Stripping carpet adhesive/tar board from floor/carpet area?
moab762
moab762 is offline
PostPosted: Tue Nov 18, 2014 1:20 pm    Post subject: Stripping carpet adhesive/tar board from floor/carpet area? Reply with quote
Is there a good/cheap alternative for stripping the carpet adhesive spray and tar paper and other gunk from under the carpet? I really don't want to eat into the paint. And I hate using Jasco. It's so caustic and a mess to clean up. It's not like I can hose the inside of my car out. That stuff splatters everywhere and would continue to remove paint from anyplace it hit (dash!). And it would for sure eat the paint that is still there that I would not want removed. Like under the dash where the carpet goes.
I had to clean up the floor on a '49 Lincoln with tar paper that was adhered to the floor. Not sure if it was actual adhesive or just years of being baked on. But it took a damn air chisel to get the stuff off. And even after using the air chisel I was going to use Jasco and repaint. Have not been able to inspect my new '67 yet (being shipped). But the carpet looks og. So I assume there is a mix of tar board and carpet adhesive that has been setting up for years.
I read this thread about Dawn Power Dissolver. http://www.thesamba.com/vw/forum/viewtopic.php?p=7449434#7449434 Which used to be $3 a can. And supposedly worked AWESOME. But now's it's $9.37 a bottle! Dawn must have figured out how great it was.
Any advice before I break out the air chisel? I assume a stronger oven cleaner could handle the carpet adhesive. But if the tar board is stuck as much as my '49 Lincoln. It's going to be a total PITA. I'm having the interior done. And I want to strip off all the crud before having them put down sound deadener and carpet padding.
offshores
offshores is offline
PostPosted: Tue Nov 18, 2014 4:39 pm    Post subject: Reply with quote
I used a heat gun and a few different size putty knives on my tar boards. For the left over adhesive I believe I used acetone and some rags to clean that stuff off. Probably even used the putty knives there too when the stuff softened up.
moab762
moab762 is offline
PostPosted: Tue Nov 18, 2014 7:48 pm    Post subject: Reply with quote
I'm wondering if brake cleaner might be a place to start with the carpet adhesive. I've only used it on old gun parts though. Seems to strip paint a little to well. I might just try some simple green soaked over night and covered with plastic bag maybe. If I could just get the adhesive and tar up without disturbing the paint that would be nice. The car was painted not long ago. I mean about ten years ago. But then it was garaged for 10 years.
I'll just start trying some test spot when it gets here. Acetone too maybe on the glue.
Mike Fisher
Mike Fisher is offline
PostPosted: Tue Nov 18, 2014 9:20 pm    Post subject: Reply with quote
Some guys have used dry ice to freeze the tar on pans before chipping it off on Type 3's.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Bobnotch
Bobnotch is offline
PostPosted: Wed Nov 19, 2014 8:58 am    Post subject: Reply with quote
A friend of mine swears by Goof Off for getting ahesives off. Should work good for carpet glue.
I normally just use a DA or my trusty 90* die grinder with those textured grit discs (not actual sand paper).
As for tar board left overs, putty knife and a heat gun should take care of that.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
hitest
hitest is offline
PostPosted: Wed Nov 19, 2014 9:45 pm    Post subject: Reply with quote
This is exactly what I had to do to approx. 20 sq. feet of my '66 microbus. Took a long time- but came out clean. I saved myself a cue ball-sized glob of the tar to remind myself never, ever, embark on a similar project again.
FU#5
moab762
moab762 is offline
PostPosted: Wed Nov 19, 2014 10:05 pm    Post subject: Reply with quote
Good one, Hitest! lol!
jeston
jeston is offline
PostPosted: Sat May 29, 2021 6:31 pm    Post subject: Re: Stripping carpet adhesive/tar board from floor/carpet area? Reply with quote
Is it always worth removing the tar board? I have a pan that looks pretty solid. I see som minor surface rust around the edge of the tar board. Should I take it all out or leave it? 1958 Baja with ragtop slider that just came into the family.
