Bob Martin Samba Member
Joined: August 15, 2015 Posts: 3 Location: Western North Carolina
Posted: Sat Aug 15, 2015 2:50 pm Post subject: 1968 Baywindow turn signal problem |
| New Member, Hoping someone can help. On my '68 Bay, The turn signals operate correctly, when I turn the headlights on, the drivers side rear stops flashing, and burns solid very brightly... The front flashes as normal. The passenger side operates normally with or with out the headlights on. I have tried a direct ground to the battery from the drivers side rear light socket, but that has no effect. I removed the lamp, and it is a dual element, and is inserted correctly.... thoughts? Thank You! |
Tcash Samba Member
Joined: July 20, 2011 Posts: 12843 Location: San Jose, California, USA
Posted: Sat Aug 15, 2015 3:19 pm Post subject: |
Make sure the bulb is installed right.
Should be an 1157
Note the two filament wires in the bulb:
The one that is much thicker. Is the turn-brake light filament.
The thinner one is the tail light filament.
Sometimes the connector inside the light bulb socket gets twisted.
Good Luck
Tcash |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 4157 Location: Seattle, WA
Posted: Sat Aug 15, 2015 8:02 pm Post subject: |
If the wires to the bulb were reversed (i.e. turn sig./brake wire to the taillight post, and vice versa, turning on the headlights would
turn on the brighter filiment, and the other one might still be flashing, but not be noticeable. This is a very common mishap, and an easy fix. _________________ '67 bug: seized by the authorities
Posted: Sun Aug 16, 2015 9:02 am Post subject: |
I got it,..... it was a combination of the Wires being hooked up backward on the lamp socket, and a bad ground connection.
BerryBus Samba Member
Posted: Sun Aug 16, 2015 10:21 am Post subject: |
There's nothing quite like figuring your turn signal issues. Every time my are blinking the last couple weeks, I still smile with pride. I only had brake lights when I found him last year. Literally, no other lights anywhere. _________________ 1970 7 Pass/Riviera/Westfalia - Ours
1968 + 1971 Bus Trailer
1991 Porsche 964 C4 Cabriolet - Mine
2005 New Beetle Convertible - Wife
2012 Touareg TDI |
Dana Champion Samba Member
Joined: July 06, 2012 Posts: 633 Location: Ventura County, CA
Posted: Sun Aug 16, 2015 6:38 pm Post subject: |
| I had a time with my '70. I was tired of using hand signals. After hours of futsing with it, turned out to be a bad ground, on the drivers side tail light, and a flasher relay. |
