DUELLER Samba Member
Posted: Mon Jul 07, 2014 7:06 pm Post subject: Rev limiter bad? |
Anyone ever had a Bosch rev limiter go bad? Mine is a 6200rpm and it has started cutting out around 4000rpm. It is only 2 years old and i have only hit that 6200 mark a couple of times.....seriously a couple of times. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79583 Location: Sneaking up behind you
Posted: Mon Jul 07, 2014 7:17 pm Post subject: |
There's a spring that controls the rpm range. I guess your spring is bad. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15601 Location: Deep in the 405
Posted: Mon Jul 07, 2014 8:06 pm Post subject: |
Yes they wear out and must be replaced just like a regular rotor. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Mon Jul 07, 2014 9:20 pm Post subject: |
Soooooo. If the spring is bad, can just the spring be replaced? |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20816 Location: Just a tiny bit west of Yosemite Valley
Posted: Tue Jul 08, 2014 5:59 am Post subject: |
DUELLER wrote: |
Spring is calibrated.... Change spring and it changes what rpm limiting takes place. springs counters centrifugal force of plunger in rotor... Example is you spring is either stretched or gone soft (worn out) and now it limits at a lower rpm... Stiffer spring will move range of limit upwards, and to stiff spring will make it so there is no limiting...
Other possibility is rotor material is breaking down and allowing arc to travel to ground of dist shaft, inspect rotor body for cracks or arc trails...
Dale _________________ “Fear The Government That Wants To Take Your Guns"
