renka Samba Member
Joined: September 23, 2010 Posts: 38 Location: Holland
Posted: Sun Oct 04, 2015 3:42 am Post subject: Wooden slats for tilt |
restoring a doublecab at the moment and confused about the size needed for the wooden slats
Original bows and hoops came with the car I straightened and repaired them.
After reading the dropgates I saw the slats must be aproxx 69.2 inches long
measuring my own old slats they are only 68.5 inches ?
fitting them is straightforward with nice uprights, so confusion about te correct position of the rear upright at the loadbed.
can anybody confirm the right place as the loadbed is replaced with new KF panels and I've forgotten to check if the mountholes are in the correct position.
_________________ to finish first, you first have to finish |
EDragnDean Samba Member
Joined: July 13, 2005 Posts: 1151 Location: Vancouver, WA
EverettB  Administrator
Joined: April 11, 2000 Posts: 71960 Location: Phoenix 602
renka Samba Member
Posted: Sun Oct 04, 2015 9:27 am Post subject: wood slats for tilt |
stupid me, mounting points are indeed the factory ones in de bedframe
did some measurements
this is 2 13/16
from this
to this
is exactly 68 3/16
the distance between de harts of the mounting holes is 66 13/16
as I lenghten the woodslats to 69 2/16 the rear hoop is standing top backwards I assume this has to be totally upright?
It worries me because of the fitting of the tilt in the future.
still not sure wat is wrong yet.  _________________ to finish first, you first have to finish |
Daddybus Samba Member
Posted: Sun Oct 04, 2015 9:33 am Post subject: |
How did you "lengthen" the slats?
Looks like the original length was correct. |
renka Samba Member
Posted: Sun Oct 04, 2015 9:38 am Post subject: |
I jiust put a piece of sheet metal with two clamps to it to show the result
the woodslats are only 68 1/2 and not 69 2/16 as supposed on the dropgates site _________________ to finish first, you first have to finish |
Posted: Sun Oct 04, 2015 5:16 pm Post subject: Re: wood slats for tilt |
| renka wrote: |
this is 2 13/16
from this
to this
is exactly 68 3/16
My original metal Double Cab has almost the same exact measurements.
I do not know about the slat length but I agree the rear bow should be at a 90-degree angle (straight up and down) _________________ How to Post Photos
renka Samba Member
Posted: Sun Oct 04, 2015 11:44 pm Post subject: wood slats |
Thank you all for the replies
@ EverettB :
your reply reassures me thanks, was afraid for a very loose fit of a tilt in future.
Car is leaving to be sprayed this week
cheers René _________________ to finish first, you first have to finish |
