quirkinator Samba Member
Posted: Mon Mar 16, 2015 8:52 am Post subject: Installing passenger-side mirror? |
My husband and I want to see if it is possible to attach an identical passenger-side mirror to his '69 Fastback. We could go to a shop that specializes in these types of VWs or do it ourselves, but want to make sure it's done properly, since we just absolutely LOVE "Murphy." Any thoughts? |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35929 Location: Conejo Valley, CA
Posted: Mon Mar 16, 2015 10:47 am Post subject: |
I had the body shop drill and then weld in the correct size nut to the inside of the door. Or you can find a same-vintage Squareback door; they came with them from the factory.
I'm not sure a right-side mirror was ever a factory option, but I wanted the safety regardless and retrofitted it. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18046 Location: Eugene, OR
Posted: Sat Mar 21, 2015 7:45 am Post subject: |
It took me years to find my '69 passenger mirror! It should have the extended arm like the middle mirror in the bottom row & the teardrop mirror on top. The teardrop mirrors on top are original '67 mirrors. New EMPI Karmann Ghia mirrors like the right mirror in the bottom row will work, but the shaft diameter is different. New EMPI Beetle mirrors with long arms like the lower left mirror will work, but Not original!
_________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Suesanctuary Samba Member
Joined: August 17, 2007 Posts: 842 Location: Wishing we were still chest deep in Vw Parts at the Wolfe Estate.
Posted: Sat Mar 21, 2015 8:14 am Post subject: |
KTPhil wrote: |
... drill and then weld in the correct size nut to the inside of the door. |
This. The nut welded inside the door is an absolute necessity. _________________ Sue
70 Fastback-AT w/ pop-outs
Did you know:
New York was the first state to require license plates, back in 1901. In those days, you had to make your own. Sears even sold Kits! Massachusetts was the first state to issue them in 1903.
Source: Automobile Magazine, Nov. 2006 |
Posted: Sat Mar 21, 2015 8:22 am Post subject: |
My passenger side nut is welded to a small triangular plate & slipped up into the pillar to match the hole in the pillar & then thread the mirror on to hold it. _________________ https://imgur.com/user/FisherSquareback/posts
DHanna Samba Member
Joined: June 15, 2004 Posts: 246 Location: North Richmond, N.S.W Aust.
Posted: Sat Mar 21, 2015 4:06 pm Post subject: |
KTPhil wrote: |
Of course they came out from the factory KTPhil!! All our cars here in OZ had them fitted to the RH door.  |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23396 Location: Kimball, Mi
Posted: Sat Mar 21, 2015 8:01 pm Post subject: Re: Installing passenger-side mirror? |
quirkinator wrote: |
I think CIP or J-bugs sells a nut for mounting the mirror to a door that never had one. In fact my old 69 Square had 1 installed in it's right door (one of the PO's swapped the door from a Fastback). All you'd have to do, is drill a hole big enough for the mirror mounting screw and then remove the door panel, so you can get your hand up there to get the nut started on the mounting screw. Tighten everything up, then, you'd just have to put the door back together. That mounting screw nut grabs the sheetmetal inside the door, and locks the mirror into position. I never had to readjust mine in the 2 years I owned it.  _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
KTPhil  Samba Member
Posted: Sat Mar 21, 2015 9:49 pm Post subject: Re: Installing passenger-side mirror? |
Not quite "identical" since the arm has to be a bit longer in order for you to see it with the right angles form the other side of the car. Same style, yes, but it's not exactly a "mirror image." |
shortride Samba Member
Joined: October 10, 2010 Posts: 1323 Location: Oklahoma
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 6041 Location: Brooklyn
Posted: Thu Apr 09, 2015 7:30 am Post subject: Re: Installing passenger-side mirror? |
KTPhil wrote: |
I see what you did there. |
ronbug73 Samba Member
Posted: Sat Apr 11, 2015 7:33 am Post subject: |
cip1 have a nut that you dont have to weld end its not from metal
in a beetle there is a hole from the inside beacuse of the right whell drive car.
this is the place to make the hole from the outside.
my be its the same with the type 3.
ron |
Posted: Sat Apr 11, 2015 4:57 pm Post subject: |
shortride wrote: |
Isit possible to install a passenger side mirror without screwing up the paint? |
See my post above. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
grandpa pete Samba Member
blues90 Samba Member
Joined: March 14, 2009 Posts: 1912 Location: Hollywood ,CA
Posted: Mon Nov 20, 2017 5:13 pm Post subject: Re: Installing passenger-side mirror? |
My 73 had the factory threaded insert on the right door and it had a mirror.
I had to replace the glass on both so I got cheap mirrors with the black plastic trim around the glass and silicone them in place.
Lately they were so stiff that if I tried to turn them up or down the entire large thread would move . I took them out and added a rubber washer since the old seal was gone and backed off the nut on the spring and added a drop of oil then just tightened the nut enough so I could move them and they would stay in place.
I recall the right mirror the peen that holds the mirror head to the shaft broke so I drilled and tapped the shaft and used a bolt and washer before I replaced the glass with the cheap ones.
The right mirror glass now has that dark area spots . Some day I'll get replacements . |
oxsign Samba Member
Joined: February 19, 2006 Posts: 607 Location: Sanford, FL
Posted: Tue Nov 21, 2017 1:16 pm Post subject: Re: Installing passenger-side mirror? |
My '71 square has a factory threaded hole for a mirror. I just need to find one (and would like to) now. The search for all the things I would like continues on......  _________________ 1971 Squareback, fully bagged, 1776.
Build thread here.....
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
haz77 Samba Member
Posted: Sat Oct 10, 2020 8:18 am Post subject: Re: Installing passenger-side mirror? |
Ok, so looks like my door has a mirror location but how do you remove this plug???
_________________ '71 Type 3 Fastback, Sunburst Yellow, Lowered on Riviera's.
1776cc, Fully balanced, 8 Dowel fly, W100, DRD L3 heads, 1:25-1 CB rockers, 8.2:1, Twin 34's, Elec fuel pump, Fuel press reg, Full flowed, Single Quiet pack. |
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4629 Location: Pasadena CA/DTLA soon China
Posted: Sat Oct 10, 2020 8:31 am Post subject: Re: Installing passenger-side mirror? |
Its a plastic plug. Don’t remember if it’s threaded . If it doesn’t get damaged, I’d buy it from you.
Martin
Allwagons _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
Everything sounds good on paper! |
Qldelsie Samba Member
Joined: September 22, 2019 Posts: 518 Location: Queensland Australia
Posted: Sat Oct 10, 2020 6:07 pm Post subject: Re: Installing passenger-side mirror? |
Yes its a screw. Screwed into the same thread that the mirror will then screw into. I had to destroy mine to get it out - After all, it had been in the for 50 years ! I put two holes in the face then used circlip pliers to screw / wiggle it out.
G |
Yabbadubbadoo Samba Member
Posted: Sun Oct 11, 2020 2:42 am Post subject: Re: Installing passenger-side mirror? |
Quoting my recent experience on this task from my build thread.
Yabbadubbadoo wrote: |
Whilst the body was at the body shop I remembered a job I'd always planned to do but never got around to doing.
My car only had a right hand mirror. That's the drivers side in Australia. I really wanted to install a passenger side mirror but there's no thread on that side.
Anyhow without any available doors to chop up I decided to make something to give the panel beater to weld in.
Vw used a standard hex nut M16x1.5 captured within a piece of folded Sheet metal welded inside the door. My solution was to make a nut with a large diameter 40mm thinned out flange so that it would be easier to weld to the thinner metal of the door skin. Welding thin metal to thick metal is always hit n miss so I turned the flange down to about 2mm. The 40mm diameter also spreads out the bending force whilst adjusting the mirror.
Here's the flange nut I made. First version I made was 32mm and it felt a bit small as you can see. 40mm is a much better size.
Drill 4x 5mm holes around the large center hole and plug weld.
Some glaze putty to finish it smooth and prime.
_________________ Sydney, Australia.
66 Type 3 Fastback |
haz77 Samba Member
Posted: Sun Oct 11, 2020 8:55 am Post subject: Re: Installing passenger-side mirror? |
but there's no thread on that side. |
So you disagree & say the plug in my door doesn't hide a thread? _________________ '71 Type 3 Fastback, Sunburst Yellow, Lowered on Riviera's.
