millinario Samba Member
Posted: Mon Jul 13, 2015 4:34 pm Post subject: Need help removing front shift rod |
Massive noob here....
My shifter and stop plate were toast so I have replacements.
Trying to replace my front shifter rod, but I can't get the old one out. I have searched quite hard but can't find a decent 'How To' anywhere.
Removed grub screw from the front coupler (also had one screw missing), it wasn't an 8mm square head screw and had no hole for the safety wire. Btw, anyone seen a coupler like this, looks nothing like anything I've seen during my internet searches:
Do I need to do the same at the rear coupler? Even then I don't see how either of the rods will come out?
This plate at the front of the cup of the front shift rod stops it sliding out:
How do I get this sucker out folks?!
FWIW I think I left her in neutral when I removed the shifter. Mistake? |
Ran When Parked Samba Member
Joined: September 26, 2013 Posts: 781 Location: Birmingham, AL
Posted: Mon Jul 13, 2015 6:25 pm Post subject: Re: noob too |
OK, thanks, helpful links.
So when I get this front coupler off the front shifter rod can be removed by pulling back towards the engine? This is the part I'm having trouble getting my head around.
| Sh*tBird wrote: |
Edit: is a summary thread for this issue on the Split Bus FAQ? |
Not that I could find, I did check there first, honest. |
Posted: Mon Jul 13, 2015 7:33 pm Post subject: |
Thanks again for the nudge Sh*tBird, has improved my search skills no end.
Found this image in the gallery
I have the early type coupler on my 74 bus, good to know. |
Posted: Mon Jul 13, 2015 8:48 pm Post subject: Re: noob too |
| millinario wrote: |
| Sh*tBird wrote: |
Maybe it will get it's own thread/listing in the FAQ one day...
When I removed mine, I had everything under the cab floor unhooked from the shift rod and the coupling was the only thing holding up removal. When the coupling lost its grip, it allowed the shift rod to slide forward and it was free. I just moved it out from under the bus and then removed the rest of the coupling that was still on the front shift rod.
That coupling acted like a "Chinese Finger Trap" with screws:
Hope that makes sense, I am really sleepy. |
easy e Samba Member
Joined: May 28, 2008 Posts: 3942 Location: 1 hr north of Santa Barbara
Posted: Mon Jul 13, 2015 9:33 pm Post subject: |
Love that ^^ visual
Front might need to be cut... carefully.
Rear... I think maybe someone has had success changing rear shift rod bushing with transmission in... but from what I recall.... need trans out.
_________________ aka: Evan
“They are about as worthless as the tits on the boars that live in the woods behind their junk yard.” -Weatherly |
EverettB  Administrator
Joined: April 11, 2000 Posts: 72016 Location: Phoenix 602
peterxxl Samba Member
Joined: December 20, 2010 Posts: 426 Location: smwhere between Azerbaijan and Uruguay
Posted: Tue Jul 14, 2015 7:56 am Post subject: |
| easy e wrote: |
Love that ^^ visual
That's what I did. _________________ Hi! I am Peter from Czech Republic...
Bringing VW news en Español to your doorstep since 2009!
* 1961 Panel - my 1st VW - bought near Mexico City - traded for:
* 1959 Kombi - stored in Philly for now
Read my story here:
* Part 1 - Mexico City to Philadelphia
* Part 2 - Philadelphia to Europe - in progress |
sub-hatchtim Samba Member
Joined: September 19, 2006 Posts: 2696 Location: Phoenix AZ
KevinAlbrecht Samba Member
Joined: March 07, 2002 Posts: 1006 Location: Ocean City > Boca > Pompano > Kirkland > Eugene > Sarasota > Babcock Ranch
Posted: Tue Jul 14, 2015 8:05 pm Post subject: |
don't forget to order the screws! _________________ Kevin Albrecht
1963 Panel
Don't forget those seat-belts!
My '66 after the crash.
Click to view image |
Stocknazi Samba Member
Posted: Tue Jul 14, 2015 8:10 pm Post subject: |
Heat usually does the job getting the coupler apart. Heat the coupler and screws until they are glowing red then cool quickly with cold water.
You may have to repeat the process a few times.
Most of the time a propane torch works, but I have had a couple that required a little more heat from an oxy/act torch.
You can lay wet rags on the floor above the coupler and the heater tube underneeth. Don't melt your choke or fuel tap cable sheeth if you have one.
If the screws are broken off, you will have to cut it like in the pic above. _________________ WANTED:
Thomas Jefferson |
Posted: Thu Jul 16, 2015 9:31 am Post subject: |
Gonna try the heat route later this week.....damn real life getting in the way of imporant kombi work for now. If I get no joy I'll be forced to cut the coupler.
Screws are out thankfully (one was actually missing).
Appreciate all the repsonses. Will update. |
iamdonquixote Samba Member
Joined: January 28, 2003 Posts: 2087 Location: M*ssholia
Posted: Thu Jul 16, 2015 8:29 pm Post subject: |
Heat, heat heat.
Heat the coupler until it is very cherry red and twist the rod back and forth with a good set of vice grips ( if the front of the rod is not connected to the shifter ). |
crukab Samba Chef
Joined: December 13, 2002 Posts: 6132 Location: Vermont
Posted: Fri Jul 17, 2015 3:54 am Post subject: |
| iamdonquixote wrote: |
Heat, heat heat.
Yes ^^^^^^^^^^^^^^^^^^^
That worked for me, every time. _________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
Posted: Mon Jul 20, 2015 1:42 pm Post subject: |
| ajdfhifgwodldbfsjgflahl.....it feels like the coupler and the middle shift rod have been welded togethor. As it's 'above' the coupler (between coupler and the floor of the bus) I can't see any weld, but it certaily feels that way when I run my finger up there. |
Posted: Mon Jul 20, 2015 2:19 pm Post subject: |
Here is the extent of hacking required to remove mine:
Don't let that fucker beat you. _________________ Kevin Albrecht
1963 Panel
crofty Judas of the North
Joined: August 09, 2000 Posts: 19938 Location: Land of Whine and Phonies
Posted: Mon Jul 20, 2015 2:44 pm Post subject: |
| KevinAlbrecht wrote: |
don't forget to order the screws! |
And wire them up when you are done tightening them! _________________ Your Vanagon sucks, Stop waving at me.
| HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Fiatdude Samba Member
Joined: April 20, 2009 Posts: 1217 Location: now in MO.
Posted: Mon Jul 20, 2015 3:58 pm Post subject: |
World's Greatest Penetrating fluid
50% ATF and 50% Acetone ---- ---- ! BILLION times better than any thing else -- -- Squirt it once or twice every 2 hours first day-- next day ,,, a miracle _________________ Remember, as you travel the highway of life,
For every mile of road, there is 2 miles of ditch |
Posted: Mon Jul 27, 2015 8:00 am Post subject: |
Man this is bugging me, still can't get the middle shift rod out! More advice needed please.
This all started because I had ridiculous slop when changing gears (the gear stick was doing a 180 and 3-4th were very hard to find). Upon inspection the shift plate was cracked and the pin/ball of the gear stick was horribly worn. I ordered both new. They arrived with a new front shift rod too (turns out the gear stick and front linkage didn't belong in my Kombi).
So....I ended up cutting the front shift rod with my grinder to within an inch of the coupler in the hope I would be able to slide the middle shift rod forward and out (heating/cooling the coupler mulitple times had no effect...I suspected it's been welded in place).
No joy. Is my only play now to cut the coupler? I'm going to measure later after work, but I can't believe that removing that extra 3 inches or so of metal will allow the rod to slide forward and out. The tube housing the rod doesn't seem short enough to allow it to 'drop' enough.
I really want the rod out so I clean out and grease that tubing under the bus. I guess I could forget that, cut the coupler, get a replacement and join things up again.
Edit: also found that the middle shift rod has been cut and welded by PO too. Maybe it's the wrong part or PO had it cut to remove it??!! |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15515 Location: Casa de Oro, California
Posted: Mon Jul 27, 2015 9:40 am Post subject: |
| When you say 'middle rod" you are talking the one the lays in the belly running down that hollow tube? That rod can only be pulled all the way out from the rear after pulling the transaxle. |
