DWP Samba Member
Posted: Tue Apr 28, 2015 4:51 am Post subject: Help with shifter purchase. |
Need recomendations for a shifter that is bent back about 4"-6". from stock for my Baja. After mounting the seats further back it's hard to reach 1st and 3rd.
I am thinking about the Scat Dragfast for early bugs.
DWP |
Brian Samba Moderator
Posted: Tue Apr 28, 2015 8:42 am Post subject: |
Stock 67 down shifters have that bend to them, not sure how much. Hurst and EMPI knock offs are pretty nice too. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
DWP Samba Member
Posted: Tue Apr 28, 2015 9:00 am Post subject: |
Thanks, i will look at them. I was considering the bugpac shiftright but was told it only bends back about 2".
In the photo below you can see how i raised the shift plate and brake plate. The body has a 3" lift and 3 rib trans.After mounting the seats i realized i should of moved the shifter back.
Anybody know how far back the Early Scat handle is bent?
DWP
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 3695 Location: West Coast (Michigan's)
Posted: Tue Apr 28, 2015 11:55 am Post subject: |
Is that a steering coupler I see between your shift box and P-brake box??? _________________ Brian H.
OrangeCrushERBerrien Warrior-2.4L Quad4-2x3 arms-1.5Fox coilovers-094-930CVs
LAZY MARY1970 Baja 2110cc-82mm CB forged crank-AA pistons/cylinders-Grant rings-1.1 vw rockers-CB serpkit-CB chromoly PRs-CB maxiflow filter pump-wix51515 filter-Dual 44IDF-cut/turned front beam-AEM wideband-Auber CHT-Donaldson Dual PowerCore filters-custom AL air boxes |
DWP Samba Member
Posted: Tue Apr 28, 2015 12:12 pm Post subject: |
Yes I was having a little fun with design. The shift rod itself runs inside the steering part and out the back and to the trans. I have to stop looking at Steampunk sites!!!!!!!
DWP |
flashho Samba Member
Joined: August 11, 2012 Posts: 240 Location: Mulege, Baja
Posted: Tue Apr 28, 2015 12:29 pm Post subject: |
Hell yes! For steampunk.  _________________ rant _ classified ads with out pics are almost worthless |
B Ramsey Samba Member
Joined: February 05, 2006 Posts: 479 Location: Mohave Valley, AZ.
Posted: Tue Apr 28, 2015 1:54 pm Post subject: |
| whack the shift lever off and weld whatever you want that fits. |
mtnroads Samba Member
Joined: December 06, 2006 Posts: 403 Location: Minkler, CA
Posted: Sun May 03, 2015 11:58 am Post subject: |
You can always get a bus shifter bend and cut as necessary. I've seen it done in rat rods. _________________ pax
No Good Deed Goes Unpunished.... |
