What Grease for Manual Window Gear/Spring????
djkeev
djkeev is offline
PostPosted: Mon Feb 29, 2016 11:17 am    Post subject: What Grease for Manual Window Gear/Spring???? Reply with quote
I just read half a dozen or more threads on windiw regulators..... Power and manual. On the Samba and elsewhere........
While the question is often asked.....
"What Grease do I use???”
I've yet to see an answer........
So, a thread dedicated to one question......
What is the grease of choice for VW cable style window regulators?
Thanks guys!!!!
Dave
Ghia
Vanagon
Beetle
PDXWesty
PDXWesty is offline
PostPosted: Mon Feb 29, 2016 11:56 am    Post subject: Re: What Gease for Manual Window Gear/Spring ???? Reply with quote
I just use a plain white lithium grease for most things like that.
89 Westy 2.1 Auto
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Mon Feb 29, 2016 12:10 pm    Post subject: Re: What Gease for Manual Window Gear/Spring ???? Reply with quote
I used a green wheel bearing grease intended for boat trailer axles
Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE.
Merian
Merian is offline
PostPosted: Mon Feb 29, 2016 12:40 pm    Post subject: Re: What Gease for Manual Window Gear/Spring ???? Reply with quote
any grease will be fine
Personally, I use a food grade certified bio-dynamic grease that is sustainably harvested deep in the natural wilderness from jojoba trees by indigenous women on the Islet of Langerhans. Each tube of grease is from a single carefully maintained tree. My grease is from a tree named Larry.
Zeitgeist 13
PostPosted: Mon Feb 29, 2016 12:45 pm    Post subject: Re: What Gease for Manual Window Gear/Spring ???? Reply with quote
I previously used white lithium grease in my regulators, but found that it lost its adhesion when subjected to water + time
Casey--
'89 Bluestar ALH
NEAT, no ICE.
djkeev
djkeev is offline
PostPosted: Mon Feb 29, 2016 3:04 pm    Post subject: Re: What Gease for Manual Window Gear/Spring ???? Reply with quote
My Dad (born 1917) was a huge White Lithium Grease fan!
He kept a tub with a hole in the lid with an acid brush in it. EVERYTHING got a smear of White Grease!
Even as a teen, I didn't care for the stuff and rarely used it...... I often opted for other more "modern" lubricants.
I keep a tube around..... Because of the Memories of my Dad, but rarely if ever use it.
I used a red wheel bearing grease, resists washout, flows at low temps and can withstand 540*!!
It should work I think...... and if it doesn't? I'll pull it out, clean it and have another go at it!
I figure that whatever I use is far superior to the hardened 1980's era wax I just removed!
Hmmmm.... That 1980`s era wax was probably one of my more "modern" lubricants?
Dave
Ghia
Vanagon
Beetle
Merian
Merian is offline
PostPosted: Mon Feb 29, 2016 3:39 pm    Post subject: Re: What Grease for Manual Window Gear/Spring???? Reply with quote
modern???
by cracky young feller, let me tell ya what we done did when a wagon needed grease coming over heah
we'd just pull over to a bubblin' spring of crude oil and tar in Why-oming, and mix that with the real fine gumbo mud they had all over the place
then we'd slather that onto the wood hub and continue on down the Oregon Trail
also good for the dysentery
oldhuldy67
oldhuldy67 is offline
PostPosted: Mon Feb 29, 2016 4:24 pm    Post subject: Re: What Gease for Manual Window Gear/Spring ???? Reply with quote
That's an incredible coincidence...my tree is Moe😳
I use a lithium on mine..last time I checked my carbon footprint is bigger than yours..
Currently:1980 Westy Westfalia Poptop (a total stock-look rebuild with all my favorite camping mods)
1967 stock Sunroof Beetle
Formerly:
1978 Westy Campmobile, the"EM50 Urban Assault Vehicle" code named "The Pickle"
1973 Squareback (sold on a lark)
1973 Super Beetle (crashed..walked away without a scratch)
1972 Standard Beetle (lost in a relationship..)
1966 Beetle (the Black Beauty, my Dad's)
1964 Beetle (the Beige Bug, my beginning beater, also my Dad's) Thanks, Dad.
Merian
Merian is offline
PostPosted: Mon Feb 29, 2016 4:26 pm    Post subject: Re: What Grease for Manual Window Gear/Spring???? Reply with quote
we gotta find Curly
djkeev
djkeev is offline
PostPosted: Mon Feb 29, 2016 4:29 pm    Post subject: Re: What Grease for Manual Window Gear/Spring???? Reply with quote
A seious question goes awry...... Rolling Eyes
Dave
Ghia
Vanagon
Beetle
Merian
Merian is offline
PostPosted: Mon Feb 29, 2016 4:31 pm    Post subject: Re: What Grease for Manual Window Gear/Spring???? Reply with quote
only after it was answered - see above
Chuey
Chuey is offline
PostPosted: Mon Feb 29, 2016 11:10 pm    Post subject: Re: What Grease for Manual Window Gear/Spring???? Reply with quote
Dave
Not many lubricants better than a bit of humor. And, this was some pretty good humor in my opinion.
Curly
OK. Really, Chuey
Pascal
Pascal is offline
PostPosted: Mon Apr 14, 2025 12:33 pm    Post subject: Re: What Grease for Manual Window Gear/Spring???? Reply with quote
I'm going to give Super Lube a try. Seems like white lithium grease is a popular choice, but it seems to get sticky and harden over time in my experience.
'84 Westy - 2.2wbx, GT Torque-Biasing Differential
'91 EA Cabby
OlisGarage
OlisGarage is offline
PostPosted: Mon Apr 14, 2025 3:19 pm    Post subject: Re: What Grease for Manual Window Gear/Spring???? Reply with quote
Which super lube? Last I checked they produced a lot of lubricants with the name super lube on the tube.
I personally was planning on using either wheel bearing grease or dielectric grease (dielectric from super lube since I have a whole tube of that).
1981 VW Vangagon TDI (in progress)
1984 VW Rabbit Convertible (daily)
2003 VW Jetta Wagon TDI (recovering from a hit and run)
WiboBusMan
WiboBusMan is offline
PostPosted: Mon Apr 14, 2025 6:20 pm    Post subject: Re: What Grease for Manual Window Gear/Spring???? Reply with quote
Agree that white lithium grease tends to cake up over far too little time.
My latest favorite is Lucas Red 'n Tacky - it comes in a gun tube and also in handy spray format - it is quite tacky, as the name implies, so tends to stay in place, but also remains sufficiently soft in the cold. You don't need much at all in that application, but you do want to clean out the old crud fairly well before greasing.
While I have been using it for a few years, I don't have enough of a long view of how it stands up over time. So far it seems to be perfect wherever I've used it (including window regulators).
It is also relatively neutral in smell. Some wheel bearing greases have quite a sulfur stink, which you want to avoid anywhere "in cabin", and the doors' innards aren't really sealed off from the inside of the vehicle. This is also one of the advantages of white lithium (low odor).
W.
Science has sacrificed Truth on the altar of its narrative.
Pascal
Pascal is offline
PostPosted: Tue Apr 15, 2025 4:28 am    Post subject: Re: What Grease for Manual Window Gear/Spring???? Reply with quote
Super Lube multi-purpose synthetic grease with syncolon (PTFE). It’s in a 85g/3 oz tube. It’s actually the only one I’ve ever seen other than the spray can version.
'91 EA Cabby
vanagonjr
vanagonjr is offline
PostPosted: Wed Apr 16, 2025 10:22 am    Post subject: Re: What Grease for Manual Window Gear/Spring???? Reply with quote
Yeah, I’ve only seen that one, but was surprised that they had many more on the website. But in the 3oz/85g tube size, there are only few choices. There seems to be two that Ace Hardware carries, but not all stores have both.
They have one listed as for O-Rings which is supposed to help condition and seal O-rings and be compatible with plastics & rubber and the Multi-purpose one, which is the more common one.
It sounds like the standard multipurpose version is likely OK for most plastics, but not ideal for all rubber compounds.
The O-Ring version was US$30 vs $15 for the standard multi-purpose.
Up to you if it is worth the extra money. I might buy a tube to use on new door seals, etc. After all, I spent almost that much on muffins for the family and an ice coffee.
Complete SA Grill Set-up for sale!
https://www.thesamba.com/vw/classifieds/detail.php?id=2748907
