Did he resize the seal mount for a new available bushing/seal?? _________________ Brett
“He’s decieving you boy! Reach into his pocket and take what he’s got.” Mr. Crabbs.
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
2011 Touareg TDI
2001 NB TDI
Licensed pilot (single engine land VFR)
Rust In Pieces: 72 Bug, 73 Bug, 81 Rabbit LS D 2D, 83 Rabbit D 2D, 84 Jetta TD GL, 85 Jetta D, 68 Z28 RS 302, 91 Passat 16v
webwalker Samba Member
Joined: January 26, 2006 Posts: 2803 Location: Mount Laurel, NJ
Posted: Tue Aug 06, 2013 9:12 am Post subject: |
How many megabux was it? Deep into three figures?
M _________________ "Consistent maintenance with quality products is the cheapest warranty you'll ever need."
1977 CE1 Transporter Deluxe, Subaru EJ22, Skills Cooling, Steedle HD 091 w/ GuardT .82 4th
Click to view image |
Randy in Maine Samba Member
Posted: Tue Aug 06, 2013 10:14 am Post subject: |
Everything was touched and made better than new.
Your looking at around 3 bills, need to contact for specifics.
He is a top quality machinist who is tooled for and familar with building these. _________________ '75 Westfalia Camper FI 1.8L
'75 914 2.0L |
Tcash Samba Member
Joined: July 20, 2011 Posts: 12846 Location: San Jose, California, USA
Posted: Thu Aug 31, 2017 8:14 am Post subject: Re: Throttle Body Rebuild |
025 133 073 Throttle Body to Intake Plenum Seal
022 133 069 Throttle Body Shaft Seal
whip618 wrote: |
You are probably suffering from a worn throttle body. VW did a poor job of design on these throttle bodies and as result they wear to the point of a sticky throttle at best and to an uncontrollable idle with very poor drive-ability at worst.
The throttle shaft and throttle plate being unsupported in the vertical position will actually wear into each other causing the excess gap between the throttle plate and bore of the throttle body with no way to really repair it without exchanging it for one with less wear or going to complete new re-machined throttle body that will not wear out.
This is photo of a 2.1 water cooled throttle body that has been back lit to emphasize the gap between throttle plate and throttle bore
This image is of a re-machined air-cooled throttle body, for proper operation you would want yours to look more like this.
whip618 wrote: |
To help put a little finer point on what busdaddy said about the throttle binding when the idle screw has been turned in to far I have included a picture that shows the wear that occurs in the throttle bore from the throttle plate opening and closing while rubbing on the bottom of the throttle bore.
With this amount of wear it is easy to visualize the air gap that would be present at the top of the throttle plate when in the idle position so if the idle air screw were turned in until it almost touched the throttle plate in this position it would certainly bind the throttle because the throttle plate in order to turn must first climb up out of this groove which sometimes are as much .030 deep so in that upward climb it would bind against the air screw.
on my rebuilds I machine the bore and the throttle plate to a radial clearance of.0015 so with the throttle shaft locked in the vertical position this produces a very stable idle that will not change over time.
Phil |
whip618 wrote: |
Steve, I have quit a few of these seals in good used condition if you need some.
I remove these on the 2.1 throttle body's that I rebuild and replace them with an inch equivalent seal except that the OD is several thousandths over and I have to bore the throttle body anyway for a bearing so I just open up the seal counterbore at the same time so they are concentric
Phil |
djkeev wrote: |
Here you go, perfect fit!
Harwal (That's why I included the package in the photo, company ID and item description)
This office was in Vermont but they have others. You do need to purchase from a distributor.
In my case it was Motion Industries in Teterboro NJ.
Harwal will tell you who is nearby if you call them.
The OG VW/Audi product is single lipped too.
Fact is......
These are better, a single lip with a shaft tensioning spring.
Dave |
obnoxiousblue Samba Member
Joined: February 21, 2007 Posts: 3027 Location: East Northport, NY
Posted: Tue Sep 05, 2017 4:24 pm Post subject: Re: Throttle Body Rebuild FAQ |
Phil is building me a new TB now. I can't control my idle consistently from one minute to the next. I've never separated the Tab from the intake. Is it really as simple as disconnect the cable, unscrew the two Phillips heads and remove it from the car?
When reinstalling, just put the seal on screw it in, and reconnect the cables?
I'm sure I'm missing something - any words of wisdom before I tackle the project? _________________ Mike
1964 Beetle
2001 Eurovan Camper |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23155 Location: Oklahoma City
Posted: Tue Sep 05, 2017 5:45 pm Post subject: Re: Throttle Body Rebuild FAQ |
obnoxiousblue wrote: |
I'm sure I'm missing something - any words of wisdom before I tackle the project? |
Pretty much!
I get much better results with the TB fitted seal/o-ring by carefully putting a VERY thin smear of high temp, oil proof RTV like permatex ultra.....on the tB side of the seal. Mount it up to the TB. Use something that will hold the seal in exact position until the RTV is conpletely cured.
I'm lucky....I have several plenums. I bolt the TB to a spare plenum to dry. I carefully open the plate and clean up any little bit of RTV that squeezes out.
Then carefully clean the plenum opening so its smooth. Repaint if necessary.
Then install the TB. Much better seal positioning. Ray |
Posted: Tue Sep 05, 2017 5:51 pm Post subject: Re: Throttle Body Rebuild FAQ |
Great thanks Ray! I'm thinking since I dont have a spare plenum I could probably use something just to secure it in place. _________________ Mike
1964 Beetle
Posted: Tue Sep 05, 2017 8:03 pm Post subject: Re: Throttle Body Rebuild FAQ |
Great thanks Ray! I'm thinking since I dont have a spare plenum I could probably use something just to secure it in place. |
The late seal kind of has a stepped/ribbed OD.
Anything cone shaped with a,weight,will do to put in the center to hold it in contact. Ray |
Posted: Mon Sep 18, 2017 8:06 pm Post subject: Re: Throttle Body Rebuild FAQ |
So while I can't yet confirm it is THE problem, I'm certain that the play in my Tab is A problem. A friend let me play with his and it didn't move around like mine did. The rebuilt one is on its way from Phil.
Is there anything special to the install here, or is it really as easy as the two screws and the cable? Any settings or anything that need to be adjusted beyond the obvious idle screw? _________________ Mike
1964 Beetle
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52829 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Sep 18, 2017 8:42 pm Post subject: Re: Throttle Body Rebuild FAQ |
No, the 2 screws and the cable adjustment along with any attached vacuum lines is all there is, and reinstalling the S boot and an idle adjustment of course.
A friend let me play with his and it didn't move around like mine did. |
You really should proof read your posts, that statement leaves you wide open for many potential derails  _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Sep 18, 2017 9:13 pm Post subject: Re: Throttle Body Rebuild FAQ |
busdaddy wrote: |
You really should proof read your posts, that statement leaves you wide open for many potential derails  |
Sounds like a technique issue......or lack of lubricant......just sayin....
Ray |
Tcash Samba Member
Posted: Tue Sep 19, 2017 6:55 am Post subject: Re: Throttle Body Seal |
Karl wrote: |
What is still available is the late Vanagon gasket, 025 133 073. It
looks very similar in size and shape with the only differences I can
see being that it has more ribs along the circumference and the 3
small cutouts at the perimeter are missing.
022 133 073A 2L Type 2 76-79, Vanagon 80-85
025 133 073 Vanagon 86-up
mlbegley Samba Member
Posted: Wed Aug 24, 2022 10:44 am Post subject: Re: Throttle Body Rebuild FAQ |
Reviving an old thread, as my bus is also suffering from a worn throttle body and needs a rebuilt unit. I reached out to Phil but he is no longer doing this work.
Anyone have recommendations for where I could get a rebuilt throttle body, or have mine rebuilt?
Thanks! |
vwmerckx  Samba Member
Joined: August 12, 2012 Posts: 240 Location: Phoenix, AZ
