PapaKoch Samba Member
Posted: Mon Mar 07, 2016 11:16 am Post subject: No Idle on 1500 Single Port |
I would appreciate any advice/suggestions as to the cause.
Has anyone ever experienced these problems before?
Thank you for reading!
I have not been able to get the bus to idle since December.
Although dying at idle is the primary issue, there are some other nuances to the problem.
There is sufficient power in first and second, but very limited power in 3rd and 4th gear.
The valve cover gasket for number 1 and 2 cylinders only lasts for one day/drive.
The gasket will leak and/or expand sometimes getting sucked in between the rocker arms and pushrod tubes.
The engine only runs at high RPMs with extremely rich gas.
The engine also dies/lags when gas is applied (I think this colloquially called a flat spot).
Unfortunately, this happens all time.
I spent several days in past few months trying to resolve the issues and all day yesterday, but if anything the problem is worse.
Since Cruise the Coop is coming up this weekend, I am at my wits end with it.
Here is a list of things I have tried so far:
Adjusted valves
Adjusted timing with static timing light
Adjusted timing by ear
Adjusted Carb (2.5 turns out on gas and idle screws)
New points in distributor (009 Distributor)
Adjusted points to factory gap of .016in
Adjusted points to open more than factory gap
Made sure plug wires were firmly secured to cap spark plugs
Drain and fill oil (2.5 quarts)
Changed carb to Solex 30 Pict -3 (rebuilt)
Changed carb to Brosol 30/31 (New)
New cork valve cover gasket (no permatex)
New rubber valve cover gasket (no permatex)
Cross-Post from:
http://www.volksfolks.org/forums/air-cooled-vw-tech/no-idle-on-1500-single-port/ |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17667 Location: San Diego, California
Posted: Mon Mar 07, 2016 12:25 pm Post subject: Re: No Idle on 1500 Single Port |
Could you please post some pictures of your engine? Also, knowing where you are helps a lot. Most people include that info along with what kind of bus you have in their signature line. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Randy in Maine Samba Member
Posted: Mon Mar 07, 2016 1:09 pm Post subject: Re: No Idle on 1500 Single Port |
Stick your dwell meter on that green coil wire and tell us just how good you are at getting the points to the 47º +/- 3º.
then time the engine using a real timing light. Set that fine 009 distributor to 30º +/- 2º when all of the centrifical advance it has to offer is all in at about 3500 RPMs.
Set the idle to the correct 850 RPMs +/- 50 RPMs.
Report back your findings. |
Posted: Mon Mar 07, 2016 1:12 pm Post subject: Re: No Idle on 1500 Single Port |
If it won't idle at all and you've tried two separate carburetors I'd guess you might have a large vacuum leak somewhere. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52933 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Mar 07, 2016 1:16 pm Post subject: Re: No Idle on 1500 Single Port |
PapaKoch wrote: |
There is sufficient power in first and second, but very limited power in 3rd and 4th gear. |
If you can prop the throttle open a little and get it running at a constant speed pull one plug wire at a time out of the distributor cap and listen for a drop in RPM, then replace the wire and move on to the next, do any make no difference? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Tcash Samba Member
Joined: July 20, 2011 Posts: 12846 Location: San Jose, California, USA
Posted: Mon Mar 07, 2016 1:28 pm Post subject: Re: No Idle on 1500 Single Port |
As part of a tune up. You should
Lubing the Distributor
dying at idle
engine also dies/lags when gas is applied (flat spot)
Make sure the hose under the oil fill cap is not kinked or clogged.
Adjusted valves. To what specifications?
Here are a few vids
https://www.youtube.com/watch?v=EpH7VftH3_I
https://www.youtube.com/watch?v=vQ9ccGXtZL0
https://www.youtube.com/watch?v=T3MgWSXTwWQ
https://www.youtube.com/watch?v=isYX7b5r5Ng
https://www.youtube.com/watch?v=Ozht-_iu3Ew
https://www.youtube.com/watch?v=787INwvir24
http://www.volkzbitz.com/34pict-3---4-and-h30-31-adjustments.html
009's are known for having a flat spot. Rich mix helps.
It would be better to use a dwell meter and set them to 50*
You could check for a high tension leak.
Ignition High Tension Leaks
Did the oil smell like gas?
Check your breather hose as mentioned.
Also put the valve cover up against the head with no gasket and make sure it is not bent. Make sure the bailing wire is in its holes on the end and has the same amount of tension as the one that is not leaking.
Glue the gasket to the valve cover, and let the glue set so the gasket is not squessed out when you install it. |
Tcash Samba Member
Posted: Mon Mar 07, 2016 1:33 pm Post subject: Re: No Idle on 1500 Single Port |
Tcash wrote: |
Cylinder power balance test.
Place a length of vacuum hose between the Distributor cap and plug wires.
Connect test light ground directly to the battery.
Ground out each cylinder and note the RPM drop.
Each cylinder should have close to the same RPM drop.
Cylinders with little or no rpm drop need further diagnoses and repair.
While you got the Test Light out.
Ignition High Tension Leaks |
Posted: Mon Mar 07, 2016 1:44 pm Post subject: Re: No Idle on 1500 Single Port |
aeromech wrote: |
Could you please post some pictures of your engine? Also, knowing where you are helps a lot. |
The engine is in a 1972 bus.
I am in Chattanooga, TN.
Here is a picture from I while back when I had it out last summer.
Posted: Mon Mar 07, 2016 1:55 pm Post subject: Re: No Idle on 1500 Single Port |
Tcash wrote: |
[color=green]...Did the oil smell like gas? |
I set all the valves to .006" while the engine was cold.
I will try to get some more up to date pictures after work today.
The oil did not smell of gas.
Posted: Mon Mar 07, 2016 1:59 pm Post subject: Re: No Idle on 1500 Single Port |
Does the engine rotate normally when turned over by hand? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Mon Mar 07, 2016 2:04 pm Post subject: Re: No Idle on 1500 Single Port |
aeromech wrote: |
Does the engine rotate normally when turned over by hand? |
When turning it over by hand, there seems to be about the same compression on all but one of the cylinders. Unfortunately,I have not done a compression tester. |
Posted: Tue Mar 08, 2016 9:06 am Post subject: Re: No Idle on 1500 Single Port |
Thanks to everyone for the advice.
I will take anything I can get. Ha! Ha!
Last night, I decided to start over from scratch. When I pulled the valve covers off to adjust the valves, there WAS gas in the oil even though that oil had only been in engine for 24 hours. So, I replaced the fuel pump. I also adjusted the valves to .006, adjusted the points to .016, put the newly cleaned out 30 pict carb on, used static timing light, and drained and filled the oil. By that time, it was late and I did not want to wake the neighbors.
Tonight test firing and engine analyzing is on the agenda. If the engine does not fire up right off, I may need to dig deeper. Although, I do not have a real timing light or a compression tester, I feel like those may be on shopping list soon.
I will post back with my findings and updated pictures. With all this time behind the engine these past few days, I have been able to clean it up quite a bit!  |
Green70 Samba Member
Joined: January 23, 2012 Posts: 186 Location: Out in the Garage
Posted: Tue Mar 08, 2016 10:14 am Post subject: Re: No Idle on 1500 Single Port |
Do a compression test. If the numbers are low, you might be able to get it running, but not well. Also, do what Randy in Maine suggested and do the timing with a real timing light. You need to know that its correct at full advance. |
Malokin Martin Samba Member
Posted: Tue Mar 08, 2016 10:21 am Post subject: Re: No Idle on 1500 Single Port |
PapaKoch wrote: |
there WAS gas in the oil even though that oil had only been in engine for 24 hours. |
This will kill an engine super quick.
I would recommend starting here:
http://www.vw-resource.com/gas_oil.html |
sodbuster Samba Member
Joined: August 08, 2004 Posts: 1132 Location: wherever my baywindow takes me.
Posted: Tue Mar 08, 2016 2:37 pm Post subject: Re: No Idle on 1500 Single Port |
Did you check the electric idle valve on the carb? With the ignition turned on remove the wire from the idle valve then touch it back to the connection spade of the valve several times. The valve should make an audible click when you do that. If it clicks it should be good to go. if you hear no click coming from the idle valve its most likely bad. Double check the 12v power source for the idle valve to be sure. If it tests bad or has no voltage your engine won't idle.
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13540 Location: West Coast, USA
Posted: Wed Mar 09, 2016 1:02 am Post subject: Re: No Idle on 1500 Single Port |
sodbuster wrote: |
[img] |
Also check to make sure it is screwed in all the way. Snug is good, just because it has a hex section doesn't mean you need to wail on it with a wrench.
Robbie _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
Road trip reports and tech blog:
https://www.patreon.com/airschooled |
Posted: Wed Mar 09, 2016 10:07 am Post subject: Re: No Idle on 1500 Single Port |
I had it running rough when I first started working last night. Unfortunately, it ran rough like this for two minutes, but never fired off again even thought a put on a new coil and a different vacuum advance distributor. Video: https://www.youtube.com/embed/D7Cr0ZeqsAE |
Posted: Wed Mar 09, 2016 10:13 am Post subject: Re: No Idle on 1500 Single Port |
sodbuster wrote: |
Did you check the electric idle valve on the carb? |
Thanks for the reminder. I have verified the Idle Cut off does function and "click" when I turn the key. Of the two carbs I have, only the 30/31 has an idle cut off on it. Currently, I am trying to run the 30 Pict-3 because I just cleaned it out last weekend. But, I eventually want to switch back to the 30/31.
As promised, here is the a picture of the engine as it was when it ran a little last night. Sorry for the low light. I can not wait until the time change so it will not be dark outside by the time I get off work!!!
