Rex lucy Samba Member
Joined: April 10, 2008 Posts: 497 Location: pleasant plains arkansas
Posted: Sun Mar 20, 2016 7:48 pm Post subject: 010 distributor |
| i'm running an 010 distributor in my t3 and wondering if it retards #3 spark. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23579 Location: Kimball, Mi
Posted: Sun Mar 20, 2016 7:56 pm Post subject: Re: 010 distributor |
| Rex lucy wrote: |
You might want to ask Mr 010 (Glenn Ring) about that. He's about the only one who would know right off hand. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| "Friends are God's way of apologizing for relatives." |
| Tram wrote: |
| People keep confusing "restored" and "restroyed". |
Joined: April 27, 2002 Posts: 6868 Location: Pentwater, Michigan
Posted: Mon Mar 21, 2016 7:59 pm Post subject: Re: 010 distributor |
The 010 does not have # 3 lobe retarded. The Distributor Distributor. _________________ Roads Scholar
Member# 2059 |
wcfvw69 Samba Purist
Posted: Mon Mar 21, 2016 8:04 pm Post subject: Re: 010 distributor |
| tasb wrote: |
| The 010 does not have # 3 lobe retarded. The Distributor Distributor. |
What about the German made 009 from the 70's. _________________ Contact me at [email protected]
The Samba member since 2004.
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80508 Location: Sneaking up behind you
Posted: Tue Mar 22, 2016 4:07 am Post subject: Re: 010 distributor |
009... yes
010... no _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Tue Mar 22, 2016 6:20 am Post subject: Re: 010 distributor |
The 0 231 129 010 is a copy of the VJ 4 BR 25 which was installed on the 1960 Bus. This was long before any distributor was retarded on the # 3 lobe. _________________ Roads Scholar
Member# 2059 |
Glenn  Mr. 010
Posted: Tue Mar 22, 2016 6:35 am Post subject: Re: 010 distributor |
Most of the aluminum models have a 4* retard on #3. _________________ Glenn
Member #1009
#BlueSquare
Critter1 Samba Member
Joined: August 04, 2004 Posts: 1579 Location: Sacramento
Posted: Tue Mar 22, 2016 9:48 am Post subject: Re: 010 distributor |
| Glenn wrote: |
| Most of the aluminum models have a 4* retard on #3. |
Educate me... Why the #3 retard on the aluminum distributors? _________________ Justin |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13587 Location: Tejas!
Posted: Tue Mar 22, 2016 9:56 am Post subject: Re: 010 distributor |
before the doghouse type shroud (type 1) the oil cooler sat right over cyl #3. It got hotter. VW took 3 or so degrees off of cyl 3 in order to reduce the heat a bit. With the dog house shroud, it opened that air passage up, vw eliminated the #3 retard
Type 3's are 180 out from type 1. So you end up retarding #1...
(please correct me if I'm wrong, this is what I have always thought) _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Tue Mar 22, 2016 8:02 pm Post subject: Re: 010 distributor |
During the mid 1960's the type III distributors were set up the same as the Beetle so even on them #3 was retarded. The 1970's SVDA and DVDA distributors were all 180 out so that part is correct but true for type I also. _________________ Roads Scholar
Member# 2059 |
