dave Friday Samba Member
Joined: July 13, 2013 Posts: 60 Location: Southern Spain
Posted: Sun Apr 03, 2016 3:43 am Post subject: 800°C Exhaust Gas Temperature!! |
Hi all,
As above, nearly 800°C. Oil temp 85°C, water under 90°C, boost 5 bar max.
The EGT drops quickly from 600°C to 350°C (at 900 rpm) then takes 5 seconds to drop from 350 to below 300.
Pump timing .95mm
Engine "SB" from a GTD Golf.
Any ideas?
Ta. _________________ 1992 t3 syncro jx 1.6td leisure drive camper van
Now with " sb" engine |
Team WorldTour Samba Member
Joined: September 02, 2010 Posts: 2427 Location: Der Vaterland
Posted: Sun Apr 03, 2016 3:19 pm Post subject: Re: 800 deg c egt!! (Exhaust Gas Temperature) |
Don't drive it..... _________________ 1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat! |
Posted: Sun Apr 03, 2016 3:49 pm Post subject: Re: 800 deg c egt!! (Exhaust Gas Temperature) |
Good idea!
Have you got any others? _________________ 1992 t3 syncro jx 1.6td leisure drive camper van
Posted: Sun Apr 03, 2016 4:13 pm Post subject: Re: 800 deg c egt!! (Exhaust Gas Temperature) |
| Where are you measuring the EGTs? If this is at full load then 800°F doesn't sound that hot to me. |
Posted: Sun Apr 03, 2016 4:25 pm Post subject: Re: 800 deg c egt!! (Exhaust Gas Temperature) |
in the exhaust manifold where it meets the turbo [800deg centigrade!].
I'm surprised its so high as the max fuel screw still has the tamper proof coller on. _________________ 1992 t3 syncro jx 1.6td leisure drive camper van
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12177 Location: Port Manteau
Posted: Sun Apr 03, 2016 4:41 pm Post subject: Re: 800 deg c egt!! (Exhaust Gas Temperature) |
800C = 1472F
That's way too high for my comfort. Under what circumstances are you seeing this high of EGT? Are you sure the gauge is accurate? Your high oil temps may indicate that the pyrometer is indeed telling some sort of story about excessive heat in the engine _________________ Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE. |
Posted: Sun Apr 03, 2016 4:47 pm Post subject: Re: 800 deg c egt!! (Exhaust Gas Temperature) |
| Sorry, I missed the 800° was Centigrade, yes that would be awfully hot. |
Posted: Sun Apr 03, 2016 4:53 pm Post subject: Re: 800 deg c egt!! (Exhaust Gas Temperature) |
85 c too hot?it was 130c before I fitted an oil cooler!
700 to 800c is in top gear up hill,i change down to third gear to bring the temp down of course.
ps I used a test meter to check that egt gauge is correct. _________________ 1992 t3 syncro jx 1.6td leisure drive camper van
oceanair Samba Member
Joined: June 09, 2013 Posts: 724 Location: Victoria, BC
Posted: Sun Apr 03, 2016 4:54 pm Post subject: Re: 800 deg c egt!! (Exhaust Gas Temperature) |
Hi -- I don't know that it is a problem -- perhaps others can share what they would expect.
I fly airplanes that run on gasoline. 1450F is a normal temperature at TIT, Turbo inlet temperature. CHTs are much more important than EGTs because they cool very quickly and it depends on where you measure them from. _________________ 84 Vanagon Pop Top Conversion from Tin Top, 1970 Ghia - all sweet rides! Love em!
Previous: Green 72 Tin Top, White 72 Westy, Blue 64 Beetle, Yellow 71 Squareback, 2014 Jetta TDI Wagon - wish I could have them all back! |
Witless Joe Samba Member
Posted: Sun Apr 03, 2016 7:00 pm Post subject: Re: 800 deg c egt!! (Exhaust Gas Temperature) |
| dave Friday wrote: |
Hi all,as above nearly 800 deg c ..oil temp 85 c water under90 c boost.5 bar max
The EGT drops quickly from 600 c to 350 c (at 900 rpm) then takes 5 seconds to drop from350 to below 300
Pump timing .95mm
Engine "sb" from a gtd golf.
Any ideas?
Ta. |
I think your boost pressure is kind of low. That's only about 7 psi. A GTD Golf would run closer to 1 bar boost pressure stock, IIRC.
If you crank up your boost pressure, I would bet your EGT drops to more like 675*C in the same circumstances.
Boost cools EGT in a turbodiesel.
edit - I bet you have a pretty smoky exhaust at full go pedal, right? I suspect you're overfueled, relative to your boost pressure.
You haven't said what kind of turbo is on this thing, but there are a couple of simple ways to cheat the peak pressure up higher, depending on what you have. Either you can play with the wastegate setting right on the turbo, or install an external boost controller valve or "bleed". They all basically cheat the wastegate diaphragm from seeing the full amount of pressure built by the turbo, so the wastegate opens at higher pressure.
As for oil temps, 85*C isn't even hot enough to boil the water condensation out of the oil, so I'd say that was fine.
Free advice, worth every cent, YMMV, etc.
mreuter Samba Member
Posted: Sun Apr 03, 2016 7:05 pm Post subject: Re: 800 deg c egt!! (Exhaust Gas Temperature) |
| above 1600°F you have to expect engine damage. 1450°F sounds reasonable under full load. |
Posted: Sun Apr 03, 2016 11:56 pm Post subject: Re: 800 deg c egt!! (Exhaust Gas Temperature) |
Thanks all,off to catch a 'plane to the UK.
Will type later. _________________ 1992 t3 syncro jx 1.6td leisure drive camper van
Posted: Sun May 06, 2018 1:38 am Post subject: Re: 800 deg c egt!! (Exhaust Gas Temperature) |
Well...the EGT probe/sensor failed,so I fitted the(exposed tip )sensor that I had been meaning to fit ..
Guess what? EGT now max 450/500 deg c!
Lesson learnt. _________________ 1992 t3 syncro jx 1.6td leisure drive camper van
jimf909 Samba Member
Posted: Sun May 06, 2018 7:00 am Post subject: Re: 800 deg c egt!! (Exhaust Gas Temperature) |
Neato! This is nomination #2 for bump of the month. Thanks for the follow-up. Did you have a good visit to the UK? _________________ - Jim
| Butcher wrote: |
| This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
Posted: Sun May 06, 2018 7:25 am Post subject: Re: 800 deg c egt!! (Exhaust Gas Temperature) |
Thanks Jim ,yes it's nice to visit the uk but I wouldn't want to live there(anymore ) _________________ 1992 t3 syncro jx 1.6td leisure drive camper van
Posted: Mon Aug 17, 2020 9:03 am Post subject: Re: 800 deg c egt!! (Exhaust Gas Temperature) |
Hi all,well the exposed tip EGT sensor failed! So I replaced it but,the exposed tip sensor reads about 250 deg c higher than the enclosed type sensor
Tested by sticking them ( sensors ) in the Gas ring..
Kr. _________________ 1992 t3 syncro jx 1.6td leisure drive camper van
Gnarlodious  Samba Member
Joined: September 28, 2013 Posts: 2411 Location: Adobe Jungle USA
Posted: Mon Aug 17, 2020 10:02 pm Post subject: Re: 800 deg c egt!! (Exhaust Gas Temperature) |
I suggest that you are overfueled, possibly because you are not getting enough boost or maybe your oxygen sensor is fouled, or both. My AAZ really gets hot EGT at high elevations when it is overfueling. Apparently the hydrocarbons combust in an oxygen deficit and produce no power but a lot of exhaust heat. 800c is about the max for safety, so take it easy. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
Posted: Tue Aug 18, 2020 4:08 pm Post subject: Re: 800 deg c egt!! (Exhaust Gas Temperature) |
Hi Gnarlodious and thanks for the advice,I did adjust the wastegate to get the boost up a bit...a month ago I replaced the turbo( £200 Chinese ,looks good )the van runs as it normally does but the EGT sensor is faulty 1.3k ohms between element and casing!
Now the EGT is just over 600deg c ( foot to the floor up hill in third or top gear!)
I now need to repair my boost gauge,and check that the EGT gauge is reading ok( with my new meter)
Kr,Baz _________________ 1992 t3 syncro jx 1.6td leisure drive camper van
Abscate Samba Member
Joined: October 05, 2014 Posts: 24468 Location: NYC/Upstate/ROW
Posted: Tue Aug 18, 2020 4:15 pm Post subject: Re: 800 deg c egt!! (Exhaust Gas Temperature) |
| jimf909 wrote: |
Neato! This is nomination #2 for bump of the month. Thanks for the follow-up. Did you have a good visit to the UK? |
No,it rained mainly on the plane.
Most of the instruments sold into these markets are junk with 50% tolerances or worse _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
Posted: Tue Aug 18, 2020 6:10 pm Post subject: Re: 800 deg c egt!! (Exhaust Gas Temperature) |
Abscate hi,I agree about the quality? Of the gauges etc,EGT sensors ( the cheap ones ) don't last long..
What I have found is that a £10 multimeter with a temperature setting works well as a EGT gauge,possibily for other sensors..
We live in the mountains at 2350 ft and get some interesting weather,
When the rain in Spain is falling mainly on the plains,up here it's raining golf ball sized hail,dents in your car!! This time of year it's 40 deg c a lot.. _________________ 1992 t3 syncro jx 1.6td leisure drive camper van
