davealten Samba Member
Joined: September 16, 2014 Posts: 8 Location: Arkansas
Posted: Thu Sep 24, 2015 12:41 pm Post subject: Fuel tank help! |
I have recently purchased a 1973 westy project, this bus came without a fuel tank. I have located a tank out of a 1970 bus pretty close to me at a reasonable price. Will this work?? Are there any known issues?
Thanks in advance! |
Tcash Samba Member
Joined: July 20, 2011 Posts: 12846 Location: San Jose, California, USA
Posted: Thu Sep 24, 2015 4:32 pm Post subject: |
1973 westy project
The fuel sender vibrator and gauge are different. If it is fuel injected you will need to "T" in a return line. It will fit in the same space though.
Tcash |
Posted: Thu Sep 24, 2015 6:16 pm Post subject: |
I think bus depot and others have new tanks available these days. Don't know about quality and fit though. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52762 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Sep 24, 2015 6:31 pm Post subject: |
If it's an early 73 the sender is compatible, if it's the later bayonet mount style the fuel gauge will be a blur due to a bouncing needle. The outlet will match but the vent tubes will require some crafty plumbing to get everything Teed together and functional. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Sep 25, 2015 6:19 am Post subject: |
Thanks for your help guys |
Tcash Samba Member
Posted: Fri Sep 25, 2015 8:42 am Post subject: |
The change took place last six of the chassis #166 508. |
m.pendzick Samba Member
Posted: Fri Sep 25, 2015 2:53 pm Post subject: |
On a side note, I just pulled my fuel tank out a 73 project. The exterior of the tank is in good shape. The inside had some old nasty fuel and sediment in it. A friend had recommended using a POR-15 fuel tank repair product for cleaning and re-sealing. Has anyone tried this with any success? Or can anyone recommend a process that's worked for them? Thanks |
Posted: Fri Sep 25, 2015 3:23 pm Post subject: |
m.pendzick wrote: |
Avoid the POR-15, infact avoid any coating unless the tank is full of pinholes, in that case the Bill Hirsch product is far superior to the POR.
Start by giving it a good old cleaning and see how it turns out: http://www.thesamba.com/vw/forum/viewtopic.php?t=378770 _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Sep 26, 2015 10:12 am Post subject: |
Thanks Daddy!
Super awesome thread with tons of great information. I tried to do a search for something like that, but alas I failed. |
