Tips for removing rear fiberglass bumper cover
jwendorf
jwendorf is offline
PostPosted: Mon Apr 28, 2014 12:14 pm    Post subject: Tips for removing rear fiberglass bumper cover Reply with quote
I have removed the four bolts that hold the rear fiberglass bumper cover onto my '89 carat (two behind wheel wells, two above the tow clips), however the thing won't budge.
Anything else I should be checking here?
D Clymer
D Clymer is offline
PostPosted: Mon Apr 28, 2014 12:17 pm    Post subject: Reply with quote
You have to remove the two bolts on each frame rail that hold the bumper bracket to the frame rail. That actually isn't a bumper cover - it's the whole bumper, so the brackets are bolted directly to it. Once those big bolts are out, the whole bumper will slide out. There are additional bolts on the inside of the bumper that you can't see when it is mounted.
Dave
K58
K58 is offline
PostPosted: Mon Apr 28, 2014 12:32 pm    Post subject: Reply with quote
bumper cover...lol
yeah, believe it or not that pos made it past DOT and NHSTA
were you able to remove it?
Westy HID Projector Retrofit
j_dirge
j_dirge is offline
PostPosted: Mon Apr 28, 2014 12:38 pm    Post subject: Reply with quote
Yep.
And just to clarify.
There are 4 large bolts (2 each side) in the frame members (can be seen from under side near the wheel well).
These attach to brackets that slide INTO the frame members (bolted to the from inside).. the brackets slide out with the bumper AFTER you detach the items below...
There are two bolts (one each) side that attach end caps to side brackets bolted up on the inside body panel..
AND, there are two smaller, kinda rinky-dink, brackets (one each side) that are visible from under the bumper just behind the rear wheels.. these are secondary side brackets that help align and stiffen the assembly when bolted to the van.. These two also manage to slice my knuckles up almost every time I have to deal with them.
If the bumper won't budge?
You've missed one of these.
-89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote:
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
madspaniard
madspaniard is offline
PostPosted: Mon Apr 28, 2014 1:34 pm    Post subject: Reply with quote
j_dirge wrote:
Yep.
gosh I have done this so many times I think I can do it blindfolded
j_dirge
j_dirge is offline
PostPosted: Mon Apr 28, 2014 1:53 pm    Post subject: Reply with quote
No doubt, eh?
I've done it so many times I have left a few bolts off, figuring I'd just be doing it again, soon enough. Laughing
jAndrew
jAndrew is offline
PostPosted: Fri Nov 20, 2020 11:54 am    Post subject: Re: Tips for removing rear fiberglass bumper cover Reply with quote
I know, it's an old thread. It would seem, from the lack of threads that came up in a search, that I am the only one ever to have trouble getting the bumper off.
Anyone have issues with getting the bumper off a Doka? I've taken the 2 bolts that hold it to the frame and it moves up and down a centimeter when I pull up and down on the hitch but that's about it.
I know there isn't anything else holding it that I can see and it looks like it should just pull back but nothing so far. I will attach it to a hand winch and see if I can't pull it off.
But nothing different on a Syncro Doka I might have missed?
ALIKA T3
ALIKA T3 is offline
PostPosted: Fri Nov 20, 2020 12:07 pm    Post subject: Re: Tips for removing rear fiberglass bumper cover Reply with quote
The tow bars have a 3rd bolt further up on the frame Wink
jAndrew
jAndrew is offline
PostPosted: Fri Nov 20, 2020 2:50 pm    Post subject: Re: Tips for removing rear fiberglass bumper cover Reply with quote
Doh! Came right out. I thought the bolts were just fillers for something else. Now getting that new plate steel bumper in is proving difficult. Those holes just do not want to line up. Will use a little force with the floor jack to hold it up.
djkeev
djkeev is offline
PostPosted: Mon Apr 19, 2021 5:14 am    Post subject: Re: Tips for removing rear fiberglass bumper cover Reply with quote
Great thread!
Puzzle solved!
Thanks!
I added this thread to the FAQ section.
Also a parts drawing to help understand the assembly.....
Dave
Ghia
Vanagon
Beetle
mikemtnbike
mikemtnbike is offline
PostPosted: Mon Apr 19, 2021 8:15 am    Post subject: Re: Tips for removing rear fiberglass bumper cover Reply with quote
If, like me, you find yourself with one of the fiberglass supports in which the buried bolts are mounted in a damaged beyond repair state, you can replace it a thru bolt, I used PVC pipe as a spacer to mimic the length of the fiberglass brace so that I had a stop to prevent myself from over-torqueing the bolt and crushing my bumper. Also, make sure there is a large fender washer on both sides of the bumper.
Trust me that all makes sense and will be helpful if somebody visits this thread with the same problem or finds the problem when s/he removes the bumper.
2020 GTI SE manual
dasilva
dasilva is offline
PostPosted: Wed May 12, 2021 2:32 pm    Post subject: Re: Tips for removing rear fiberglass bumper cover Reply with quote
Upon removing my bumper, the bolts sheared off. Pics attached.
From Dave's drawing, I think I need to try to remove the whole 'loop' assembly (number 1) by attacking fasteners 4 and 6.
To date, heat, PB Blaster and a speed out have all failed me!
mikemtnbike, what size PVC pipe were you using?
DuncanS
DuncanS is offline
PostPosted: Wed May 12, 2021 4:16 pm    Post subject: Re: Tips for removing rear fiberglass bumper cover Reply with quote
Bolt #4 goes into a brass/bronze insert which is molded into the fiberglass bumper. #6 goers into a welded nut on the bumper bracket. I think this is true, as I completely rebuilt my old bumper last Christmas. Usually what happens is the bronze insert separates from the bolt leaving a serious mess. It is easy to take a stainless nut and just rebuild the mounting point using JB Weld for epoxy. You can make patterns fro the spacing from the mating members and get them in the right spot. It's fussy and takes time, but is not hard work at all. With the bolt into the bumper bracket, drill it out and retap and use a 'Mercan bolt.
As far as I can tell, the bolts on the side pieces that connect to the body work are really there to trash the body tin in the event of a slight nudge. They sure are good at that.
D
kamzcab86
kamzcab86 is offline
PostPosted: Thu May 13, 2021 12:07 am    Post subject: Re: Tips for removing rear fiberglass bumper cover Reply with quote
To remove the bumper carriers (brackets), you need to remove the 4 bolts (2 per bracket) holding them to the frame... #7 in this illustration (oddly, not shown in the fiberglass version):
Edit: Image link broken. See the new illustration below.
2016 Golf GTI S
mikemtnbike
PostPosted: Thu May 13, 2021 3:10 am    Post subject: Re: Tips for removing rear fiberglass bumper cover Reply with quote
1/2" or 3/4" whichever I had on hand. Pretty sure it wad 1/2". Just something for the bolt shaft to pass through and to act as a stop. I can take a picture of how this looks from the outside much later today if you want.
2020 GTI SE manual
djkeev
djkeev is offline
PostPosted: Thu May 13, 2021 3:29 am    Post subject: Re: Tips for removing rear fiberglass bumper cover Reply with quote
When you remove the fiberglass bumper you are leaving it attached to the mounting brackets.
Unbolt the brackets from the frame.
Here are the brackets, you can see each one has provision fir two bolts.
Dave
Ghia
Vanagon
Beetle
dasilva
dasilva is offline
PostPosted: Thu May 13, 2021 11:06 am    Post subject: Re: Tips for removing rear fiberglass bumper cover Reply with quote
You guys are such a great resource! I'm hopefully back to work on the van on Friday. I'll report my progress
heynanc
heynanc is offline
PostPosted: Fri Mar 03, 2023 9:37 am    Post subject: Re: Tips for removing rear fiberglass bumper cover Reply with quote
Many thanks to all of the contributors to this thread, including the person who asked the question in the first place!! Today I am battling the rear bumper on an 89 Carat. Every time I think I am unbolting the last bolt, there are more.
Heading out to look for those ones inside above the tow loop bracket.
Nancy
2016 Subaru Outback daily driver
1984 Westfailia Vanagon EJ22 “ Guinness”
2006 Dodge Sprinter 2500
VicVan Premium Member
VicVan is offline
PostPosted: Fri Mar 03, 2023 11:53 am    Post subject: Re: Tips for removing rear fiberglass bumper cover Reply with quote
I have a particularly fond memory of bolt #17 on the diagram above. Fun times.
'90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH)
kamzcab86
PostPosted: Fri Mar 03, 2023 11:57 am    Post subject: Re: Tips for removing rear fiberglass bumper cover Reply with quote
Since 7zap is down, and it irritates me that VW's diagram is missing the two bracket bolts, I've done some illustration updating:
2016 Golf GTI S
