JDEL Samba Member
Joined: April 24, 2010 Posts: 112 Location: Orange County Ca.
Posted: Wed Jan 06, 2016 9:46 pm Post subject: Vanagon cluster question |
I came across this vanagon cluster. I need help figuring out what the small gizmo attached to the blue circuit tape just above the speedo is. And why is it there?
Skidub Samba Member
Posted: Wed Jan 06, 2016 10:26 pm Post subject: Re: Vanagon cluster question |
I just replaced my dead speedometer last week. Inside the speedo is a circuit board for the dynamic oil pressure system control unit. The tab connected to the printed circuit attached to the blue masking tape in your picture plugs into the 6 pins on the circuit board inside the speedo.
If you didn't install the blue masking tape I would guess the PO did in order to keep the tab on the pins.
Check out this page from Bentley:
_________________ 86 Syncro GL Tin Top
Subaru 2.5L Swap
Rblt Transaxle w/ R Locker + Decoupler |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10379 Location: Orbiting San Diego
Posted: Thu Jan 07, 2016 5:38 am Post subject: Re: Vanagon cluster question |
http://www.thesamba.com/vw/forum/album_page.php?pic_id=486175
Mark
JDEL wrote: |
dobryan Samba Member
Joined: March 24, 2006 Posts: 17152 Location: Brookeville, MD
JDEL Samba Member
Posted: Thu Jan 07, 2016 8:12 am Post subject: Re: Vanagon cluster question |
Very cool! I love this forum. thank you |
JDEL Samba Member
Posted: Thu Jan 07, 2016 1:23 pm Post subject: Re: Vanagon cluster question |
I just thought of another question related to this cluster. Do you think the PO put the resister on because the vangaon had a 2.5L Gowesty motor? |
Skidub Samba Member
Posted: Thu Jan 07, 2016 2:25 pm Post subject: Re: Vanagon cluster question |
That I don't know, but per Mark's information my guess would be this cluster was taken from an 86+van and used in a pre-86 van that did not have the circuit board inside the speedo. Gizmo (resistor) was required to make the oil light work properly. _________________ 86 Syncro GL Tin Top
Subaru 2.5L Swap
GreggK Samba Member
Joined: May 17, 2008 Posts: 1019 Location: Colorado/Philidelphia
Posted: Thu Jan 07, 2016 8:27 pm Post subject: Re: Vanagon cluster question |
I placed a resistor in the same place to satisfy my high pressure oil switch for my Subaru 2.2 conversion to keep the buzzer from sounding. This was recommended by someone on the Subaru/vanagon yahoo forum. Ive got more info somewhere in one of my folders that I can dig up if you need more details. |
