Don't do what I did during an engine rebuild
davidyat
davidyat is offline
PostPosted: Mon Jan 02, 2017 7:43 am    Post subject: Don't do what I did during an engine rebuild Reply with quote
So I'm rebuilding my 1967 Beetle engine. I get to the installation of the thermostat that controls the opening and closing of the vanes inside the fan shroud. To check if the thermostat is working, I put it near a heater in my garage. I get distracted with the engine. Time goes by. I look back at the thermostat and it has expanded from about 1 inch to almost 12 inches. YIKES!!! It stretched so far out of shape that it never went back to its' original size. It was like when you stretch a spring too far. Take the advice of most mechanics, boil some water and place the thermostat near or in it. When you see it move, TAKE IT OUT!!!! IT IS WORKING!!
Good luck on your rebuild
diablosandwich
diablosandwich is offline
PostPosted: Mon Jan 02, 2017 7:46 am    Post subject: Re: Don't do what I did during an engine rebuild Reply with quote
Happy new year. It is best to test it in the thermostat bracket so this does not happen. Casey
1966 Java Greens
davidyat
davidyat is offline
PostPosted: Mon Jan 02, 2017 8:27 am    Post subject: Re: Don't do what I did during an engine rebuild Reply with quote
Even better advice. Keep it in the bracket.
67rustavenger
67rustavenger is offline
PostPosted: Mon Jan 02, 2017 8:34 am    Post subject: Re: Don't do what I did during an engine rebuild Reply with quote
Welcome to the samba.
We all get distracted from time to time. Hell I got distracted a few weeks ago and damn near burned down my car and house when I left a fuel line off a carb and started my engine Shocked
The up side is that you can still find thermo-stats in the classifieds and at swap meets. Just be careful with the next one.
Please post some pics of what you are working on.
Good Luck.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
gt1953
gt1953 is offline
PostPosted: Mon Jan 02, 2017 4:23 pm    Post subject: Re: Don't do what I did during an engine rebuild Reply with quote
Yep you trashed that thermostat. Boiling water is for water cooled engines. Keep it in the thermostat bracket, use a blow drier on it carefully only to test it. Do not buy one that is expanded.
72 type 1
72 Squareback
Tim Donahoe
Tim Donahoe is offline
PostPosted: Mon Jan 02, 2017 6:07 pm    Post subject: Re: Don't do what I did during an engine rebuild Reply with quote
Gt's method is the best. A good thermostat will open very quickly, using a blow dryer set on high.
Tim
Let's do the Time Warp again!
Richard O'Brien
tasb
The Distributor Distributor
tasb is offline
PostPosted: Mon Jan 02, 2017 6:44 pm    Post subject: Re: Don't do what I did during an engine rebuild Reply with quote
It'd be kinda fun to see a pic of that thermostat, actually: Arrow
I've seen them over extended by an inch or two but never that far.
Roads Scholar
Member# 2059
