Any experience with GlowShift Oil Filter Sandwich Adapter?
Page: 1, 2, 3  Next
Syncronoid
Syncronoid is offline
PostPosted: Mon Nov 09, 2015 11:56 pm    Post subject: Any experience with GlowShift Oil Filter Sandwich Adapter? Reply with quote
Anybody have experience with the GlowShift Oil Filter Sandwich Adapter? I've seen the oil sensor kits/parts sold at VC and RJE, but this seems like such a simple solution to get oil pressure and temp. I realize its not a complete kit, but I like the fact that I can source the other parts on my own and do it the way I want.
http://www.glowshiftdirect.com/oilfilter-sender-adapter-3-4unf-16.aspx
'90 Syncro Westy w/GW2.5L
RaraBlacksheep
RaraBlacksheep is offline
PostPosted: Tue Nov 10, 2015 2:08 am    Post subject: Reply with quote
They're good but the O-rings are junk. The aluminum part is fine, but the o-ring seems like something you'd get at Harbor Freight..mine lasted about two weeks before it deformed and started leaking. Hoping they'd do me a solid and send me a couple replacements, I shot support an email but they offered to sell me replacements at $7 each or so instead.
Not satisfied with that, I went to the parts store, sat down on the floor and started going through oil filters until I found one with an o-ring that fit. Best bet I found was an STP brand, S2827 filter, $4-5 tops. It was slightly small for the adapter, but it was close enough that I was able to get it in the groove. I used some grey silicone between the o-ring and the adapter for a little extra insurance (I set a few brake rotors on top to make sure it dried flat). Two months in, so far so good, and it's far more substantial than the one the adapter came with.
'82 Westy - Shark Weak
RaraBlacksheep
PostPosted: Tue Nov 10, 2015 2:13 am    Post subject: Reply with quote
Also: the aluminum 1/8" NPT plugs are junk too, I couldn't get them to stop leaking no matter what I did. Run of the mill hardware store brass plugs cured all my issues.
Fiddlestyx
Fiddlestyx is offline
PostPosted: Tue Nov 10, 2015 4:06 am    Post subject: Reply with quote
I had one of these on my other car for over 5 years. Never had a problem with it.
JudoJeff
JudoJeff is offline
PostPosted: Tue Nov 10, 2015 5:28 am    Post subject: Reply with quote
I use one for my oil and temp gauges, no problem.
1989 Vanagon GL Westfalia Camper, Burned up on 7/31/16.
1987 Vanagon GL Westfalia Camper, Bostig & Rebuilt, sold
1986 Vanagon GL Westfalia Camper, Bostig Sold May 10, 2021
1999 Ford GTRV Westfalia camper (30% bigger Westy layout)
J Charlton Premium Member
J Charlton is online now
PostPosted: Tue Nov 10, 2015 6:15 am    Post subject: sandwich plate Reply with quote
I like this one from them better.
http://www.glowshiftdirect.com/oil-cooler-sandwich-block-adapter-20mm.aspx
then you have ports for your oil cooler as well as for the sensors.
NAHT hightop availability May 18 2023 -
Bend Oregon - for Oregon, California- (7 tot , 3 available), Kennewick Wa (6 tot, 1 available), Small Car Performance Fife Wa. (7 tot 4 avail ), Fairbanks Alaska (1 tot 0 avail)
Future availability TBD : Springfield Mass. Staunton Va, Florida, Colorado, Grand Junction Co., SLC probably late 2024
insyncro
Banned
insyncro is offline
PostPosted: Tue Nov 10, 2015 9:01 am    Post subject: Reply with quote
Mocal's are much better quality and offer them with thermostat control.
HoustonPhotog
HoustonPhotog is offline
PostPosted: Tue Nov 10, 2015 10:57 am    Post subject: Reply with quote
I've had mine installed for about a year... never ad an issue with it...
Glowshift adapter I bought:
http://www.amazon.com/gp/product/B001PLNDF2/ref=as...KQQ5FMEMI4
gauge install writeup:
http://texasvanagons.com/oil-pressure-temperature-gauge-pod/
Abel Longoria
VanAlert App for Vanagons/Buses | Texas Vanagons | My Vanagon Build Thread | Follow Me On Instagram | Vanagon-centric Stickers Available Now
geodude
geodude is offline
PostPosted: Tue Nov 10, 2015 12:27 pm    Post subject: Reply with quote
I had one on the WBX and now one on the Subie 2.2 to use for oil temp and pressure sensors. They work, but you have to seat the o-ring well or you will get leaks. As others have said you can use a different o-ring. Its nothing special, just a chunk of aluminum.
1988 GL Camper
1991 Multivan — the basket case
Timwhy
Timwhy is offline
PostPosted: Tue Nov 10, 2015 4:02 pm    Post subject: Reply with quote
Could not have been easier. Thanks to Abel's write up!
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
insyncro
Banned
insyncro is offline
PostPosted: Tue Nov 10, 2015 4:18 pm    Post subject: Reply with quote
On the Zetec???....kudos Man.
I'd like to see that.
insyncro
Banned
insyncro is offline
PostPosted: Tue Nov 10, 2015 4:21 pm    Post subject: Reply with quote
His Instagram is one of my favorites!
djkeev
djkeev is offline
PostPosted: Tue Nov 10, 2015 4:38 pm    Post subject: Reply with quote
Interesting concept but aren't you simply doubling an already weak joint.
The oil cooler seal is a proven failure point in cold weather.
Is not removing the sender and installing a piped in Tee easier and less prone to leakage?
Dave
Ghia
Vanagon
Beetle
insyncro
Banned
insyncro is offline
PostPosted: Tue Nov 10, 2015 5:03 pm    Post subject: Reply with quote
Dave
That is a great question and I think some of the previous posts address the answer...but possibly the installer has more to do with it.
I use RJE's sensor relocation device, add the pressure gauge to it and than replace the oil pressure sensor below the water pump with the temp sensor he also sells...in the classifieds.
This is for the WBX.
I didn't realize that conversions were getting the same treatment.
Very excited to see this.
The temp and pressure readings are great diagnostic info and even better for peace of mind.
The Mocal's I made reference to are for thermostat controlled oil coolers and these extra ports.
tjet
tjet is offline
PostPosted: Tue Nov 10, 2015 5:09 pm    Post subject: Reply with quote
Can you run an aftermarket type oil cooler & keep the factory oil-water heat exchanger?
Also, whats the correct p/n for the thermostatic Mocal unit?
Is it this below? Thx
Mocal Sandwich Plate- 3/4"-16 Thread - Hi-Temp 200 Degree
MOC-SP1T-HT
$129.95
http://www.racerpartswholesale.com/product/13462/Sandwich_Plates
insyncro
Banned
insyncro is offline
PostPosted: Tue Nov 10, 2015 5:19 pm    Post subject: Reply with quote
Contact Vanistan and purchase the entire kit.
tjet
tjet is offline
PostPosted: Tue Nov 10, 2015 5:28 pm    Post subject: Reply with quote
I'd do that, but I already have an old Harrison racing cooler that I want to use along with an OEM Vanagon radiator fan.
geodude
geodude is offline
PostPosted: Tue Nov 10, 2015 6:12 pm    Post subject: Reply with quote
Dave
If you are keeping the stock cooler I don't see this as adding much or any additional leakage risk over putting in a tee. You also have the ability to put a temp probe in, which you can't with the tee. Most of the tee setups add several threaded connections and a hose or tube that are all potential leakage sources.
1988 GL Camper
Syncronoid
PostPosted: Wed Nov 11, 2015 9:34 am    Post subject: Re: Any experience with GlowShift Oil Filter Sandwich Adapte Reply with quote
I ended up buying the Prosport version oil filter sandwich and a couple extra o-rings just in case. Seems pretty much the same thing as the GlowShift. I also went with the 52mm Prosport EVO green/white gauges (oil pressure, oil temp and voltage)..... http://prosportgauges.com/evo-series-green-and-white.aspx
I have yet to make a final decision on placement, but am leaning towards what 10centlife did on the lower dash below the radio ( http://i105.photobucket.com/albums/m218/tencentlife/Vanagon%20Gauges/Oilgauges-driversview.jpg). I'm thinking the oil pressure and oil temp gauges to the left of the Syncro difff lock panel and the voltage to the right. I suspect going either side of the diff lock will be a tougher install since it's not just flat plastic in those spots. Fortunately, the Prosport gauges are only 1 1/2" deep. I could also mount all three even lower, facing up (like this http://i38.photobucket.com/albums/e121/toothlor/oct06030.jpg), using these simple and low profile mounting pods.... http://www.autometer.com/2-mounting-cup-black.html
Syncronoid
PostPosted: Fri Nov 13, 2015 3:16 pm    Post subject: Re: Any experience with GlowShift Oil Filter Sandwich Adapte Reply with quote
Here's a mock up of my planned gauge install. It is to scale. Oil pressure and oil temp to the left, battery voltage to the right utilizing Prosport's 52mm EVO Green/White gauges. I thought the Green/White would blend in well with the greenish lights on the diff panel.
http://prosportgauges.com/evo-electrical-Digital-Green-White-Oil-Pressure-gauge-.aspx
Page: 1, 2, 3  Next
