Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Wed Jul 16, 2014 8:02 am Post subject: Bad wheel cylinder? |
I replaced my brakes completely, front to back. I have one rear wheel that every time I bleed that brake, it gives me air. I've gone over all the connections and there is no visible leakage. Brakes work fine, but pedal distance is further down than I'd like. The distance the pedal travels doesn't seem to increase over time. The other rear wheel cylinder never gives me air, just fluid. This one, always a puff of air when I have someone step on the brake pedal and I bleed it with a hose. Should I assume its the wheel cylinder drawing in air? _________________ 1958 Karmann Ghia owner |
PJ_1600 Samba Member
Joined: June 30, 2008 Posts: 149 Location: Edmonton, Alberta, Canada
Posted: Wed Jul 16, 2014 10:15 am Post subject: |
| Sometimes there is a stubborn pocket of air that just takes a lot a time and bleeding to get out. I've found that sometimes leaving it sit for a day or two will result in the air moving up and then a round or two will expel it. Another thing it to be sure all your shoes are turned out to the point where you can just barely (or not) turn your wheels by hand to maximize fluid space in the system - this will also help expel air. Lastly, if none of these work it could be a bad wheel cylinder. I've had that happen too when I (unknowingly) bought inferior (MiC) parts. I then got German made from WW and had no problems. Good luck. |
Posted: Wed Jul 16, 2014 10:20 am Post subject: |
My theory is that air is leaking in somehow. I figure that because after I expel air from the suspect wheel cylinder, the pedal doesn't get any higher. I'd expect that with every bit of air I get out, the pedal should come up. What do you think of that theory? The brakes work fine, I can make them squeal if I stop hard. Fronts are converted to discs. _________________ 1958 Karmann Ghia owner |
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3543 Location: Houston, TX
Posted: Wed Jul 16, 2014 10:40 am Post subject: |
| Northof49 wrote: |
| My theory is that air is leaking in somehow. I figure that because after I expel air from the suspect wheel cylinder, the pedal doesn't get any higher. I'd expect that with every bit of air I get out, the pedal should come up. What do you think of that theory? The brakes work fine, I can make them squeal if I stop hard. Fronts are converted to discs. |
Sounds like you got a Dud Wheel cylinder.
Are you cracking the bleeder open no more than 1/8-1/4 a turn?
Any more and you will get air past the bleeder threads
Although, I noticed I had a ton of air in my rear circuit, it was due to my MC blowing the rear seal out, letting air in, and brake fluid out into the frame tunnel. (noticed low brake fluid)
But since your brake fluid is the same, you may have a dud wheel cylinder.
Oh and:
Do this.
Pull the E-brake up as hard as you can.
Now Feel the brake pedal with your foot.
Does it feel firmer? If so, your rear brake pads need to be adjusted.
(let go of the e-brake and adjust the rear brake pads)
that's what I noticed for a "lowish" brake pedal for mine
I have from disks too. _________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
Posted: Wed Jul 16, 2014 11:17 am Post subject: |
Parking brake has no effect on my pedal. I have to try something, so it's a 20 dollar gamble to replace it. The right rear, when treated the same way, no air. I worry it's something to do with the junction block at the rear, but I can't find any leaking fluid there. _________________ 1958 Karmann Ghia owner |
Posted: Wed Jul 16, 2014 11:18 am Post subject: |
| Northof49 wrote: |
| Parking brake has no effect on my pedal. I have to try something, so it's a 20 dollar gamble to replace it. The right rear, when treated the same way, no air. I worry it's something to do with the junction block at the rear, but I can't find any leaking fluid there. |
What brand of wheel cylinder did you choose?
I found good luck with the FTE/ATE brand. Its all I will ever use for brake parts from now on.
check your brake light switches on your MC, if they are leaking they can let air into the system.. _________________ (Owner) www.vintagecarleds.com
1966 Ghia (sold)
1966 Red Beetle |
Posted: Wed Jul 16, 2014 11:31 am Post subject: |
I can't recall what brand I bought. I bought them from CIP. I'm re-using my old, probably circa 1973 brake light switches. Still working! _________________ 1958 Karmann Ghia owner |
BUGGED11111 Samba Member
Joined: February 03, 2006 Posts: 1828 Location: Oregon
Posted: Wed Jul 16, 2014 11:41 am Post subject: |
If you have a cylinder handy I would just swap it and see how it goes.
I agree on the bleeder valves mentioned. I've had fussy ones that if I opened more than an 1/8 turn it would suck air and produce bubbles. |
Posted: Wed Jul 16, 2014 11:50 am Post subject: |
| I gave up on the wheel cyls from CIP1 after getting two that leaked badly. Now pay the higher cost for German from WW. Ditto on bleeder screw more than 18th turn too. |
Posted: Wed Jul 16, 2014 11:51 am Post subject: |
I guess I can't rule out that its air coming in the bleeder valve when its cracked open. I do only open it about 1/8th of a turn. _________________ 1958 Karmann Ghia owner |
wcfvw69 Samba Purist
Posted: Wed Jul 16, 2014 3:57 pm Post subject: |
How are you bleeding them? With the pedal or a power bleeder or a suction bleeder? Suction bleeders can pull the inner rubber cups over in the wheel cylinders. I've seen that before.
I use a power bleeder now and it pushes ALL the air out fairly quickly. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Wed Jul 16, 2014 6:08 pm Post subject: |
I am bleeding using an assistant to press the brake pedal, while I crack open the bleeder for a short burst. _________________ 1958 Karmann Ghia owner |
Rene60 Samba Member
Joined: December 18, 2012 Posts: 118 Location: Crescent City Ca.
Posted: Wed Jul 16, 2014 8:03 pm Post subject: |
| I had a front wheel cylinder do the same thing. It wasn't leaking or showing any signs of leaking. I replaced it and that fixed the problem. |
Rene60 Samba Member
Posted: Wed Jul 16, 2014 8:04 pm Post subject: |
alexvw Samba Member
Joined: February 03, 2011 Posts: 1023 Location: Hales Corners, Wisconsin
Posted: Wed Jul 16, 2014 8:07 pm Post subject: |
Have the helper press pedal 4 times, and hold it. While they hold the pedal crack the bleeder and let air out. If this doesnt work you may want to invest in a bleeder tool that pushes fluid through the bleeder screw up to the master cylinder. It will push all the air out through the reservoir. _________________ 1995 Mitsubishi 3000GT SL
1974 Volkswagen Superbeetle( Mitsubishi 4G63T Swap in Progress )
http://www.thesamba.com/vw/forum/viewtopic.php?t=575769&highlight= |
Hyperspace Samba Member
Joined: January 03, 2013 Posts: 1166 Location: South Africa
