Steering box removal question?
T3man
T3man is offline
PostPosted: Sun Feb 16, 2014 8:07 pm    Post subject: Steering box removal question? Reply with quote
How high do you have to get the bus off the ground to remove the steering box in a 63 bus?
1962 Blue notchback n model
1964 White Variant S Type 3 Squareback Euro
1966 Blue sunroof fastback
1969 Bahama Yellow camper bus
2170 Silver Alien space ship. Leaks Nuclear waste!
ezcamper
ezcamper is offline
PostPosted: Sun Feb 16, 2014 9:41 pm    Post subject: Reply with quote
I used steel drive up ramps....I guess about 10-12"
I make HWE style roof racks, Jim-Dandy racks, SO-33 metal parts, Dormobile racks, HWE style ladders, engine crank start handles, Westy rack tags, Binz tags, Sundial badges, State of California tags, steering lock electrical covers and single / double cab gate latch friction blocks.
instagram is http://instagram.com/bullidriversteelworks
j.pickens
j.pickens is offline
PostPosted: Sun Feb 16, 2014 9:50 pm    Post subject: Reply with quote
Also, MUCH easier with two people, one inside the bus, one underneath.
BeaterBarndoor wrote:
Red Fau Veh wrote:
T3man
T3man is offline
PostPosted: Mon Feb 17, 2014 7:11 am    Post subject: Reply with quote
10-12" sounds low, any others would like to give there imput.
ezcamper
ezcamper is offline
PostPosted: Mon Feb 17, 2014 7:38 am    Post subject: Reply with quote
Oh, my bus is stock height too.
grey60
grey60 is offline
PostPosted: Mon Feb 17, 2014 11:21 am    Post subject: Reply with quote
My bus is 3.5-in lowered all around (flipped spindles, no RGBs). When I pulled the column, I used these:
http://www.harborfreight.com/magnum-16000-auto-ramp-set-with-built-in-safety-chock-67722.html
and a couple of these:
http://www.craftsman.com/craftsman-3-ton-high-lift...ockType=G6
The plastic block/ramps were really just for added safety -- plus, I had a floor jack under the beam, ALSO.
The jacks were way high -- like, maybe I've got 18-in or thereabouts to move around under there. Even at that, there was still a bit of 'angling' involved after disconnecting everything and lowering it. Did it all by myself.
1960 grey panel
brettsvw
brettsvw is offline
PostPosted: Mon Feb 17, 2014 3:17 pm    Post subject: Reply with quote
In a pinch I used a set of ramps and dug a hole in the ground.
My 59 kombi build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=635003&highlight=
My buggy build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=558601&highlight=
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807
T3man
T3man is offline
PostPosted: Mon Feb 17, 2014 6:00 pm    Post subject: Steering Reply with quote
My bus is lowered too, So I guest I will start the work this weekend.
Thanks for the info.
pyrOman
Fire Master
pyrOman is offline
PostPosted: Tue Feb 18, 2014 8:23 am    Post subject: Reply with quote
Removing the driver's seat will give you more room and need less lift of the bus! Wink
70bus Premium Member
70bus is offline
PostPosted: Mon Jun 02, 2025 7:26 pm    Post subject: Re: Steering box removal question? Reply with quote
Gonna ask here to keep info in one place... so consensus from a few threads is you need about 22 - 24" off the ground to remove steering column; take out seat first and have a helper - but how far do you need clearance at the FRONT of the bus? Or can you slide it out from the side once it clears the body?
My garage is, uh, small, and I have maybe 10" at front and 8" at back leeway; after that, I am out on a sloped sidewalk that I can't leave blocked for long. I'm mostly worried that the front jacked way up and the rears on an angled surface will be bad juju.
Street is also sloped and a bit crowded, tho if I use it I do have a sewer grate across from garage I can drop the box into!
Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater
matthew henricks
matthew henricks is offline
PostPosted: Tue Jun 03, 2025 7:05 am    Post subject: Re: Steering box removal question? Reply with quote
I think you will find the the distance in front of the bus is proportional to how high you lift it. At some point you can tilt the box but the hole in the floor pan does not allow that much tilt. My recollection is that it did not matter going straight out the front or to the side. I just needed height.
Also wrap your column as your going to scratch it up unless as a kit your were the expert at the game operation.
1964 Original Owner build Thread. https://www.thesamba.com/vw/forum/viewtopic.php?t=702135&highlight=
Ambulance Fan's. https://www.thesamba.com/vw/forum/viewtopic.php?t=627707&highlight=
Parts i am looking for:
64 bug nice used front/rear Black LHD floor mat.
70bus is offline
PostPosted: Wed Jun 11, 2025 7:24 pm    Post subject: Re: Steering box removal question? Reply with quote
Distance from bottom of valence to floor - 20"
Distance from front of valence to wall - 20"
Column just squeaked out of the floor with those distances. Getting it in might be a bit harder, as i won't want to scrape freshly- painted box along floor!
Craig K
70 Neunsitzer
65 Pritschenwagen
BarryL Premium Member
BarryL is offline
PostPosted: Thu Jun 12, 2025 6:13 pm    Post subject: Re: Steering box removal question? Reply with quote
Is that raised to that height or what-you-see-is-what-you-get?
70bus is offline
PostPosted: Thu Jun 12, 2025 8:40 pm    Post subject: Re: Steering box removal question? Reply with quote
I measured from the floor of garage to bottom of the valence, right behind the bumper. Same with distance from garage wall. This was with truck jacked up using the front axle; I was using the hypotenuse to get a few extra inches of travel. Bare minimum, if you can safely get 22" height go for it.
Craig K
70 Neunsitzer
65 Pritschenwagen
