four speed manual - oil level etc.
tlbranth
tlbranth is offline
PostPosted: Sat Feb 21, 2015 4:40 pm    Post subject: four speed manual - oil level etc. Reply with quote
Can anyone tell me how to check the oil level? Owner's manual says go to your VW dealer. Bentley says check and refill if necessary but I can't find where it says how.
Terry
1991 Westfailure. 2004 Forester 2.5 engine. 4speed Standard transmission.
a1fa
a1fa is offline
PostPosted: Sat Feb 21, 2015 4:43 pm    Post subject: Reply with quote
open the pour bolt, stick your finger in.. Shocked
Learn to ride. Ride to learn.
Ahwahnee
Ahwahnee is offline
PostPosted: Sat Feb 21, 2015 5:12 pm    Post subject: Reply with quote
Without looking I seem to recall that the specified level was somewhere below the fill plug. Not very handy when refilling (like being told to 'turn left 5 blocks before Main Street').
But I believe that instruction was later revised to fill to the bottom of the fill plug - so easy to refill (until it comes out) and check (then mentioned finger).
You will need something to undo the 17mm socket head plug. Either a tool for that purpose or a substitute made from a bolt & nut.
tlbranth
tlbranth is offline
PostPosted: Sat Feb 21, 2015 5:22 pm    Post subject: Reply with quote
What I figured. I looked around and am not seeing the filler bolt though.
Terry
Ahwahnee
Ahwahnee is offline
PostPosted: Sat Feb 21, 2015 6:19 pm    Post subject: Reply with quote
Right (passenger) side of case, near the linkage.
May be wicked tight if it hasn't moved in a while.
IdahoDoug
IdahoDoug is offline
PostPosted: Sat Feb 21, 2015 11:21 pm    Post subject: Reply with quote
Aaaaaaaaannnnnnndddddd wait for it - the piece of advice you will never need to be reminded of if you disobey it..........
Loosen the FILL bolt before you remove the drain bolt.
dobryan
dobryan is offline
PostPosted: Sun Feb 22, 2015 7:51 am    Post subject: Reply with quote
^^^^^ X10! Laughing
Dave O
The Western Syncro build
Steve M.
Steve M. is offline
PostPosted: Sun Feb 22, 2015 8:02 am    Post subject: Reply with quote
Oh...you mean IF you can get it loose! Laughing
tlbranth
tlbranth is offline
PostPosted: Sun Feb 22, 2015 8:43 am    Post subject: Reply with quote
Thanks fellas.
Terry
gears
gears is offline
PostPosted: Sun Feb 22, 2015 8:45 am    Post subject: Reply with quote
Sometimes, only the tool that Ahwahnee shows will remove the dang thing, because it allows more loosening torque to be applied. Shops should know better, but they tend to tighten these plugs to 100+ lbs, when the manual states 15. Personally, I use teflon tape to avoid any future knuckle bashing.
aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com
singler3360
singler3360 is offline
PostPosted: Sun Feb 22, 2015 11:05 am    Post subject: Reply with quote
Over here is where I asked about the oil level. There is a debate between at the fill hole level and 1/8" below.
http://www.thesamba.com/vw/forum/viewtopic.php?t=588128&highlight=transmission+oil+level
IdahoDoug
PostPosted: Sun Feb 22, 2015 11:14 am    Post subject: Reply with quote
In the field once, I used a truck's jack to get the fill plug open, so tight was it on. I put whatever wrench I had on it, and used the jack's lifting power under the wrench to rotate it. It let go with a bang that told me there was no way I would have gotten it. The owner of the truck later called the shop and gave them an earful about overtightening things. He'd also had major trouble with the lugnuts. Anyhow, with few resources at hand remember the power of the car's factory jack to move a wrench even when in the middle of nowhere.
Abscate Premium Member
Abscate is offline
PostPosted: Sun Feb 22, 2015 1:52 pm    Post subject: Reply with quote
You can debate this kind of stuff all day.
Ridiculous. Gears are lubed by splash, and 3mm difference in level won't matter. It should be 3mm of course, not 1/8.
