slight misfire when hot
vanagonjr
vanagonjr is offline
PostPosted: Fri Sep 27, 2013 4:56 pm    Post subject: slight misfire when hot Reply with quote
My vans seems to run just a bit off after cruising for an extended period of time, say 3 or more hours. Misfire is actually too severe a term; it just doesn't seem quite as smooth as it is in the morning. I definitely will notice how well the engine runs the next morning on a trip for example. Note, my coolant temp is fine.
Van has new NGK plugs, OEM wires, new Bosch rebuilt dizzy and a new Bosch coil, as well as recent Bosch cap and rotor, so it seems that the ignition system should be A-OK. Timing set per TenCent's method. I checked for vacuum leaks, spraying brake cleaner (although engine was cold) and did not find any - but I am still think that is a possibility.
The blue coolant temp sensor was replaced 6 years and perhaps 10-15,000 miles ago.
Any thoughts on what to check?
vanagonjr
PostPosted: Mon Sep 30, 2013 9:35 am    Post subject: Reply with quote
Forgot to add van/engine details Embarassed
1986, 2.1, 4-speed, P/s No AC.
djkeev
djkeev is offline
PostPosted: Mon Sep 30, 2013 9:52 am    Post subject: Reply with quote
Check for an intake or vacuum line leak when hot.
Dave
Ghia
Vanagon
Beetle
