Awesome tool - Harbor freight engine support beam!
RocketBox
RocketBox is offline
PostPosted: Wed Sep 24, 2014 7:36 am    Post subject: Awesome tool - Harbor freight engine support beam! Reply with quote
i was looking into getting an engine hoist, but really hated the idea of storing such a bulky thing. I then found a Engine Support beam that Harbor Freight sells. They didn't have any on display, but the local store had them in stock. I just used it for dropping and raising the engine and I gotta say that this makes the job SOOOO much better compared to jacking and muscling the engine around and lowering transmission and all the other crazy stuff i had to do the first time i installed the engine. I've seen some home made ones, but for the cost and time it saved me, i thought it was a great investment.
It's this guy: http://www.harborfreight.com/1000-lb-capacity-engine-support-bar-96524.html
Just thought i'd share the experience of using this thing...
84 Vanagon - tintop, 1.9L wbx. Complete Rebuild done August 2014. 2000~ miles on it so far... SOLD
80 Vanagon Camper ASI Riveria - subaru 2.2 conversion project. 1993 Subary legacy donor car + Riveria = AWESOME!
Gnarlodious Premium Member
Gnarlodious is offline
PostPosted: Wed Sep 24, 2014 7:44 am    Post subject: Reply with quote
You should post this in the "Official Harbor Freight win or lose thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=512248
Are you saying it bridges the deck to hold up the engine? Looks like a good product for Vanagons! Post a photo in use.
RocketBox
PostPosted: Wed Sep 24, 2014 8:28 am    Post subject: Reply with quote
yeah - it spans the engine bay nicely. here it is in action...
raising and lowering done using the threaded 'hooks'. i liked the fact that you can move the engine forward and backward as the beam has a channel that the hooks ride in. each hook is about 16 inches long - long enough if your van isn't raised up on jacks to get it into place without having to reset in mid-lift. It also makes the engle adjustment easy to get the bolts lined up between the transmission and engine.
I'll post it in the HFT - win/loose also
williamM
williamM is offline
PostPosted: Wed Sep 24, 2014 8:54 am    Post subject: Reply with quote
Or 2 cinder blocks and a water pipe.- old school/shade tree- and you don't need a hook for the wall to store it.
some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
?Waldo?
?Waldo? is offline
PostPosted: Wed Sep 24, 2014 9:52 am    Post subject: Reply with quote
I've used this to R+R quite a few vanagon engines in the last decade:
dobryan Premium Member
dobryan is offline
PostPosted: Wed Sep 24, 2014 9:54 am    Post subject: Reply with quote
^^^ Cool, where can I get that disembodied hand to help me on my projects? Wink
Dave O
Traveling after Building a bus for travel in Europe (euroBus)
The Western Syncro build
campism
campism is offline
PostPosted: Wed Sep 24, 2014 10:05 am    Post subject: Reply with quote
dobryan wrote:
^^^ Cool, where can I get that disembodied hand to help me on my projects? :wink:
Bicycle repair has long featured tools named Third Hand and Fourth Hand for brake repair. Probably the same thing, only different.
danfromsyr
danfromsyr is offline
PostPosted: Wed Sep 24, 2014 10:07 am    Post subject: Reply with quote
certainly looks safer than the metal sawhorse.
Abscate wrote:
RocketBox
PostPosted: Wed Sep 24, 2014 10:51 am    Post subject: Reply with quote
i was totally considering both those options.... matter of fact - i had purchased the metal sawhorses for the same damn thing, then did some searching and found the beam. I also considered the 2x4 option too... but thought it would take me 3x as long to build it and it wouldn't be as stable and it would have cost about 1/2 the price...
in the end, i think it is a pretty good tool for droping and lifting a vanagon engine if you don't have and want a hoist.
?Waldo?
?Waldo? is offline
PostPosted: Wed Sep 24, 2014 10:58 am    Post subject: Reply with quote
If you are talking about my 2x4/allthread version, it is completely 100% stable, cost about $15 and took 1/2hr to make or an hour if you include the trip to get the materials. The three attachment points and the ability to slide the upper 2x4s means that you can achieve any desired angle/position and have it completely stable. That makes aligning the input shaft/clutch very easy. The metal sawhorse or single ratchet strap both look terribly dysfunctional in comparison. The HF support you used looks almost as nicely functional as my 3-point "hoist".
sanchius Premium Member
sanchius is offline
PostPosted: Wed Sep 24, 2014 3:21 pm    Post subject: Reply with quote
Yeah, I'm always recommending this thing.
I have a lot of confidence in those twin steel beams, much more than I would in some 2x4's.
If I'm going to have my head under a couple hundred pounds of engine and transmission, I'm not going to mess around to save $60.
http://www.thesamba.com/vw/forum/viewtopic.php?p=6864986#6864986
http://www.thesamba.com/vw/forum/viewtopic.php?p=6916550#6916550
The Syncro years (2005-16) - The 2WD years (2017-23) - In Hoosierland (2023-now)
Westy & WBX rebuild spreadsheet - Sanchius & Tuna: The Video
Your gold star membership keeps this awesome list going!
Merian
Merian is offline
PostPosted: Wed Sep 24, 2014 4:05 pm    Post subject: Reply with quote
but you will need a really good trauma surgeon after catastrophic failure of the cinder blocks under compression
?Waldo?
?Waldo? is offline
PostPosted: Wed Sep 24, 2014 6:01 pm    Post subject: Reply with quote
The twin steel beams are fine, but they sure aren't the weakest part of that tool and whatever tool you use is only as strong as its weakest part. I'd be more concerned about the un-gussetted verticals and the hooks. Regardless, it looks up to the task.
Cost savings is not at all the reason I have gone with the 2x4 setup. The $60 cost difference is a non-issue. I continue to use that setup because it very accurately places the engine at whatever position or angle I desire and is totally stable when it does. The 2x4 setup is a darn sight safer than the stamped steel sawhorse with come-along. I have used the 2x4s to remove and install a dozen or so engines or engine and transmission combined without any issue. I used it to install my ALH TDI and automatic transmission at the same time. The ALH weighs a fair amount more than a WBX and the automatic weighs more than the manual trans. Regardless, I don't ever get under any engine until it is bolted in place regardless of what contraption is holding it up.
williamM
williamM is offline
PostPosted: Fri Sep 26, 2014 7:54 pm    Post subject: Reply with quote
Was thinking that when we signed up for MEDFLIGHT.
Had more grief trying to keep iit balanced on the roller jack. so cinder blocks were actually an improvement.
Weirdest one was a dodge van 318 extraction out the passengers side door using 2 ladders and a pipe in a pipe to slide it all sideways.
Don't step in any!
Bicycle019
Bicycle019 is offline
PostPosted: Fri Sep 26, 2014 11:33 pm    Post subject: Reply with quote
Have the HF tool, used it when swapping out the engine in our van last spring for one that didn't spray coolant out the head.
I found it wasn't enough just to use the support beam, I supplemented with a floor jack underneath to help raise the motor. I felt like just using the supplied chains and threaded rods to do the heavy lifting wasn't enough support for my level of comfort, plus it takes a while to spin the motor up, readjust the chain, and spin some more. What the beam and chain setup does do well is allow you to position the motor much better than just using a floor jack when getting it lined up and bolted in. For me the combo of jack and support beam worked well and took out a lot of the drama and turned this into a pretty easy one man job.
Glad I bought mine, also works well holding up engines on FWD cars as well when ever you have to take a transmission off. Easy to store as well if you don't have a lot of space in your garage.
'89 Vanagon Whitestar
'84 Jetta GLI - built 2.0 ABA
'16 GTI Performance Pack
'17 Golf AllTrack (wife)
chazz79
chazz79 is offline
PostPosted: Sat Sep 27, 2014 4:40 am    Post subject: Reply with quote
I have a cheap winch screwed to a board that does the same thing. I think it's a 70.00 hf cheapie but a buddy gave it to me because it wasn't reversible.
It works great! You can look from below the vehicle and sight align items as the engine is raised by the remote. This is handy when you're trying not to pinch anything and are lining up bolt holes by yourself.
I've done this on typical american stuff by strapping the same winch to a peice of 12' angle iron slid through the trusses of my shop. It works out pretty sweet either way. As you get older you keep thinking of better ways to save your back.
One day as a lion, or a lifetime as lamb
The green monster in bits and peices: http://www.thesamba.com/vw/forum/viewtopic.php?t=332556&highlight=green+monster
sanchius is offline
PostPosted: Sat Sep 27, 2014 7:16 am    Post subject: Reply with quote
I agree completely, these are all excellent points.
I always have 1 or 2 floor jacks and a transmission jack in play as well, plus several jackstands as backup.
IdahoDoug
IdahoDoug is offline
PostPosted: Sat Sep 27, 2014 8:34 am    Post subject: Reply with quote
Andrew,
Care to share enough info so I can exactly duplicate your rig? I will be yanking a WBX and auto together next week from a yard and it would be great simply to do that. Lengths of boards, length of rod, fitting on bottom of rods, etc. Thanks!
DougM
